Re: Low Water cut off
Posted: Sat Apr 12, 2014 11:56 am
Thanks for reply Roberto, Same behavior...nothing happens. I also tried switching the connections, to no avail. The pins on the left are my low water cutoff for the main pump and the pins to the right are my hi water cut off for my skimmer cup. The pins on the right works fine so I tried switching the low water with the high water and the pins on the left and left pins are NG. I can't see how any water would get in their since the unit is mounted high up under the cabinet.
Any suggestions on port repair?
