How to setup your wifi attachment
sophie10
Re: How to setup your wifi attachment
Post by sophie10 »
rimai wrote:The preloaded code is not customized.
You need to generate a code with the wizard to be able to customize your controller to you and add your forum integration.
Otherwise the controller doesn't send information to the portal.
Hi Roberto, I used the wizard (slick!), and used my 192.168.0.11 for the ddns, and I found my info on the portal (see below)! Everything looks fine, except the connection status shows 'unreachable address', is the norm? The data is accurate!
sophie10
Post by sophie10 »
Uh oh, While I see my system in the portal, I notice that while the temp and pH are accurate, the the range is wrong. It only has data to 12/26, but the last update was 12/29 at 9:41 (just did one). I also can no longer access my RA from within my own WIFI using 192.162.0.11:2000/WIFI. What did I do?
The path is case sensitive. Sorry.
Also, your address seems wrong. Usually, they are 192.168 and not 192.162 on most routers.
It needs to be http://192.168.0.11:2000/wifi
Also, in order for the portal to connect to your controller, that's when port forwarding comes in.
By default, all routers block any external access to inside your wifi network. That's what they are designed for. It's called firewall.
So, the portal has no way to access your controller.
Port forwarding allows a specific port to be forwarded to a specific ip address, which will allow external connections to reach your controller.
You need to setup your router for port forwarding. It needs to forward port 2000 to your RA ip address 192.168.0.11
sophie10
Post by sophie10 »
Can you check my status on the portal Roberto? Attached is an image of the status. I think I have everything set right. I get live reports when I access from within and outside my LAN, but I don't have historical data. The iPhone app the same - current data, but nothing after Jan 2. Thank you.
Can you send us the "get e" dump from the wifi attachment?
The new server is operational, so there may be something else.
sophie10
Post by sophie10 »
OK, thank you. I may not know how to do that... :/ But will investigate!
Look at this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=6337
Basically, you need to connect to the COM port at 57600 baud and type $$$ to enter command mode.
Then type get e.
