Page 2 of 2
Re: Problem With WiFi.
Posted: Sat May 05, 2012 8:53 pm
I'm not so sure where the 10. came from if your network is setup to 192.
Posted: Sat May 05, 2012 9:00 pm
by abhi_123
192 series is the IP assigned to devices where as 10 series IP are Dynamic IP provided by ISP
Posted: Sun May 06, 2012 1:35 am
by abhi_123
Finally somehow able to forward the port. Portal & client is working fine.
Thanks roberto & others for their support & patience.
Posted: Sun May 06, 2012 8:13 am
by abhi_123
prob has started again but this time i am able to use client suite but data on portal is not updating.
Posted: Sun May 06, 2012 8:42 am
abhi_123 wrote:prob has started again but this time i am able to use client suite but data on portal is not updating.
What version of the libraries are you using?
Posted: Sun May 06, 2012 9:09 am
by abhi_123
Dev 0.9.6
Posted: Sun May 06, 2012 9:28 am
Did your ip address assigned to you by your isp change?
If it changes, you will need ddns
Sent from my SPH-D700 using Tapatalk 2
Posted: Sun May 06, 2012 10:13 am
by abhi_123
rimai wrote:Did your ip address assigned to you by your isp change?
Yep it changes. It's a dynamic IP. The prob looks like to be solved for now. Will see for ddns if its continue.
Posted: Mon May 07, 2012 10:34 am
by abhi_123
Looks like the prob is sorted completely. Btw here is a link of site which i used for port forwarding quite simple & free too.
www.simpleportforwarding.com
Posted: Tue May 08, 2012 3:57 pm
Thanks for sharing.
I liked this application a lot, except for the part I had to find which router model I had... lol...
But it was very easy to get it to setup my router.
Posted: Wed May 09, 2012 3:27 am
by abhi_123
rimai wrote:Thanks for sharing.
Any time Roberto.
