Page 1 of 2
				Re: Icecap Module
				Posted: Tue Mar 01, 2016 3:51 pm
				by Ismaclst
				rimai wrote:Ismaclst wrote:I have the maxspect gyre and was thinking about purchasing the Icecap module to go with it.  Has anyone else bought this?  Does it come with the cable you need to connect to the RA?  I'm assuming you can use any  of the DC pump modes?
You should be able to use the DCPump modes.
The Kessil cable in the webstore should be able to be used with the Icecap module too
How long is the Kessil cable?  My RA is in the basement so it needs to be a decent length.
				Re: Icecap Module
				Posted: Tue Mar 01, 2016 4:01 pm
				Won't reach.
It's about 6ft.
You better off just splicing your own cable. You can build one from scratch or get an stereo audio cable at the local store than is long enough.
				Re: Icecap Module
				Posted: Tue Mar 01, 2016 5:03 pm
				He way I wrote the function I added 10 to the speed for reverse and forward uses the values you provide.
				Re: Icecap Module
				Posted: Tue Mar 01, 2016 5:42 pm
				by Ismaclst
				What do all three of these numbers mean?
				Re: Icecap Module
				Posted: Tue Mar 01, 2016 8:42 pm
				40 speed, 35-45 during 1/4 moons and 25-55 during new and full moon. It might be
				Re: Icecap Module
				Posted: Wed Mar 02, 2016 5:03 pm
				by Ismaclst
				Sorry for all the questions, but I'm still confused on how you got 35-45 and 25-55?  I can't seem to find the correlation between those numbers and the 40, 10 and 30 ones.
				Re: Icecap Module
				Posted: Wed Mar 02, 2016 8:08 pm
				40 is the speed for the tide. As it goes from high tide to low tide its going to start at a range of 10 so 35-45 between the high tide and low tide speed. As the month progresses the range will increase to 3 which is 25-55.
				Re: Icecap Module
				Posted: Wed Mar 02, 2016 8:10 pm
				Re: Icecap Module
				Posted: Fri Mar 04, 2016 5:10 pm
				by Ismaclst
				Ok, I understand now.  I don't have the icecap module yet but I wanted to upload the code so it was ready when I did get it.  I noticed that  both the daylight and actnitic values didn't change when I uploaded the new code.  Should they? I did notice that where it says dc pump in the portal, that it shows that the mode is constant, speed is 50% and duration is 50.
				Re: Icecap Module
				Posted: Sat Mar 05, 2016 4:51 pm
				Can you post your new code?
				Re: Icecap Module
				Posted: Sat Mar 05, 2016 5:54 pm
				by Ismaclst
				Here is my latest code:
#include <Tide.h>
Tide tide;
  ReefAngel.DDNS("Damien");
  ReefAngel.AddMultiChannelWaterLevelExpansion();  // Multi-Channel Water Level Expanion Module
  ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port3Bit;
  ReefAngel.Relay.Set(Port8, now()%6*SECS_PER_HOUR<30*SECS_PER_MIN);
  InternalMemory.WaterLevelMax_write(1800);
  tide.Init(55,10,30);
  tide.SetWaveLength(12+SECS_PER_HOUR);
  ReefAngel.StandardHeater( Port3,780,785 );
  ReefAngel.WaterLevelATO(4,Port4,240,28,31);
  if (ReefAngel.WaterLevel.GetLevel(1)<5) //Disable the port until overriden manually
    ReefAngel.Relay.Override(Port8,0);    //Saltwater Reservoir
  if (ReefAngel.WaterLevel.GetLevel(1)>80)   // Set port back to auto
    ReefAngel.Relay.Override(Port8,2);
  if (ReefAngel.WaterLevel.GetLevel(2)>80) //Overflow
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.On(Port1);
  if (ReefAngel.WaterLevel.GetLevel(3)>87) //ATO Reservoir
    ReefAngel.Relay.Off(Port5);
  if (ReefAngel.WaterLevel.GetLevel(3)<1)
    ReefAngel.Relay.On(Port5);
  ReefAngel.Portal( "Ismaclst" );
byte setMaxspect(byte minSpeed, byte maxSpeed, boolean PulseSync)
  int reverse_speed=0;
  int forward_speed=45;
   // swap between forward and reverse every X seconds
   reverse_speed = ShortPulseMode(0,100,ReefAngel.DCPump.Duration*2,true);
   if (reverse_speed == 100) {
     // while we are going in reverse increase the speed by 10
     forward_speed = ShortPulseMode(35+10, 60+10,ReefAngel.DCPump.Duration,true);
   } else {
     // while we are going forward set speed to 25-40 to keep
     // from blowing corals off the rocks
     forward_speed = ShortPulseMode(35,70, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
    return forward_speed;
  } else {
    return reverse_speed;
				Re: Icecap Module
				Posted: Sun Mar 06, 2016 12:54 pm
				You added the function but you have to call it. Same with the tide you set. We have to tie them together now.
You need to add the following now to set your dimming channels.
I need to be on the computer to give you the right code. I also made some mistakes that I need to fix in the setMaspect function.
				Re: Icecap Module
				Posted: Tue Mar 08, 2016 1:58 pm
				by Ismaclst
				I bought a stereo audio cable for forward and reverse.  How many wires should be in it?  I cut the end off and there are three, a red, blue and white.
				Re: Icecap Module
				Posted: Tue Mar 08, 2016 6:02 pm
				One should be ground and the other two would be for your two signals. If you are wiring to the dimming leads you'll share the ground.
				Re: Icecap Module
				Posted: Tue Mar 08, 2016 6:28 pm
				by Ismaclst
				lnevo wrote:You added the function but you have to call it. Same with the tide you set. We have to tie them together now.
Did you ever get a chance to look into this more?
				Re: Icecap Module
				Posted: Tue Mar 08, 2016 7:30 pm
				No, i got swamped this weeken. I'll probably have a chance friday if you can hang in...
				Re: Icecap Module
				Posted: Wed Mar 09, 2016 1:44 am
				by Ismaclst
				No problem
				Re: Icecap Module
				Posted: Sun Mar 20, 2016 7:44 am
				Ok, this should do it. I've set the min speed to 1/2 the Tidal speed and used the Tidal speed as the max speed. As discussed the tidal speed will vary +/- depending on the range you gave which means 55 (+/-5 during quarter moons and half moon, versus +/-15 during newmoon and full moon) It will also vary throughout the day based on the wavelength you have set.. which is currently 72 minutes...   tide.SetWaveLength(12+SECS_PER_HOUR); The default is 12 hours which would be 12*SECS_PER_HOUR. Anyway below is the code that will set the Actinic/Daylight to the value of the the setMaxspect function using the tide class as an input. I also included the change I made in your RO/Valve post
#include <Tide.h>
Tide tide;
  ReefAngel.Relay.Set(Port8, (now()%(6*SECS_PER_HOUR))<(30*SECS_PER_MIN));
  ReefAngel.Relay.Off(Port5); // Set Default to off
  ReefAngel.PWM.SetDaylight(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,true)); // Set the Speed
  ReefAngel.PWM.SetActinic(setMaxspect(tide.GetSpeed(),tide.GetSpeed()/2,false)); // Set the direction - speeds here are irrelevant actually.
     forward_speed = ShortPulseMode(minSpeed+10, maxSpeed+10,ReefAngel.DCPump.Duration,true);
   } else {
     forward_speed = ShortPulseMode(minSpeed,maxSpeed, ReefAngel.DCPump.Duration, true);
  if (PulseSync) {
  } else {
				Re: Icecap Module
				Posted: Sun Mar 20, 2016 10:59 am
				by Ismaclst
				Thanks for taking the time and correcting my code.  I appreciate it.
				Re: Icecap Module
				Posted: Fri Feb 10, 2017 12:42 pm
				by slm222
				I know this is an old thread. But I wanted to check before moving forward. Icecap just came out with their gyre pump as a license off maxspect. If i get their gyre pump and the ice cap module will this work with the DC pump codes? i current have two jeabo but would like to swap out to two opposing gyres. I have the jebaos set up to randomly select the wave pattern for the day. would this still be relevant for the gyre control? along with feed mode?
				Re: Icecap Module
				Posted: Fri Feb 10, 2017 5:07 pm
				I don't see why not.
It should work just the same.
