Page 2 of 2
Re: ReefAngel Status
Posted: Wed Feb 20, 2013 9:04 am
tkeracer619 wrote:
It pops up every couple hours with a notification with Error 11 Bad URL. On the last version it would just kick back saying it couldn't connect and after a try or two it would work.
Last night I updated the firmware on my wifly and it seems to have made it much much better but I still get that error from time to time. Is there a way to turn that notification off or is something else going on that I need to address?
This sounds like an error message on the Android Status App and not the Java Desktop Status App (sorry for any confusion).
For the Android App, if you are getting those errors and a retry will correct it, I would suggest going to the Settings and then down to Notifications. There is the Error Retries section. I would suggest changing that from 2 to 5 (or something above 2) OR change the Error Retry Interval from 15 seconds to 30 seconds. This way you can hopefully avoid those unfortunate mishaps.
Posted: Wed Feb 20, 2013 5:49 pm
DrewPalmer04 wrote:Cool ever thought about an icon so us Mac people could put it on our dock?
I've got that fixed and updated. I'm actually going to package it up like the MenuGenerator app so you can actually install it. I'm almost ready to do another update/release for it. I have a couple more things I would like to add (ok, well one more). I'd like to have the auto refresh ability in the app. Although I may just push out this update and then work on the auto refresh and update it again...not sure. Oh and I'm thinking of adding in a notification for software updates to the app as well, so you can check for updates from the app without having to search.
Posted: Wed Feb 20, 2013 8:19 pm
by DrewPalmer04
Awesome! The release is up to you. No rush on my side
Posted: Tue Apr 02, 2013 4:34 pm
DrewPalmer04 wrote:Awesome! The release is up to you. No rush on my side
Just released the update. Did not create a mac package for it (I forgot how I did it) but I can if needed. Let me know how it works for you.
Posted: Tue Apr 02, 2013 5:44 pm
by DrewPalmer04
Ok cool. I'll mess with it tomorrow AM
Posted: Sun Apr 28, 2013 3:12 pm
by ahmedess
is it possible in the coming update to add an option to the application to be able to save custom memory location to the list of memory locations already available. It would be great to be able to save the memory location number, its type int or byte and its name.
Posted: Sun Apr 28, 2013 4:44 pm
ahmedess wrote:is it possible in the coming update to add an option to the application to be able to save custom memory location to the list of memory locations already available. It would be great to be able to save the memory location number, its type int or byte and its name.
I hadn't thought about that for this application. I suppose it could be possible. I will have to look into it.
Posted: Mon Apr 29, 2013 12:22 pm
by ahmedess
Is there any other application that has this option we could use?
Posted: Mon Apr 29, 2013 6:26 pm
ahmedess wrote:I hadn't thought about that for this application
I just meant that I was working on this functionality for the Android Status App and never considered doing this for the Java Status App. I don't know of any other app that you could save the custom memory locations for quick reference. Let me start working on this functionality for you and see what I can come up with.
Posted: Wed May 08, 2013 4:08 pm
by jsclownfish
Does anyone know how to load the Java Status App on the iPad?
Jon
Posted: Wed May 08, 2013 4:24 pm
jsclownfish wrote:Does anyone know how to load the Java Status App on the iPad?
Jon
That's an interesting question. I'm not sure if it would work. I can look into it though....I have an iPad and iPad Mini.
Posted: Wed May 08, 2013 4:34 pm
by jsclownfish
I tried to use DropBox to get it onto the ipad, but I couldn't get it to work. I like the status app for reading and writing to memory. I used the Dropbox method to load a handful of different html pages for different parameters (lights, flow rates, etc) from this example Roberto made.
http://forum.reefangel.com/viewtopic.ph ... phs#p11688
It's a cool way to check things by various categories without loading all the graphs on one chart.
Jon
Posted: Wed May 08, 2013 4:36 pm
I just did a search and there's not really an easy way to do it. I did find something if you have a jailbroken device, you can install Java and you should be able to run Java apps. There's also something for running java from websites that's a paid app on iTunes.
Posted: Wed Jun 26, 2013 6:44 am
by Poiromaniax
Doesnt look like the ReefAngel status is working for me. im on mac 10.8.4 with java 6 (latest build)
When i click the refresh button, the port switches grey out for a second, but then no data is pulled through? my dyndns is definately working as I can get to it from my browser.....
Posted: Wed Jun 26, 2013 2:10 pm
Poiromaniax wrote:Doesnt look like the ReefAngel status is working for me. im on mac 10.8.4 with java 6 (latest build)
I think I know what the problem is. It has to do with the app failing on parsing the XML tags being returned. I will have to fix it.
Posted: Wed Jun 26, 2013 3:06 pm
I just uploaded the latest, 1.1.1 to my ftp site. I edited the OP to have the correct download link. Give it a try and see if this fixes your problem.
Posted: Thu Jun 27, 2013 4:24 am
by Poiromaniax
Thanks Curt, that fixed it
Posted: Thu Jun 27, 2013 4:31 am
Poiromaniax wrote:Thanks Curt, that fixed it
awesome. glad it's working now.
Sent from my Nexus 7
