Page 10 of 14
JEBO WP-40
Posted: Fri May 17, 2013 5:38 am
bhazard wrote:Had a little trouble with the wifi module at first, but got it up and running. I can't update the firmware through the wifi utility though, so it is either the newest firmware, or something else needs to be fixed.
I'm loving the Reef Angel way more than the Apex already. Built in ATO is a nice touch, and I can get rid of my Avast top off.
There is a post somewhere about the new firmware and modules...it's like a two step process now or something like that....
If you have the avast pressure switch, you can wire that to one of the ato ports and still have a pressure switch in lieu of a float. Can then use the float for backup. And you could still use both floats...
I have my two float switches wired in parallel doing different things connected to one ato port. The higher one watches my sump for an overflow (and doubles as a salt water ato during water changes) and the lower one alarms if my sump is running too low and my pump may cavitate soon.
Just some food for thought...
Re: JEBO WP-40
Posted: Fri May 17, 2013 6:02 am
by bhazard
The Avast kit has an Apex digital connector. Could I cut it to expose the bare wire, and then is there a link I can purchase the cable end similar to what is on the end of the RA float switches?
Of all things, I had everything up and running, and I forgot where I stored my Jebao cables! Just running the pump normally for now. Was so disappointed. Hopefully I can find them tonight.
Re: JEBO WP-40
Posted: Fri May 17, 2013 6:29 am
by Sacohen
Bhazard;
Where can you get the ends that are on the RA float switches?
PM me if you don't want to put the link in the thread or at least give me the name of them and I can look it up. I just don't know what they are called.
I'm looking for the 3 like the ATO switch and the 2 like on the dimming or temp probe.
JEBO WP-40
Posted: Fri May 17, 2013 7:11 am
They might be the same as the dimming ports. Those are in the store. I'm sure if its different Roberto can supply them.
Re: JEBO WP-40
Posted: Fri May 17, 2013 7:58 am
ATO and dimming ports are the same. You can get them in the webstore.
Re: JEBO WP-40
Posted: Fri May 17, 2013 8:14 am
by Sacohen
Thanks.
What about the Temp port?
The 3 port female plug.
Re: JEBO WP-40
Posted: Fri May 17, 2013 8:24 am
I don't have those, but you could get the temperature probe extension and cut it.
Re: JEBO WP-40
Posted: Fri May 17, 2013 9:38 am
by Sacohen
Are they just PC fan connectors?
Re: JEBO WP-40
Posted: Fri May 17, 2013 9:54 am
yes.. same ones
Re: JEBO WP-40
Posted: Fri May 17, 2013 9:58 am
by Sacohen
Thanks.
Re: JEBO WP-40
Posted: Fri May 17, 2013 3:28 pm
by paulvisco
moddiy dot com
Vendor Product ID : c_prod_1
Product Description : modDIY Female 3-Pin Fan Connector (Molex #2510) with Pins
Product Name : modDIY Female 3-Pin Fan Connector (Molex #2510) with Pins
Vendor Product ID : c_prod_3
Product Description : modDIY Male 3-Pin Fan Extension Connector (Molex #2510) with Pins
Product Name : modDIY Male 3-Pin Fan Extension Connector (Molex #2510) with Pins
Vendor Product ID : c_prod_2
Product Description : modDIY Female 2-Pin Fan Connector (Molex #2510) with Pins
Product Name : modDIY Female 2-Pin Fan Connector (Molex #2510) with Pins
Vendor Product ID : c_prod_7
Product Description : Shielded 4-Wire USB 2.0 Cable Wire (UL2547-24A/4C) - Black
Product Name : Shielded 4-Wire USB 2.0 Cable Wire (UL2547-24A/4C) - Black
These are the crip connectors so you will need the crip tool as well. The time to make a single temp probe extention cable is rather painfull but it can be done
The costs on the fan connectors is very good and shipping to CA was not too bad.
Re: JEBO WP-40
Posted: Fri May 17, 2013 4:45 pm
by Sacohen
Thanks.
Re: JEBO WP-40
Posted: Sat May 18, 2013 4:27 pm
by bhazard
What are some recommended durations for some of these modes? I've been unable to make a wave with short pulse and NT mode.
Re: JEBO WP-40
Posted: Mon May 20, 2013 7:33 am
by bhazard
Something just doesn't seem right with the Vortech modes. I added Jimmy's case code after using the RA Wizard, and the modes just don't seem to be working as intended.
Unless I am getting the speed/durations wrong in the portal, I'm not sure what the issue could be aside from modifying the code. Pulse modes like short pulse just seem to ramp up and down way too fast to make a wave. NTM doesnt really ramp, reef crest doesn't really change speed very often.. etc.
I copied Jimmy's code exact and added it to the loop section.
Re: JEBO WP-40
Posted: Mon May 20, 2013 7:56 am
by topjimmy
I think it needs a break at the end, or just get rid of the default, comment it out and see if the modes work. I probably should fix that.
Re: JEBO WP-40
Posted: Mon May 20, 2013 10:28 am
by ReeferBee
I agree Bhazard. I can't get the vortech modes to compare to W1, or else mode from the stock controller.
Re: JEBO WP-40
Posted: Mon May 20, 2013 10:34 am
How can we improve?
Re: JEBO WP-40
Posted: Mon May 20, 2013 11:01 am
by ReeferBee
I'm very new to my RA. I'm sure this is a simple fix within type coding. I liked the randomness of the else mode from the stock controller. It would change speeds very rapidly and create a lot of random turbulence. Quick speed ramps, then slow down, and even some pulse. I'm sure once I understand the code better this wouldn't be an issue.
Re: JEBO WP-40
Posted: Mon May 20, 2013 11:23 am
by Sacohen
Try this code. it something Roberto put together for another person on the forum.
I uploaded it yesterday and it is pretty nice, not as random as the else mode, but good.
rimai wrote:Add this to the end of your code:
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
And call your function like this:
ReefAngel.PWM.SetActinic(MyCustomWave(70));
Re: JEBO WP-40
Posted: Mon May 20, 2013 11:34 am
by ReeferBee
Thanks Steve, I'll give it a shot when I get home this evening.
Re: JEBO WP-40
Posted: Mon May 20, 2013 12:09 pm
by Sacohen
No Problem. Roberto did all the hard work.
I just saw it in another thread and thought I would try it.
The 70% was a little much for my 55 gallon tank so I dropped it to 50%.
binder explained what all the variables mean in post about 1/2 way down the page if you wanted to modify it any.
http://forum.reefangel.com/viewtopic.ph ... 4&start=20
Re: JEBO WP-40
Posted: Tue May 21, 2013 11:33 am
by Sacohen
Just some info.
The first set of WP25's have hit the US.
I should be getting mine by Monday of next week at the latest.
I'll post what I find out about them as it come in.
Re: JEBO WP-40
Posted: Tue May 21, 2013 11:35 am
by rrasco
Lucky for you Steve...macboat wouldn't send me two 25s to test....
Re: JEBO WP-40
Posted: Tue May 21, 2013 2:46 pm
by rrasco
I take that back, mine are on the way.
Re: JEBO WP-40
Posted: Tue May 21, 2013 3:29 pm
by Sacohen
Yeah I saw your ID on the list of ones he was shipping out.
I'm having mine shipped overnight so hopefully I'll get it tomorrow, but FedEx is saying there may be delays because Tornadoes in Oklahoma are causing delays and disruptions.
Re: JEBO WP-40
Posted: Tue May 21, 2013 3:42 pm
by rrasco
Bummer there is no speed control in the controller. Wish I had a way to control them, oh wait, I have a Reef Angel.
I guess that means my idea to design a drop in PCB replacement for their controller might still be viable.
Re: JEBO WP-40
Posted: Wed May 22, 2013 8:22 am
by Sacohen
Mine came to my office this morning.
I'll put them in and take some video when I get home after the son is in bed.
Here are some pictures really nothing new.
The only negative I can see so far is that they went with a wall wart transformer as opposed to the power brick that is on the WP-40.
This will take up more room in a power strip, I think the Reef Angel has plenty of room for this kind of plug, but it doesn't really need to get power from the RA. It can get power from a power strip plugged directly into the wall and then it is controlled speed wise by the dimming port.
It can also be shut off for feeding or water changes by setting the speed to 0%.
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
Still waiting to here back from Wystan about the speed control he told me would be on these.
Re: JEBO WP-40
Posted: Wed May 22, 2013 9:02 am
by ReeferBee
Thanks for the code Steve. it will be nice to free up the two outlets that my wp40's plugged into.
So to include water change I would just add this?
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
Re: JEBO WP-40
Posted: Wed May 22, 2013 9:08 am
by Sacohen
I'm not a coder. I just wrote my first piece of small code the other day and that was the
but that looks correct to me.
I was thinking that I needed to add that to mine too when I posted it here.
Re: JEBO WP-40
Posted: Wed May 22, 2013 5:32 pm
by bhazard
Still haven't found a setting that can make a wave similar to what the Jebao box W1 mode can do. Anyone have a setting that can do this or comes close?
