Page 8 of 9
Re: PaulTurner911 Code
Posted: Tue Nov 04, 2014 4:53 pm
by Paulturner911
I decided to keep my code and change a few relays and make it work for the most part. I have the following questions:
Chiller will now be on port 2. It has a 2 deg variance, if I want the tank at 78 i would set this to 80?
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
Wouldnt it then turn the chiller off when it goes to 79?
Skimmer is on port 6- Does shut off in feedmode , but I would like this to have a 2 hour delay after feed mode. How would i code this?
Thanks guys!
Posted: Wed Nov 05, 2014 5:36 am
No that code is for screen drawing. Post your code and I'll be able to help
Posted: Wed Nov 05, 2014 6:56 pm
by Paulturner911
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts = Port3Bit | Port7Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port6Bit | Port7Bit ;
ReefAngel.DayLights( Port1 ); // Return Pump
//Port 2 Chiller
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
//Port4 Kalk/ATO
//Port5 Kalk Stir
ReefAngel.DayLights( Port6 );// Skimmer
ReefAngel.DayLights( Port7 ); // White LEDS
//Port8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 5,(0) );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port4);
//Kalk Dose 60sec @ 11pm-12pm (every 15min)
if (hour() >=23 || hour() < 12)
ReefAngel.Relay.Set(Port4, now()%900<65);
//Kalk Stir 12pm-1pm
if (hour() >=12 & hour() < 13)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Off(Port5);
///// Place your custom code below here
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { Else, Lagoon, Else, ReefCrest, ShortPulse, LongPulse, NutrientTransport };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Return Pump is off
// First 15 minutes after feeding mode stops. Smart_NTM
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
} else {
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Posted: Thu Nov 06, 2014 8:33 am
by Paulturner911
I've noticed that the skimmer (port6) is functioning like the old mh ports 7/8 as far as off and on schedule.
Is like this to run 24/7 unless water change or feed mode has been activated.
Posted: Thu Nov 06, 2014 8:52 am
by Sacohen
Port 6 is included in Feeding, Water Change and Overheating off.
You also have it as Always on.
The one line of code that refers to Port 6 that I see has no time associated to it.
it just this...
Posted: Thu Nov 06, 2014 10:16 am
by Paulturner911
Port 6 definatly does not run 24/7
It does shut off for WC and feed mode correct.
I would like it to stay off for 2 hours after either.
What should it read? It's currently shitting down with the "daylight" LEDs.
Thank you
Posted: Thu Nov 06, 2014 12:47 pm
by Sacohen
I think it has to do with this ReefAngel.DayLights( Port6 );// Skimmer
Just remove this line ReefAngel.DayLights( Port6 );// Skimmer and it should stay on all the time except Feeding, Water Change and Overheat because of this...
You can probably remove i the Port6Bit from the Overheat as well, you don't need to turn off the skimmer during an overheat situation.
Posted: Thu Nov 06, 2014 4:19 pm
He wanted a delay so use DelayedOn instead of On and put 120 as the second argument for 2 hours.
Posted: Thu Nov 06, 2014 5:55 pm
by Paulturner911
ReefAngel.Relay.DelayedOn( Port6 );120;
will this work?
Posted: Thu Nov 06, 2014 8:36 pm
ReefAngel.Relay.DelayedOn(Port6, 120);
Posted: Sat Nov 08, 2014 5:59 am
by Paulturner911
Thanks! here is my current code
ReefAngel.Relay.DelayedOn( Port6,120 );
//Port 2 Chiller
//Port4 Kalk/ATO
//Port5 Kalk Stir
//Port6 Skimmer
//Port8 Empty
//ATO Protection
ReefAngel.Relay.Set(Port4, now()%900<60);
static int rmode;
const int Else=16;
changeMode=false;
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
The skimmer is still running the schedule of my white leds (old MH Port)
Posted: Sat Nov 08, 2014 1:21 pm
That needs to be inside loop with the other ports. Otherwise from what I can see it would just stay off...but definitely wouldn't be doing what it's designed to do.
Posted: Mon Nov 10, 2014 9:49 am
by Paulturner911
THANK YOU!
I HAVE NOTICED THAT THERE ARE NEW MODES ON THE PORTAL FOR THE JAEBO.
HOW WOULD I ADD THESE TO THE RANDOM FUNCTION?
DO I ADD THE NAMES IN HERE-
WRITE THEM EXACTLY AS THE LIST IN THE PORTAL MODES? IS THERE A BRIEF DESCRIPTION OF THE MODES ANYWHERE?
Posted: Mon Nov 10, 2014 9:57 am
by Sacohen
Yes, just write them as listed in the portal.
This is how I have them in my code...
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
Really the only new ones are SineMode, Else and Gyre.
Else is a very random flow that emulates the Else mode of the Jebao pumps.
lnevo wrote:A gyre is like when you create a whirlpool in a swimming pool. At some point the momentum builds up and it has a strength of its own. The idea is one run pump in constant for x amount then switch the gyre into another direction.
AlanM wrote:Gyre is just like Long Pulse but with round edges. So it ramps up and back down while the opposing pump is off and then switches. The "duration" argument is in minutes, btw, not seconds, to support longer than 4 minutes. Since "Duration" is a byte number if it was in seconds it would overflow at 255 seconds.
I don't use SineMode it seems to mechanical to me.
Posted: Mon Nov 10, 2014 10:14 am
You will need the dev libraries to use the new modes.
Posted: Mon Nov 10, 2014 10:19 am
by Sacohen
That's correct. I've been using then for a while now and forgot that they were still only in the dev libraries.
Posted: Sun Nov 16, 2014 5:37 pm
by Paulturner911
i havent done anything with the dev libs.
My custom wave mode called "Else" today but stayed at 30% all day. Portal showed else, 70% duration 20...
what wouldnt ti be like reef crest or lagoon mode?
Posted: Fri Dec 12, 2014 6:19 pm
by Paulturner911
Its been getting cold here and I decided to get a heater. I would like to have it on relay port 2 and only come on if the tank is below 74. Could someone please help code this?
//Port 2 Heater
//Port4 Kalk/ATO
//Port5 Empty
ReefAngel.Relay.DelayedOn( Port6,120 );//Port6 Skimmer
//Port8 Empty
//ATO Protection
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre, NutrientTransport };
changeMode=false;
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
I think this is my most current code! Thanks
Posted: Sat Dec 13, 2014 5:23 am
What temp do you want it to go off at? 74 is a bit low though, no?
Posted: Sat Dec 13, 2014 9:53 am
by Paulturner911
I would like it to turn on at 74 and off at 76. I never though I would need a heater here. My last tank had halides and would keep it just under 80. Now I have a chiller, that I run stand alone at 78, and the heater i want on the RA at 75. I want the heater on the RA for failure protection in case it locks ON when it fails, and it will... They both have a +/- 2deg so I assume another degree or two buffer to keep them from cycling each other. Any and all help is appreciated!
Posted: Sat Dec 13, 2014 10:14 am
ReefAngel.StandardHeater(Port2,74,76);
Posted: Sat Dec 13, 2014 10:58 am
by Paulturner911
I put it below void loop, it didnt activate after upload. Should I have it below void setup? I also changed it to 75
**Put it in both and it still hadnt turned the heater on.
I lost one of my codes and modified the second most recent but also update the libs. I could use a set of eyes on my current code. I think i put everything back and removed the ELSE definition because its in the libs now and was giving an error.
ReefAngel.OverheatShutoffPorts = Port1Bit |Port2Bit | Port3Bit | Port6Bit | Port7Bit ;
// Heater (75-76)
ReefAngel.StandardHeater(Port2,75,76);
ReefAngel.Relay.DelayedOn( Port1,1 ); // Return Pump
//Port 2 Heater (75-76)
//Port4 Kalk/ATO
//Port5 Empty
//Port8 Empty
//ATO Protection
static int rmode;
changeMode=false;
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Thank you!!
Posted: Sat Dec 13, 2014 12:31 pm
The temp in your tank is 76.2 it won't go on until it drops below 75.
Posted: Sun Dec 14, 2014 6:42 am
by Paulturner911
I checked the relay activity, it didnt activate port 2. I woke up and took it off the RA and plugged it in to a power strip and cranked the house heater.
Please help
Posted: Sun Dec 14, 2014 7:10 am
Where'd you put it in the code? Can you post again?
Posted: Sun Dec 14, 2014 7:13 am
Actually your code looks fine. Not sure why its not on. Are you sure you loaded the code above?
Posted: Sun Dec 14, 2014 7:43 am
by Paulturner911
I have the code in both viod setup and viod loop, i was not sure where to put it, it compiles fine in both locations within the code.
This whats on there, uploaded it once with 74 as the activation, then 75. My chiller and RA are pretty far off on calibration. Ill throw a third on there to try to get an average and set the chillers correction factor. Ill upload it again and triple check.
// Heater (75-76)
//Port4 Kalk/ATO
//Port5 Empty
//Port8 Empty
//ATO Protection
static int rmode;
changeMode=false;
} else {
} else {
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Its uploading without any issues... Port 2 is still not on
Something in my code conflicting? Could it have to do with the internal memory setting in the portal? I have assigned temps to them , but how would they know the ports for the chiller and heater?
Could or should I run the wizard again and cut my code in?
Posted: Sun Dec 14, 2014 10:15 am
The internal memory is not used with the command i gave you.
For now i recommend just manually tirn the port on and rely on the heater thermostat plus you have the chiller. I'm not sure why its not working. It should also be in loop not setup.
Posted: Mon Dec 15, 2014 12:55 pm
by Paulturner911
Ok, Ill remove it from the void setup section.
I would really like to have this functioning properly in the near future? What can I do to help troubleshoot? Can i confirm the file on the RA? Like I said, it should give an error if the RA was not taking the code, its uploading fine all around.
Posted: Mon Dec 15, 2014 1:02 pm
Maybe Roberto could take a look. I dont have an extra probe I can test with at the moment but I don't see anything wrong. I'll try and take another look later tonight.
