Page 1 of 4
Re: Cloud and Lightning Code
Posted: Fri Aug 01, 2014 8:41 pm
by 89delta
Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
Sent from my SAMSUNG-SGH-I717 using Tapatalk
Posted: Sat Aug 02, 2014 5:53 am
by cosmith71
89delta wrote:Am sure if we can do some sort of last state on the relays before the lighting it'd fix it....
I think it would be better if we could prevent the reset to begin with. I have some ideas. I'll work on them Monday when I have some time.
Posted: Sat Aug 02, 2014 6:22 am
by 89delta
Sounds good Colin. Thanks for working on a fix for it. But figured you would want to know about the "bug".
Posted: Sat Aug 02, 2014 6:36 am
by cosmith71
You're welcome!
Posted: Sun Aug 03, 2014 3:03 am
by cosmith71
I have a fix, in theory at least. I haven't had a lot of time to test but it appears to work.
Find this section in cloudcheck()
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
And add these two lines:
static time_t DelayCounter=millis();
static int DelayTime=random(1000);
Remove this section:
int a=random(5);
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin, 255);
delay(20+random(50));
analogWrite(daylightPWMPin, 0);
delay(30+random(20));
delay(random(1000));
And replace with this:
int a=random(5);
This appears to work without setting off the watchdog timer and resetting the unit.
Posted: Sun Aug 03, 2014 7:57 am
by Sacohen
I bit OT, but do the LDD drivers generate enough heat to be concerned about.
I'm putting my 4 up board in a Radio Shack 5x2.5x2 Project Enclosure with openings cut in the sides to gain access to the screw down terminals for wiring.
Do I need another source of ventilation?
Posted: Sun Aug 03, 2014 8:04 am
by cosmith71
I was surprised at how hot mine get. The more LED's on the string, the hotter they get. Some of mine get up to 60C, and they are open air.
Posted: Sun Aug 03, 2014 8:11 am
by Sacohen
Thanks and thanks for the code.
Here is what my enclosure looks like.
I may have to leave it open air or have a fan blowing on it.
Posted: Sun Aug 03, 2014 8:47 am
I think the reboot issue is the watchdog kicking in.
We need to reset it inside the lightning sequence.
I'm pretty sure if you use the original code and just add the code below inside the for loop, it will stop:
Posted: Sun Aug 03, 2014 9:35 am
by cosmith71
How often does the watchdog timer need to be reset? I thought it was every second. The big delay is the delay(random(1000)) just outside the loop which might be pushing it over the top.
I'm thinking we may need more lightning. Like a chance during most of the cloud. Might be my day-off project.
Posted: Sun Aug 03, 2014 11:08 am
Yes, every second and you are right. You may need one wdt_reset outside the loop too.
Posted: Sun Aug 03, 2014 11:21 am
Do we need a delay here? Sorry I haven't looked deep enough at the code, but is there any way to be non-blocking? Delays can add up...
I've already seen slowdown in some calculations because my INO is slow to begin with...
What i would recommend maybe is increasing the watchdog timeout if possible or disable/enable before and after the delay is needed.
Posted: Sun Aug 03, 2014 11:28 am
by cosmith71
Take a look at the replacement code. It doesn't delay so much as it just doesn't flash again until an appropriate period of time has passed. The for() loop can take up to 600 ms max to execute, but past that it's non-blocking.
That, and in it's current form, it only happens for 5 seconds max in the middle of a cloud.
Posted: Sun Aug 03, 2014 12:52 pm
You don't need a for loop...we are already in a loop....if the for loop is what is taking time we can change that so its less stateful and doesnt require a second loop. I'll take a better look this week..
Posted: Sun Aug 03, 2014 1:29 pm
by cosmith71
The new code has ran a couple of times today already. No resets so far.
Posted: Sun Aug 03, 2014 1:32 pm
Post it
Posted: Sun Aug 03, 2014 1:38 pm
by cosmith71
I did. See previous page.
Posted: Sun Aug 03, 2014 3:51 pm
I meant the update...wasnt sure you updated the first post or not
Posted: Sun Aug 03, 2014 4:09 pm
by cosmith71
lnevo wrote:I meant the update...wasnt sure you updated the first post or not
Not yet, I wanted to test it first. But I will soon.
Posted: Mon Aug 04, 2014 7:47 am
by cosmith71
OP updated with non-apocalyptic timing. It shouldn't set off the watchdog timer and reset the unit anymore. It's also less monopolistic of resources when it's running.
Posted: Mon Aug 04, 2014 2:57 pm
by cosmith71
Also added option for Mega Storm to OP, with lightning throughout the cloud increasing in intensity as the cloud gets darker. Pretty awesome, if I do say so myself!
Posted: Mon Aug 04, 2014 3:38 pm
Colin, any chance you can integrate the "mini" storm (non-fast/responsive drivers) so i have one cloud function to work on? I'm going to add high resolution dimming and potentially turn this into a class for ease of use/configuration.
Posted: Mon Aug 04, 2014 3:39 pm
Oh and btw, that sounds AWESOME!!!
Posted: Mon Aug 04, 2014 4:27 pm
by 89delta
Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
Posted: Mon Aug 04, 2014 5:15 pm
We should add an array of storm types you want and randomize between them.
sometimes mega, sometimes mini, could even simulate a storm coming in. Where is Jon, time to start talking about the audio out he has again...
Posted: Mon Aug 04, 2014 5:54 pm
by cosmith71
OK, added the slow response lightning to the OP. It's selectable via a variable switch in the checkcloud() routine.
I doubt I would want to run anything but Mega-Storm. It's awesome.
Posted: Mon Aug 04, 2014 5:55 pm
by cosmith71
89delta wrote:Oh wow....just got home from work....added ur update last night but haven't checked the relay state yet for the skimmer.....but the mega storm option sounds wicked.....
I haven't had any issues with overrides with the new code. Even with the Mega-Storm, everything runs smooth with no resets.
Posted: Mon Aug 04, 2014 6:03 pm
by Sacohen
God I can't wait to get my LEE's up and running.
Posted: Mon Aug 04, 2014 6:10 pm
by 89delta
No issues with the relays resetting Colin...Thanks.....but am gonna update the new code tonight. Lnevo....great idea about the storm mode being randomized.
Posted: Tue Aug 05, 2014 4:32 am
Colin,
You left the default as Mega
I added the random selection, you'll just need to set this array to the types of lightning you want:
byte LightningModes[] = { Slow, Fast, Mega };
Once you set that, each cloud should have a unique lightning type. If you just want Slow, or Fast you can put one. If you want one more than the others, you can put it multiple times in the array
Need to think a little more how we could combine multiple types of lightning during one cloud episode. I need to actually run the code though too to see how it looks overall
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Add Random Lightning modes
#define Slow 0
#define Fast 1
#define Mega 2
static byte lightningMode=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// Check for lightning. When lightning occurs, it will happen for 5 seconds at the middle of a cloud.
// We will have from 1 to 4 consecutive flashes, then a random delay of up to 1000 ms before another set of flashes.
// This first line basically says: Is there supposed to be lightning? Are we within a 5 second window in the middle
// of the cloud when lightning occurs? Are we not in a delay between sets of flashes? If so, do another round of flashes.
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
switch (lightningMode) {
case Mega:
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
analogWrite(daylightPWMPin, 255); // Flash on
delay(20+random(50)); // Wait from 20 to 69 ms
analogWrite(daylightPWMPin, 0); // Flash off
delay(30+random(20)); // Wait from 30 to 49 ms
break;
case Fast:
break;
case Slow:
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
} else {
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
