Page 2 of 2
Re: Clouds and Lightining Effects using standard PWM channel
Posted: Wed Aug 22, 2012 11:42 am
The alignment is off.
You will need to align them perfect just like it was before.
Posted: Wed Aug 22, 2012 11:46 am
by DrewPalmer04
got them to line up i think? What exactly is this determining? The time before the next cloud?
It reads 29:00 right now
Posted: Wed Aug 22, 2012 12:04 pm
by DrewPalmer04
If I'm reading this right...it states, "14:29" thus my next cloud is at 2:29pm? Or am I way off?
Posted: Wed Aug 22, 2012 12:27 pm
yeah. whatch and see if it is correct
Posted: Wed Aug 22, 2012 12:37 pm
by DrewPalmer04
It works...going to post a video soon
Posted: Wed Aug 22, 2012 12:46 pm
by DrewPalmer04
Ramp from cloud and back...showed 12 min duration (perfect) and next cloud due at 1553
AWESOME!
Of course the phone's camera has no white balance nor does it show shimmer very well from the LEDs
And new main showing next cloud and next duration (in minutes)....
Posted: Wed Oct 31, 2012 3:18 pm
by NMTX
I'm unsure entirely if this has been covered, but is there a way to define how much the daylights dim during cloud cover? In other words, instead of dimming all the way down to 0V, dim down to 1V (or 10%, however you look at it)? If so, how?
It would be kind of cool if the dimming amount was random, but hey, it's cool as-is.
Posted: Wed Oct 31, 2012 3:40 pm
Change this line:
To this:
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,10,180);
Posted: Wed Oct 31, 2012 3:58 pm
by DrewPalmer04
Good thought! I'll be changing this on mine
Posted: Thu Nov 01, 2012 12:34 am
by NMTX
Yeah, my LED-based light (named for a Greek god) is great, but below 1V, the LEDs just shut down since the driver can't go lower. As I was watching the cloud-dimming simulation—something that I really do enjoy, thank you Roberto et al—I just thought it would look smoother in my application to stop the whites at 1V rather than going off entirely, and still give the desired effect.
I really do enjoy this controller.
Posted: Sat Apr 06, 2013 2:46 pm
by saf1
Does this feature work in the current libraries or development libs I should say?
Also, would be sort of cool if you could add in a option to turn on, for a short burst, say your ports that control wave makers. So you mix in the cloud and storm effects with a quick burst of current.
Probably be a bad thing if it got stuck on...but would be sort of good to build up all the movement for a short period of time. I'm sort of doing that with the Hydor 425's I'm using or trying to anyway. The Koralia circulation and wave pumps say they work on timers. So I'm randomly turning on the ports on the relay box on and off between 60 and 300 seconds. With 2 in the tank I'm trying to find a way to randomly let them overlap at least once every 24 hours...tie that to the storm module would be really cool.
Posted: Sat Apr 06, 2013 4:22 pm
Yeah, it works.
You can also change the code to move water more violently.
Not sure how good it would be with a koralia though. Maybe Jebao, Tunze or Vortech would give you better results.
Posted: Mon Apr 08, 2013 11:26 am
by fran_
Hi, I try to use this code
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
ActinicPWMValue=PWMSlope(10,00,22,15,0,50,40,ActinicPWMValue);
DaylightPWMValue=PWMSlope(10,00,22,15,0,50,40,DaylightPWMValue);
CheckCloud();
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
but I get this error
'PWMSlope' was not declared in this scope
Watchdog Timer
Version Menu
Dimming Signal
Simple Menu
In file included from CloudStandard.cpp:18:
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:86: error: 'ParamsStruct' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:88: error: 'RA_NokiaLCD' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:89: error: 'RA_JoystickClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:90: error: 'LEDClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:92: error: 'RA_ATOHighClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:93: error: 'RA_ATOLowClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:94: error: 'RA_TempSensorClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:95: error: 'RelayClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:97: error: 'RA_PWMClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:133: error: 'TimerClass' does not name a type
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:315: error: 'Total_Menus' was not declared in this scope
/Users/Fran/Documents/Arduino/libraries/ReefAngel/ReefAngel.h:316: error: 'Total_Menus' was not declared in this scope
CloudStandard.cpp: In function 'void loop()':
CloudStandard.pde:-1: error: 'PWMSlope' was not declared in this scope
CloudStandard.pde:-1: error: 'class ReefAngelClass' has no member named 'PWM'
CloudStandard.cpp: In function 'void CheckCloud()':
CloudStandard.pde:-1: error: 'NumMins' was not declared in this scope
CloudStandard.pde:-1: error: 'class ReefAngelClass' has no member named 'LCD'
Posted: Mon Apr 08, 2013 11:32 am
Posted: Mon Apr 08, 2013 1:20 pm
by fran_
I have deleted arduino folder and reinstalled RA and the problem persists - 'PWMSlope' was not declared in this scope. Can be a problem in the code?
Posted: Mon Apr 08, 2013 1:32 pm
Sorry.... Yes, it was code related.
Try this:
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
Posted: Tue Apr 09, 2013 7:02 am
by fran_
Thanks Roberto, works perfect.
Can I change this
CheckCloud();
for this?
ActinicPWMValue=PWMSlope(10,00,21,00,1,100,120,1);
DaylightPWMValue=PWMSlope(10,00,21,00,0,100,120,0);
CheckCloud();
to use actinic channel 1% as moonlight
Posted: Thu May 30, 2013 10:30 am
by jjdezek
i read through this and noticed it says pwm for everything. does this work for anolog? I have 3 heat sinks over my 210 with the meanwell ELN 60-48D drivers hooked up to the anolog expansion. right now all white are hooked to same port 0 and all blues are hook to same port 1 but i can hook them up to different ports so each heat sink is on its own port and allow for the effect of a cloud passing over my tank if thats possible? the lightening would be neat as well but more interested in the cloud.
Posted: Thu May 30, 2013 10:32 am
I believe its the same commands for pwm and analog. The hardware takes care of the differences.
Posted: Thu May 30, 2013 10:38 am
by jjdezek
cool. well i have no idea now to do coding so if anyone could figure out how to do a cloud slowly passing over my tank from one side to the other that would be cool. say i have left heat sink whites in port 0 blues in port 1, middle heat sink whites in port 2 blues in port 3, right heat sink whites in port 4 and blues in port 5. could it start dimming on left then middle then dim right and brighten left then middle and right with a slow moving cloud effect, or is that too complex?
Posted: Thu May 30, 2013 11:24 am
Yeah, totally doable
Let me try to find some time to put this together.
Posted: Thu May 30, 2013 11:29 am
by jjdezek
Ok cool thanks. I will get some wire to set my lights up to those ports.
Posted: Thu May 30, 2013 11:38 am
Can you open a new thread for this?
Posted: Wed Oct 09, 2013 7:21 am
by Bruz4023
Did we open a new thread for this?
Posted: Wed Mar 12, 2014 6:36 am
by jegillis
I think I broke something my storm is after the clouds is that right?
void CheckCloud()
#define Start_Cloud_After NumMins(15,00)
#define End_Cloud_Before NumMins(22,00)
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
DaylightPWMValue=0;
ActinicPWMValue=15;
delay(1);
cloudindex++;
ReefAngel.LCD.DrawText(0,255,8,108,"Cloud");
ReefAngel.LCD.DrawText(0,255,8,118,"00:00");
ReefAngel.LCD.DrawText(0,255,90,108,"Storm");
ReefAngel.LCD.DrawText(0,255,48,108,"Length");
ReefAngel.LCD.DrawText(0,255,90,118,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=8; else x=14;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart/60));
if ((cloudstart%60)>=10) x=58; else x=64;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart%60));
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=90; else x=96;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=108; else x=114;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
