Re: Multiple on/off times
Posted: Tue May 28, 2013 8:54 am
Actually, if you look closely, it's the other way around...
The scheduling is 1st and the override is 2nd.
https://forum.reefangel.com/
How do you mean, Roberto?rimai wrote:Actually, if you look closely, it's the other way around...
I added what you asked at the top and replaced the other code with what you gave me and I'm getting the following error...cosmith71 wrote:ReefAngel.Relay.Status returns a 0 for off and a 1 for on (boolean, true/false) so you can't just add 120 there.
Try this:
This goes near the top right above ////// Place global variable code above here
Remove this:Code: Select all
unsigned long ATOUpdate=0;
And try this instead:Code: Select all
if (ReefAngel.Relay.Status(Port5)) ReefAngel.Relay.Off(Port6); else ReefAngel.WaterLevelATO(Port6,720,29,31);
--ColinCode: Select all
if (ReefAngel.Relay.Status(Port5) && ATOUpdate==0) // Check to see if port 5 is on and update time is empty { ATOUpdate = now(); // If so, set the update time to now ReefAngel.Relay.Off (Port6); } // and turn off the ATO pump if (now() - ATOUpdate >= 120 && ATOUpdate != 0) // If it's been 120 sec, and the update time is NOT empty { ATOUpdate = 0; // Empty out the update time ReefAngel.WaterLevelATO(Port6,720,29.31); } // and turn the ATO sensor back on
Steves_Custom_Wave_Sketch.cpp: In function 'void loop()':
Steves_Custom_Wave_Sketch:78: error: no matching function for call to 'ReefAngelClass::WaterLevelATO(int, int, double)'
C:\Users\Steve\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:322: note: candidates are: void ReefAngelClass::WaterLevelATO(byte, int, byte, byte)
C:\Users\Steve\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:353: note: void ReefAngelClass::WaterLevelATO(byte)
Try this:
That was it. I wasn't even looking there because the error seemed to be referring to something different.rimai wrote:I think you typed wrong....
Not your fault Colin.cosmith71 wrote:Oops. Sorry!
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
// Use T2 probe as temperature and overheat functions
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,29,31); } // and turn the ATO sensor back on
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
}We should add ato timout and overheat flags to the r99 output..Sacohen wrote:I'm not 100% sure, because I'm not at home to look at the head unit.
I only have access to the Portal & the Reef Angel Client, would it show me a time out on either of those?
I don't think it is because if I look at the relay activity Port6 has not activated since Thursday May 28th at 7:24 am and when I came home from work yesterday it was at the 32% level.
ReefAngel.WaterLevelATO(Port6,720,29,31); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.Relay.Off (Port6); // and turn off the ATO pump
