Cloud and Lightning Code
89delta
Re: Cloud and Lightning Code
Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
Sent from my SAMSUNG-SGH-I717 using Tapatalk
- cosmith71
I think it would be better if we could prevent the reset to begin with. I have some ideas. I'll work on them Monday when I have some time.89delta wrote:Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
89delta
Sounds good Colin. Thanks for working on a fix for it. But figured you would want to know about the "bug".
- cosmith71
You're welcome!
- cosmith71
I have a fix, in theory at least. I haven't had a lot of time to test but it appears to work.
Find this section in cloudcheck()
And add these two lines:
Remove this section:
And replace with this:
This appears to work without setting off the watchdog timer and resetting the unit.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;Code: Select all
static time_t DelayCounter=millis();
static int DelayTime=random(1000);Code: Select all
int a=random(5);
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255);
delay(20+random(50));
analogWrite(daylightPWMPin, 0);
delay(30+random(20));
delay(random(1000));
}Code: Select all
int a=random(5);
}--Colin
- Sacohen
I bit OT, but do the LDD drivers generate enough heat to be concerned about.
I'm putting my 4 up board in a Radio Shack 5x2.5x2 Project Enclosure with openings cut in the sides to gain access to the screw down terminals for wiring.
Do I need another source of ventilation?
- cosmith71
I was surprised at how hot mine get. The more LED's on the string, the hotter they get. Some of mine get up to 60C, and they are open air.
- Sacohen
Thanks and thanks for the code.
Here is what my enclosure looks like.
I may have to leave it open air or have a fan blowing on it.
I think the reboot issue is the watchdog kicking in.
We need to reset it inside the lightning sequence.
I'm pretty sure if you use the original code and just add the code below inside the for loop, it will stop:
wdt_reset();
- cosmith71
How often does the watchdog timer need to be reset? I thought it was every second. The big delay is the delay(random(1000)) just outside the loop which might be pushing it over the top.
I'm thinking we may need more lightning. Like a chance during most of the cloud. Might be my day-off project.
Yes, every second and you are right. You may need one wdt_reset outside the loop too.
- lnevo
Do we need a delay here? Sorry I haven't looked deep enough at the code, but is there any way to be non-blocking? Delays can add up...
I've already seen slowdown in some calculations because my INO is slow to begin with...
What i would recommend maybe is increasing the watchdog timeout if possible or disable/enable before and after the delay is needed.
- cosmith71
Take a look at the replacement code. It doesn't delay so much as it just doesn't flash again until an appropriate period of time has passed. The for() loop can take up to 600 ms max to execute, but past that it's non-blocking.
That, and in it's current form, it only happens for 5 seconds max in the middle of a cloud.
- lnevo
You don't need a for loop...we are already in a loop....if the for loop is what is taking time we can change that so its less stateful and doesnt require a second loop. I'll take a better look this week..
- cosmith71
The new code has ran a couple of times today already. No resets so far.
- lnevo
- cosmith71
I did. See previous page.
- lnevo
I meant the update...wasnt sure you updated the first post or not
- cosmith71
Not yet, I wanted to test it first. But I will soon.lnevo wrote:I meant the update...wasnt sure you updated the first post or not
- cosmith71
OP updated with non-apocalyptic timing. It shouldn't set off the watchdog timer and reset the unit anymore. It's also less monopolistic of resources when it's running.
- cosmith71
Also added option for Mega Storm to OP, with lightning throughout the cloud increasing in intensity as the cloud gets darker. Pretty awesome, if I do say so myself!
- lnevo
Colin, any chance you can integrate the "mini" storm (non-fast/responsive drivers) so i have one cloud function to work on? I'm going to add high resolution dimming and potentially turn this into a class for ease of use/configuration.
- lnevo
89delta
Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
- lnevo
We should add an array of storm types you want and randomize between them.
sometimes mega, sometimes mini, could even simulate a storm coming in. Where is Jon, time to start talking about the audio out he has again...
- cosmith71
OK, added the slow response lightning to the OP. It's selectable via a variable switch in the checkcloud() routine.
I doubt I would want to run anything but Mega-Storm. It's awesome.
- cosmith71
I haven't had any issues with overrides with the new code. Even with the Mega-Storm, everything runs smooth with no resets.89delta wrote:Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
- Sacohen
God I can't wait to get my LEE's up and running.
89delta
No issues with the relays resetting Colin...Thanks.....but am gonna update the new code tonight. Lnevo....great idea about the storm mode being randomized.
- lnevo
Colin,
You left the default as Mega
I added the random selection, you'll just need to set this array to the types of lightning you want:
Once you set that, each cloud should have a unique lightning type. If you just want Slow, or Fast you can put one. If you want one more than the others, you can put it multiple times in the array
Need to think a little more how we could combine multiple types of lightning during one cloud episode. I need to actually run the code though too to see how it looks overall
byte LightningModes[] = { Slow, Fast, Mega };
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(12,00)
// Add Random Lightning modes
#define Slow 0
#define Fast 1
#define Mega 2
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// Check for lightning. When lightning occurs, it will happen for 5 seconds at the middle of a cloud.
// We will have from 1 to 4 consecutive flashes, then a random delay of up to 1000 ms before another set of flashes.
// This first line basically says: Is there supposed to be lightning? Are we within a 5 second window in the middle
// of the cloud when lightning occurs? Are we not in a delay between sets of flashes? If so, do another round of flashes.
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
switch (lightningMode) {
case Mega:
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
analogWrite(daylightPWMPin, 255); // Flash on
delay(20+random(50)); // Wait from 20 to 69 ms
analogWrite(daylightPWMPin, 0); // Flash off
delay(30+random(20)); // Wait from 30 to 49 ms
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Fast:
break;
case Slow:
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
