No. I have not implemented the COM port communications yet. I've only got the wifi part working with the Status app.
Sorry for the confusion.
How to make some easy modification...
- Contact:
dhave
dhave
Re: How to make some easy modification...
This is arduino code of internal memory:
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(1);
InternalMemory.MHOnMinute_write(0);
InternalMemory.MHOffHour_write(11);
InternalMemory.MHOffMinute_write(0);
InternalMemory.MHDelay_write(0);
InternalMemory.StdLightsOnHour_write(1);
InternalMemory.StdLightsOffHour_write(23);
InternalMemory.StdLightsOffMinute_write(0);
It mean...
HQI, on 01.00, off 11.00, delay 0
Neon, on 01.00, off 23.00, delay 0
Right?
So... i can change time on/off directly here, or use this to set AM/PM correctly.
e.lcd_init();
It mean...
Right?
- Contact:
Yes. Your understanding is correct.
You can use that to set the values. The controller only operates in 24hr mode.
dhave
Done, now time work correctly.
Now, the next problem: if i set °c display, the temperature don't work. I think the problem is the same, as long as i can set on/on point only in °f (also if i'm using °c).
InternalMemory.HeaterTempOn_write(761);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(797);
InternalMemory.ChillerTempOff_write(788);
I will set °c and change these value, right?
Yes, you can set to celsius and change those values. Should work that way.
dhave
Just one more question about the ATO setting...
I'm using two sensor:
1) sump water level, with on/off on re-fill pump
2) re-fill water tank, that should turn on a red ligh to inform me that osmotic water is nearly finished.
My problem is that I've not understand how to remove the ATO time-out on the second sensor, vause i need to keep the light on. I've try to put 0 or 600, nut nothing change, after one minute it turn off.
In future if it work, i will install an electric shutoff valve tha open/clon osmotic plant.
I'm not picturing how your setup is.
Can you explain a little better?
Is it one float switch on sump and another in water container?
Then you have an ATO pump inside this water container.
The float switch in the sump controls the ATO pump and the other does what?
Which ATO function are you using?
dhave
