Page 2 of 2
Re: Resolution of RF Vortech command
Posted: Wed Nov 07, 2012 2:00 pm
by dedvalson
Would you like me to take a look at doing this?
Don
Posted: Fri Nov 09, 2012 10:00 am
I'll try to get something put together over the weekend.
Posted: Sun Nov 11, 2012 12:22 am
Try this one.
Use mode 12 (Short Pulse).
It is still using 8ms resolution.
The minimum pulse is 240ms, which would be duration=30.
Posted: Sun May 19, 2013 8:24 am
by dedvalson
So, more than six months later I finally get back to you on this. Life has been very busy.
Anyway, I downloaded and installed the 1.1 code above and tried running it in Short Pulse mode (12). It appears that it isn't much different from the previous version. The original modes still work fine, but the High Resolution modes (12-14) are sporadic, like we are still missing commands. In mode 12 the Vortech works fine if the duration is set to 30. But if I set it to 31, misses every 5th or 6th cycle.
So it works, but is not regular, it is sporadic.
Don
Posted: Sun May 19, 2013 9:03 am
by dedvalson
It also appears that mode 14 does not work at all. It just turns on and stays on.
Don
Posted: Mon May 20, 2013 10:41 am
Just to try to replicate the same stuff, which libraries version are you running?
Posted: Mon May 20, 2013 1:39 pm
by dedvalson
It looks like 1.0.7.
I can easily change that if it would help.
Don
Posted: Thu May 23, 2013 10:07 am
I did not have time to look into this and test yet, but I'm pretty sure it is because of the Radion integration.
Can you try commenting line 791 on ReefAngel.cpp??
https://github.com/reefangel/Libraries/ ... l.cpp#L791
Posted: Sat May 25, 2013 7:28 am
by dedvalson
You were right. That Fixed Mode 12 (and Probably Mode 13, I didn't test it). But Mode 14 is still totally dead.
This is great, now I can make big waves in the aquarium.
I would love to get 14 going though. If you would like, I can help with that.
Don
Posted: Sat May 25, 2013 9:09 am
14 is long wave. Isn't the original 4 good enough?
It doesn't need the same precision as the 12, right?
I've logged the issue for the Radion integration
https://github.com/reefangel/Libraries/issues/99
Posted: Sat May 25, 2013 2:17 pm
by dedvalson
13 is long pulse, 14 is NTM, at least that is what you had said earlier. I was hoping for an accurate NTM.
Posted: Sat May 25, 2013 3:51 pm
What is the duration you are trying?
Posted: Mon May 27, 2013 7:14 am
by dedvalson
Duration is 68, Speed is 70, Mode is 14.
Posted: Tue Jun 25, 2013 11:08 am
by dedvalson
Any progress on this
Posted: Wed Jun 26, 2013 4:57 am
by dedvalson
If you would like me to, I could look at the firmware for the RF module and see if I can fix this.
Don
Posted: Wed Jun 26, 2013 8:19 am
I'll try to check over the weekend.
Without a RF sniffer, you won't get far
Posted: Fri Jul 05, 2013 3:07 pm
Try this one.
