Page 9 of 9
Re: PaulTurner911 Code
Posted: Mon Dec 15, 2014 1:25 pm
by Paulturner911
I found my temp probe was out of the water in the sump, but it still should have activated anytime under 75, which it didnt.
This also "fixed" the calibration "issues" between the RA and the chiller, since the probe was in and out of the water level. Dumb mistake, but still doesnt justify it not turning on under 75. Thank you Lee
Could it have something to do with the temp probe assignments? In my code it pulls overheat from temp probe 1. You would think thats the trigger, but Im reaching for anything to make it jive in my eyes within the code...
Posted: Mon Dec 15, 2014 2:49 pm
Oh the standard heater only works with the T1 probe. If you cant switch them i'll write you a function
Posted: Mon Dec 15, 2014 3:31 pm
by Paulturner911
T1 IS the probe in the sump, T2 is in the stand basically ambient temp.... I can switch them, but why?
Posted: Mon Dec 15, 2014 4:06 pm
Nevermind was hoping that was it. Roberto can you check the code. I need some more eyes on it.
Posted: Mon Dec 15, 2014 4:29 pm
It should be this:
ReefAngel.StandardHeater(Port2,750,760);
instead of this:
ReefAngel.StandardHeater(Port2,75,76);
Posted: Mon Dec 15, 2014 5:21 pm
by Paulturner911
You rock!!
Posted: Mon Dec 15, 2014 5:35 pm
I'm so slow...
Posted: Mon Dec 15, 2014 6:08 pm
by Paulturner911
Lee!! You've walked me through EVERYTHING! You're the man!!
Posted: Mon Dec 15, 2014 6:24 pm
Do you think if we convert the function that if the values are less than 100 we multiply by 10 automatically? I don't think anyone is going to want 2.4 degrees to 2.6 degrees celsius in any aquarium, nor do we want 7.5 -7.8, etc.
Also, I think we could add a StandardHeater2 or a StandardHeater function with an arg for the temp probe? What do you think?
Posted: Mon Dec 15, 2014 6:48 pm
That works
Posted: Wed Dec 24, 2014 10:38 am
Patch submitted. There's now functions for StandardHeater2 and StandardHeater3 same for StandardFan. And if you pass a temp param less than 100 it will be multiplied by 10.
Posted: Sat Mar 07, 2015 10:47 am
by Paulturner911
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit ;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit ;
ReefAngel.LightsOnPorts = Port7Bit | Port3Bit ;
ReefAngel.OverheatShutoffPorts = Port1Bit |Port2Bit | Port3Bit | Port5Bit| Port6Bit | Port7Bit| Port8Bit ;
ReefAngel.Relay.DelayedOn( Port1,1 ); // Return Pump
ReefAngel.Relay.DelayedOn( Port2,90 );// Skimmer
ReefAngel.ActinicLights( Port3 ); // Actinic LEDS
ReefAngel.StandardFan(Port4,790,800);//Chiller 79-80
ReefAngel.StandardHeater(Port5,750,760);//Heater 75-76
//Port6 Kalk/ATO
ReefAngel.DayLights( Port7 ); // White LEDS
//Port 8 Empty
//Moonlight Phase 9pm-10am (CH4-CH5)
if ( (hour() >=10) && (hour() <21) )
ReefAngel.PWM.SetChannel( 4,(0) );
ReefAngel.PWM.SetChannel( 4, MoonPhase() );
ReefAngel.PWM.SetChannel( 5,(0) );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
//Over Flow Protection
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.Off(Port1);
//ATO Protection
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port6);
//Kalk Dose 10pm-11pm
if (hour() >=22 || hour() < 23)
///// Place your custom code below here
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { Else, Lagoon, ReefCrest, ShortPulse, LongPulse, Gyre, NutrientTransport };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<900) {
// First 15 minutes after feeding mode stops. Return Pump is off
// First 15 minutes after feeding mode stops. Smart_NTM
ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()-feeding<4500) { // 15 minutes plus 1 hour
// Continue NTM for the next 60 minutes (75 minutes total)
} else if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY>=81000) { // 8:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
if (modes[rmode]==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true ); // ElseMode on sync mode, Portal Speed Setting +/- 25%
} else {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "paulturner911" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
// Date and Time
I coded this and the ATO should only run from 10pm-11pm in my eyes. BUT, It doesnt seem to function correctly since I just uploaded and its 12.45pm and Port6 is ON. Any help would be great.
Posted: Sat Mar 07, 2015 11:25 am
Change the || to &&
Posted: Sat Mar 07, 2015 2:46 pm
by Paulturner911
Thank You!!
Posted: Sun Jun 14, 2015 11:16 am
by Paulturner911
Any idea what kind of run time I should get with two pumps on the Jeabo battery backup kit...??
Posted: Mon Nov 02, 2020 6:36 pm
by Paulturner911
Hi guys! Its been ages since Ive messed with the tank and/or this program. My skimmer is returning very light product. I think I want it to run every other day.
Skimmer is Port 2. How could I code that?
Thank you in advance!
Posted: Tue Nov 03, 2020 8:37 am
Replace this:
with this:
if (day()%2==0)
Posted: Tue Nov 03, 2020 7:49 pm
by Paulturner911
Thanks for the reply Roberto. Im not sure that will do what I want. Pump 1 is my return pump, I would like my skimmer to run for 24hr on and 24hr off, but still turn off when I use the feed mode.
Posted: Tue Nov 03, 2020 8:46 pm
Duh... Misread the post. I read Port 1
I'll send code later. Typing on phone....
Posted: Thu Nov 05, 2020 7:28 am
Replace this:
With this:
if (day()%2==0)
ReefAngel.Relay.Off(Port2);
Posted: Thu Oct 13, 2022 7:00 pm
by Paulturner911
Does anyone have a display menu that is capable of togging the main relay board ports?
New streamlined code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit;
InternalMemory.OverheatTemp_write( 896 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.DelayedOn( Port5,5 );
ReefAngel.Portal( "Paulturner911" );
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Posted: Wed Oct 19, 2022 5:00 am
by howaboutme
Paulturner911 wrote:Does anyone have a display menu that is capable of togging the main relay board ports?
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Do you mean naming the ports? My code does that:
https://forum.reefangel.com/viewtopic.php?f=11&t=4662
Posted: Thu Oct 20, 2022 3:26 pm
by Paulturner911
I want to be able to turn them on and off from the actual controller joystick.
I also want a fail safe that if the PORT 1 is OFF, it turns off PORT 2 and PORT 5.
Long story short, my app doesn't work reliably, and I don't want to have to sign in to the portal to turn something off or on. I can see the controller anytime on the portal, but the app is random and will not connect if I want it to, but hours later it will toggle the ports I've fiddled with in the app. Then you come home to a pump turned off and a overflowed skimmer and a filter roller that wasted 20' of roll. SUCKS
Any help would be great. Thank you
Posted: Mon Oct 31, 2022 12:06 pm
by Paulturner911
I created this with the cloud wizard.
I'm having an issue where my skimmer is overflowing because the return pump is off. I made a if/then to turn off the skimmer and filter roller off if the return pump is ever off. This doesn't seem to work.
ReefAngel.Relay.DelayedOn( Port2,10 );
ReefAngel.Relay.DelayedOn( Port5,10 );
ReefAngel.PWM.SetChannel( 4,MoonPhase() );
if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port2 );
if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.Off( Port5 );
if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.DelayedOn( Port2,10 );
if ( ReefAngel.Relay.Status( Port1 ) ) ReefAngel.Relay.DelayedOn( Port5,10 );
ReefAngel.CloudPortal();
// RA_STRING1=U2FsdGVkX1+wzokeKHQCk87w7JvvcOREK6+LjmUjNMc=
// RA_STRING2=U2FsdGVkX19g+eSJzWd3/2eYdbXZT5v3evtlYFIGeqE=
// RA_STRING3=Nacho Network
// RA_LABEL LABEL_DAYLIGHT=Not Used
// RA_LABEL LABEL_ACTINIC=Not Used
