Ok, this should do it. I've set the min speed to 1/2 the Tidal speed and used the Tidal speed as the max speed. As discussed the tidal speed will vary +/- depending on the range you gave which means 55 (+/-5 during quarter moons and half moon, versus +/-15 during newmoon and full moon) It will also vary throughout the day based on the wavelength you have set.. which is currently 72 minutes...   tide.SetWaveLength(12+SECS_PER_HOUR); The default is 12 hours which would be 12*SECS_PER_HOUR. Anyway below is the code that will set the Actinic/Daylight to the value of the the setMaxspect function using the tide class as an input. I also included the change I made in your RO/Valve post
#include <Tide.h>
Tide tide;
  ReefAngel.DDNS("Damien");
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port3Bit;
  InternalMemory.WaterLevelMax_write(1800);
  tide.Init(55,10,30);
  ReefAngel.StandardHeater( Port3,780,785 );
  ReefAngel.WaterLevelATO(4,Port4,240,28,31);
  ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
  if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
    ReefAngel.Relay.Override(Port8,0);    //Saltwater Reservoir
  if (ReefAngel.WaterLevel.GetLevel(1)>80)   // Set port back to auto
    ReefAngel.Relay.Override(Port8,2);
  if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.Off(Port5); // Set Default to off
  if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
  if (ReefAngel.WaterLevel.GetLevel(3)<1)
    ReefAngel.Relay.On(Port5);
  ReefAngel.PWM.SetDaylight(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,true)); // Set the Speed
  ReefAngel.PWM.SetActinic(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,false)); // Set the direction - speeds here are irrelevant actually.
  ReefAngel.Portal( "Ismaclst" );
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
  int reverse_speed=0;
  int forward_speed=45;
   // swap between forward and reverse every X seconds
   reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
   if (reverse_speed == 100) {
     // while we are going in reverse increase the speed by 10
     forward_speed = ShortPulseMode(minSpeed+10, maxSpeed+10,ReefAngel.DCPump.Duration,true);
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(minSpeed,maxSpeed, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
    return forward_speed;
    return reverse_speed;
