Re: How to make some easy modification...
Posted: Thu Dec 22, 2011 3:58 pm
No. I have not implemented the COM port communications yet. I've only got the wifi part working with the Status app.
Sorry for the confusion.
Posted: Thu Dec 22, 2011 3:59 pm
by dhave
I've try tu use the RA client, no AM/PM value shown...
Posted: Thu Dec 22, 2011 5:02 pm
by dhave
This is arduino code of internal memory:
e.lcd_init();
e.lcd_clear(COLOR_WHITE,0,0,132,132);
e.lcd_BacklightOn();
InternalMemory.MHOnHour_write(1);
InternalMemory.MHOffHour_write(11);
InternalMemory.MHDelay_write(0);
InternalMemory.StdLightsOnHour_write(1);
InternalMemory.StdLightsOffHour_write(23);
It mean...
HQI, on 01.00, off 11.00, delay 0
Neon, on 01.00, off 23.00, delay 0
Right?
So... i can change time on/off directly here, or use this to set AM/PM correctly.
Posted: Thu Dec 22, 2011 5:26 pm
Yes. Your understanding is correct.
You can use that to set the values. The controller only operates in 24hr mode.
Posted: Fri Dec 23, 2011 11:23 am
by dhave
Done, now time work correctly.
Now, the next problem: if i set °c display, the temperature don't work. I think the problem is the same, as long as i can set on/on point only in °f (also if i'm using °c).
InternalMemory.HeaterTempOn_write(761);
InternalMemory.HeaterTempOff_write(770);
InternalMemory.ChillerTempOn_write(797);
InternalMemory.ChillerTempOff_write(788);
I will set °c and change these value, right?
Posted: Fri Dec 23, 2011 12:16 pm
Yes, you can set to celsius and change those values. Should work that way.
Posted: Mon Dec 26, 2011 6:21 am
by dhave
Just one more question about the ATO setting...
I'm using two sensor:
1) sump water level, with on/off on re-fill pump
2) re-fill water tank, that should turn on a red ligh to inform me that osmotic water is nearly finished.
My problem is that I've not understand how to remove the ATO time-out on the second sensor, vause i need to keep the light on. I've try to put 0 or 600, nut nothing change, after one minute it turn off.
In future if it work, i will install an electric shutoff valve tha open/clon osmotic plant.
Posted: Mon Dec 26, 2011 9:34 am
I'm not picturing how your setup is.
Can you explain a little better?
Is it one float switch on sump and another in water container?
Then you have an ATO pump inside this water container.
The float switch in the sump controls the ATO pump and the other does what?
Which ATO function are you using?
Posted: Mon Dec 26, 2011 6:09 pm
by dhave
I'm using two ATO to contro two different water level.
Menatime I've solved the probem: i have found the flag to disable ATO time out. :lol:
