Re: Need custom code for custom expansion
Posted: Thu Oct 25, 2012 8:42 am
I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
https://forum.reefangel.com/
No I use a NPN transistor TIP-122rimai wrote:I'm also interested on seeing how you are powering the motors. Did you use a mosfet transistor?
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port8,0,60,60 );
ReefAngel.PWM.SetChannel( 0, now()%3600<15?80:0);
ReefAngel.PWM.SetChannel( 1, now()%3600<25?50:0);
ReefAngel.PWM.SetChannel( 2, now()%3600<35?95:0);
ReefAngel.PWM.SetChannel( 3, now()%3600<10?100:0);
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
thank you I'll try to make my own main screen and menu.rimai wrote:I'm assuming you are talking about changing the main screen, right?
http://forum.reefangel.com/viewtopic.php?f=14&t=109
