WIFI set up issues
				civictuner04
Re: WIFI set up issues
if i test connection through the router it doesnt pass
i know the ssid and pass word are correct
				civictuner04
when i go to http://192.168.1.9:2000/wifi
it shows temp ph and lets me control my relay box but nothing ie salinty and led % my apps dont work i thought i had port forwarding setup but i guess i screwed it up
Cool.
It's a start.
Now, make sure you are connected to your wifi and not 3G to get your app to work.
If you want it over 3G, you must get your port forwarding setup correctly.
The internal webserver is very simple and doesn't offer anything else.
Another user is trying to get it updated, but he didn't show us anything yet.
So, you will have to go to the portal for those parameters.
							It's a start.
				civictuner04
OK i used the simple port forwarding download from pcwintech
i clicked on reef angel and a edit port box pops up i put
type: tcp
start port: 1
end port:2000
ip address: 192.168.1.9
is this the right way>???
type: tcp
start port: 1
end port:2000
				civictuner04
Host: ReefAngelWifi
IP Address: 192.168.1.9
Subnet Mask: 255.255.255.0
MAC Address: 00:06:66:30:9e:2a
Network Connection: Bridge
Lease Type: Dynamic
Port Forwarding Services: Destination Ports 2000
Windows Shared Folders: \\192.168.1.9\
DO THESE SETTINGS LOOK RIGHT?
Lease Type: Dynamic
I think so.
Can you test for open port 2000?
Does it say open?
Does it say open?
				civictuner04
nope says closed i wish there was a way you could look in my computer and figure out the problem....lol
				dbmet
				civictuner04
actiontec--------------- verizon fios
				civictuner04
man just checked the portal and it works you sir are the man........
				civictuner04
ok quick update----
ato setup works awesome
new ph probe going strog and much better than other
temp probes working great
the wifi worked great for about a day and a half on portal, and app on 3g and wifi
then weds the app wouldnt connect while i was at work. had my mil reset the r/a no improvements when i got home i unplugged stuff....to reset it to no improvement then randomly it worked for a few hours...then stopped working again.....
i checked the open port tester no connection
i ran the test on the router for it sent 4 packets none returned
it has the green slow blink no blue
				fatman
I had some of the same problems.  This link show some things you can do to get it running.  I've only had it drop off one time in several weeks using this method.
http://forum.reefangel.com/viewtopic.ph ... 1&start=30
I was in a low signal area for mine and added an external antenna, which I believe helped a lot. One time this week I couldn't get the wifi to connect so I rebooted the router and that reopened the port and I was off running again. Can't blame the controller in that case since the router lost the port.
				civictuner04
was your wifi attachment losing signal like blinking blue?
				fatman
I had two issues:
The blinking blue light
A standard blinking green with no connection
After updating the configuration as the thread recommended and putting on the external antenna (make sure to change the configuration to external antenna) I have had to go down once to reboot the module in about two weeks, and that I'm not sure was the module. After a reboot of my router the port opened and I could get in, but I had already rebooted the module.
				civictuner04
THANKS for the info i just rebooted my router and its connected again
				civictuner04
i went through the daves utility no difference, i tried to update it but im not that good with computers....
i did while it was hooked up to the computer i checked the open port and it said port open
once hooked up to the ra controller and check it it says
Error: I could not see your service on 173.71.122.96 on port (2000)
Reason: No route to host
if i check the wifi through the tool on internet through http://192.168.1.9:2000/wifi it works
now with the iphone app sometimes it will correctly show and control my relays but when i go to the display page for temp ph and sal in gives me a time of 8 hours previous and shows sump-0 display and canopy na ph.0.00
				civictuner04
MAN Im an idiot yea that was off i still need to reset my router everytime i want my r/a wifi to work
