Page 2 of 5
Re: Dosing Pump not running on Schedule
Posted: Sat May 25, 2013 11:56 am
It returns unix time, which is often called epoch time too.
Basically it is number of seconds from 01/01/1970.
Posted: Sat May 25, 2013 9:05 pm
by kirkwood
kirkwood wrote:Inevo,
I loaded in the code you posted. Where do I find the data it is tallying? I don't know what the "Custom main function" is.
thanks
so do I have to create a custom mainscreen to be able to utilize the code that I just added?
Posted: Sun May 26, 2013 6:21 am
by cosmith71
lnevo wrote:Ok, try this...
Move this section above the setup where it says to put global code here...
time_t running1, running2;
You can leave this section in your loop();
  // Reset the counter each day
  if (now()%SECS_PER_DAY==0) {
    running1=0;
    running2=0;
  // If the Dosing Pump 1 is on and it's a new second...
  if (ReefAngel.Relay.Status(DPump1) && (millis()%1000==0)) {
    running1++; // increment the counter;
  // If the Dosing Pump is on and it's a new second...
  if (ReefAngel.Relay.Status(DPump2) && (millis()%1000==0)) {
    running2++; // increment the counter;
  // Normalize and assign to CustomVar for reporting on the portal
  ReefAngel.CustomVar[0]=running1/60; // Number of Minutes for DPump1
  ReefAngel.CustomVar[1]=running1%60; // Number of Seconds for DPump1
  ReefAngel.CustomVar[2]=running2/60; // Number of Minutes for DPump2
  ReefAngel.CustomVar[3]=running2%60; // Number of Seconds for DPump2
You can now access running1 and running2 in your CustomMain function. If you want minutes and seconds look at the CustomVar assignments for how to do that, otherwise you could just display total seconds of running.
As far as ml, I'll try and get some time to do that later... I'm actually working on some code to store my calibration number and use a ml setting instead of second setting to distribute the amount throughout the day automatically.
Lee, I'm using the custom webchart and the android app to check this and all I get back from C0-C3 are zeros. Am I doing something wrong?
Posted: Sun May 26, 2013 6:27 am
by cosmith71
rimai wrote:You would have to make the running time longer than 5 minutes if you want it to show in the relay activity 100% of the time.
Or, you could code an expansion outlet port to be triggered on dosing pump port, but it would stay on for more than 5 minutes.
Done!
Code under "////// Place global variable code below here"
unsigned long LastUpdate1=0;
unsigned long LastUpdate2=0;
Code in loop()
if (ReefAngel.Relay.Status(AlkPump) && LastUpdate1==0)
      LastUpdate1 = now();
      ReefAngel.Relay.On (Box2_Port1);
    if (now() - LastUpdate1 >= 360 && LastUpdate1 != 0)
      LastUpdate1 = 0;
      ReefAngel.Relay.Off (Box2_Port1);
    if (ReefAngel.Relay.Status(CalPump) && LastUpdate2==0)
      LastUpdate2 = now();
      ReefAngel.Relay.On (Box2_Port2);
    if (now() - LastUpdate2 >= 360 && LastUpdate2 != 0)
      LastUpdate2 = 0;
      ReefAngel.Relay.Off (Box2_Port2);
Note, Box2 doesn't physically exist. Works like a charm. I doesn't give me times, but does let the portal relay chart tell me that the pumps came on.
Posted: Sun May 26, 2013 7:20 am
Cool!! :)
Posted: Sun May 26, 2013 7:41 am
by cosmith71
I liked it so much I set it up for my ATO as well. Now my code is cluttered. Time to figure out how to move it into a function... :geek:
I was a Comp Sci major 20 or so years ago. I never finished it. I'd forgotten how much fun coding can be. :ugeek:
Posted: Tue May 28, 2013 6:47 pm
So I'm thinking of switching to volume based. The only caveat is I think we also need to store the volume calibrated against. So for Roberto's case, using a 1cup kitchen measuring cup, you could set the volume to 236ml (1cup = 236.588ml). We can trigger a timer when mask on is set and stop the counter when mask off is set. Whatever the value of the timer is the number of seconds to fill that volume. We can have an time_t timers[] and the calibration function can take a byte ports[] as the argument. this way the function can calibrate all the pumps at once, or one at a time.
In a menu mode, you could show all the pumps that have been activated and the time and have an OK or Cancel button to save the settings. Or if you already know the rate and want to just plug it in you could just write the values to memory.
This would only work well if you have the wifi module...otherwise the menu becomes a lot more complicated...
Anyway, I'm going to change my code to go the volume route. I'm going to use the WiFiAlert method now to send me the time result...btw, this might be a good method for kirkwood...you can get an email each time your doser goes off with the total time / ml dosed each session...
Posted: Tue May 28, 2013 10:16 pm
Ok, here's the function I wrote up to dose by volume or dose by time. If memory is flagged to dose by volume then it updates the DPTimer variable for that pump with the calculated time per dose. If not, it updates the memory location with how much volume should be dosed per day. This should make it easy to switch back and forth if needed. Also, should be easily adaptable to many dosing pumps, although you might want some by time and some by volume. still have to work on the new calibration function.
Once again this is test code, it has not even been compiled yet...
void DosingPumps() {
  const byte numPumps=2;
  byte pump[numPumps] = { DPump1, DPump2 };
  int memTimer[numPumps] = { Mem_B_DP1Timer, Mem_B_DP2Timer };
  int memRepeat[numPumps] = { Mem_I_DP1RepeatInterval, Mem_I_DP2RepeatInterval };
  int memCalibrateVol[numPumps] = { Mem_I_Calibrate1Vol, Mem_I_Calibrate2Vol };
  int memCalibrateTime[numPumps] = { Mem_I_Calibrate1Time, Mem_I_Calibrate2Time };
  int memPumpVolume[numPumps] = { Mem_I_Pump1Vol, Mem_I_Pump2Vol };
  for (int i=0;i < numPumps; i++) {
    float pumpRate=InternalMemory.read_int(memCalibrateVol[i])/InternalMemory.read_int(memCalibrateTime[i]);
    int doseTime=InternalMemory.read_int(memTimer[i]);
    int repeatTime=InternalMemory.read_int(memRepeat[i]);
    int totalVolume=pumpRate*(doseTime*(1440/repeatTime));
    int calcTime=(InternalMemory.read_int(memPumpVolume[i])*pumpRate)/(1440/repeatTime);
    if (InternalMemory.read(Mem_B_DoseByVolume)) {
      if (doseTime!=calcTime)
        InternalMemory.write_int(memTimer[i], doseTime=calcTime);
    } else {
        InternalMemory.write_int(memPumpVolume[i], totalVolume);
    ReefAngel.DosingPumpRepeat(pump[i], i*5, repeatTime, doseTime);
Posted: Wed May 29, 2013 5:29 am
Fixed the compile issues in the code above.
Posted: Wed May 29, 2013 4:47 pm
Ok. calculations are working.. Not sure if I changed much except cast one float and had to change a multiply to divide :)
So if the mem location is set to dose by volume, when you change the volume memory field, it will update the timer for that dosing pump. Inversely if you update the timer when it's set to dose by time, it will update the volume memory location with the total volume for the day.
Still need to fix this so you can do either without needing to choose dose by volume or not... hmmm
Edit: Logging/Reporting... done. Method to cancel the calibration... done.
Anyway, here's some code to play with...
// Definitions for dosing pumps
#define numDPumps 2
byte pump[numDPumps]={ DPump1, DPump2 };
byte varReport[numDPumps]={ Var_DPump1, Var_DPump2 };
int memDPTime[numDPumps]={ Mem_B_DP1Timer, Mem_B_DP2Timer };
int memDPVolume[numDPumps]={ Mem_I_DP1Volume, Mem_I_DP2Volume };
int memDPRepeat[numDPumps]={ Mem_I_DP1RepeatInterval, Mem_I_DP2RepeatInterval };
int memCalTime[numDPumps]={ Mem_I_CalDP1Time, Mem_I_CalDP2Time };
int memCalVol[numDPumps]={ Mem_I_CalDP1Vol, Mem_I_CalDP2Vol };
void RunDosingPumps() {
  int doseTime, repeatTime, calcTime, totalVolume;
  float rate;
  for (int i=0;i < numDPumps; i++) {
    doseTime=InternalMemory.read_int(memDPTime[i]);
    repeatTime=InternalMemory.read_int(memDPRepeat[i]);
    rate=(float)InternalMemory.read_int(memCalVol[i])/InternalMemory.read_int(memCalTime[i]);
    calcTime=(InternalMemory.read_int(memDPVolume[i])/rate)/(1440/repeatTime);
    totalVolume=rate*(doseTime*(1440/repeatTime));
        InternalMemory.write_int(memDPTime[i], doseTime=calcTime);
    } else {
        InternalMemory.write_int(memDPVolume[i], totalVolume);
    // Make sure we're not calibrating
    if (!ReefAngel.Relay.Status(VO_Calibrate))
void LogDosingPumps() {
  static time_t pumpTimer[numDPumps];
  static boolean pumpStatus[numDPumps];
  float rate;
  for (int i=0;i< numDPumps;i++) {
    if (ReefAngel.Relay.Status(pump[i])) {
      if (!pumpStatus[i]) {
        pumpStatus[i]=true;
    } else {
      if (pumpStatus[i]) {
        pumpStatus[i]=false;
        ReefAngel.CustomVar[varReport[i]]=pumpTimer[i]*rate;
    if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[i]=0; // Clear timer at end of day
void CalibrateDPumps() {
  static boolean running;
  if (ReefAngel.Relay.Status(VO_Calibrate)) {
    running=true;
    for (int i=0;i < numDPumps;i++) {
          pumpStatus[i]=true;
      } else {
  } else {
    if (running) {
      running=false;
        if (pumpTimer[i]>0 && !ReefAngel.Relay.Status(VO_LockPorts)) {
          InternalMemory.write_int(memCalTime[i], pumpTimer[i]);
        ReefAngel.Relay.Override(pump[i],2); // Go back to auto mode
        pumpTimer[i]=0;
Posted: Wed May 29, 2013 10:33 pm
FYI, this code relies on a few things that I have added to the libraries but aren't available yet. If you want to use this let me know and I can either point you to my git repo for the current branch to pull, or how to work around the missing pieces,
Posted: Thu May 30, 2013 7:28 am
Ok, I took out the dependencies to WiFiAlert and the mask commands I added. I needed a solution anyway for the logging (which could have been on or a mask...) so I used the same mechanism in the calibration routine. So this should be usable by anyone now.
Also, since we are now calculating the rate of flow and are able to determine volume.. I think we can safely store the amount dosed in a byte and publish it to the portal.... if it wraps, it wraps :) But this should provide good monitoring for those who want to monitor their dosing routine.
Posted: Thu May 30, 2013 7:38 am
by cosmith71
lnevo wrote:Ok, I took out the dependencies to WiFiAlert and the mask commands I added. I needed a solution anyway for the logging (which could have been on or a mask...) so I used the same mechanism in the calibration routine. So this should be usable by anyone now.
This is the code in the last post on page 4? Might play with it over the weekend.
Posted: Thu May 30, 2013 7:43 am
by cosmith71
Where does VO_Calibrate come from?
Posted: Thu May 30, 2013 7:44 am
Yea. The trick in using it is defining all the memory locations needed, but otherwise *should* be plug and play. I should be around to help if you get stuck on anything... There may be another version by the weekend though, as I have a few more tests to run, but I'm pretty pleased with it at the moment.
Posted: Thu May 30, 2013 7:46 am
by cosmith71
lnevo wrote:Yea. The trick in using it is defining all the memory locations needed, but otherwise *should* be plug and play. I should be around to help if you get stuck on anything... There may be another version by the weekend though, as I have a few more tests to run, but I'm pretty pleased with it at the moment.
Which locations are available? Is it 100-199?
Posted: Thu May 30, 2013 7:49 am
You should use my INO (in my signature) as a reference for some of those defines :)
VO_Calibrate is a virtual (non-existent) outlet. You could use any unused outlet or change the conditional to use a memory location as a trigger. I use two ports to control the calibration process. One that locks the ports and one to start calibration mode. If I lock the ports before I turn off calibration mode, then the values are not saved. If I turn off calibration mode first then the time values are saved to memory.
Good question, and I guess where it might get tricky for some.
Posted: Thu May 30, 2013 7:51 am
Yeah, those should be free to use if you aren't already. The built-ins start at 200.
Posted: Sat Jun 01, 2013 6:58 am
Ok, for anyone testing, I've got all the bugs I think sorted out. The nice thing is that you can now update the volume memory location OR the DPTimer in the portal. If you change the volume, the new time is calculated and updated so you can see the change and the dosage amount in the portal. If you change the time however, it will get rounded to the nearest ml. So for instance if I put 68 seconds in the timer, it will calculate the volume of ml that will produce which will then be updated in memory. It will then recalculate the amount of time necessary to get that dosage which would then be 65 seconds. This is a precision issue since we can't store floats in memory (yet hehehe) But either way, the volume method would be the more accurate means to adjust at this point, but the functionality is in place.
Anyway, if anyone wants to play with this, here is the latest round of code:
Be aware, you will need to change the triggers in the calibration routine. Either declare ports that you are not using and they will appear in the portal as if you had an expansion relay or change the conditionals to use memory settings, or if you're brave, you could write a menu interface to turn on calibration and off. That part may get tricky so let me know if you have any questions.
#define numDPumps 2
  float rate;
  int dpTime, dpRepeat, calcTime, totalVolume;
  static int doseTime[numDPumps]={
    InternalMemory.read(memDPTime[0]),
    InternalMemory.read(memDPTime[1])
    dpTime=InternalMemory.read(memDPTime[i]);
    dpRepeat=InternalMemory.read_int(memDPRepeat[i]);
    calcTime=(InternalMemory.read_int(memDPVolume[i])/rate)/(1440/dpRepeat);
    totalVolume=rate*(dpTime*(1440/dpRepeat));
    if (dpTime!=doseTime[i]) { // Memory has changed.
        InternalMemory.write_int(memDPVolume[i], totalVolume); // Update volume
        doseTime[i]=dpTime;
    } else if (dpTime!=calcTime) { // Calculated time has changed.
        InternalMemory.write(memDPTime[i], calcTime); // Update time
        doseTime[i]=calcTime;
      ReefAngel.DosingPumpRepeat(pump[i], i*5, dpRepeat, doseTime[i]);
  float rate;
        pumpStatus[i]=true;
    } else {
  static boolean running=false;
    running=true;
          pumpStatus[i]=true;
      } else {
  } else {
    if (running) {
      running=false;
        pumpTimer[i]=0;
Posted: Mon Jun 10, 2013 10:48 am
by kirkwood
    running1=0;
    running2=0;
I used this code and I don't get any value in the custom field 0 or 2. I do get a value in custom field 1 and 3. From reading the code it looks like fields 1 and 3 are for seconds. I usually get a reading that is a pretty small number while I'expect to see something that consistently approaches 60 before resetting. Seems like the minute fields are not funcitoning properl. How can I fix?
Posted: Mon Jun 10, 2013 10:57 am
Looking at the forum chart for your variables, it doesn't look like you're getting more than 13 seconds of dosing... the value climbs all day and resets at midnight as expected. It won't increment c0 or C2 until it gets passed 60 seconds... Your C3 variable peaked at 15 on friday...
Take a look at these charts if you haven't already. It may help to troubleshoot.
http://forum.reefangel.com/status/chart ... &filter=c1
http://forum.reefangel.com/status/chart ... &filter=c3
Can you confirm how much time your dosing each session?
Also, there may be an issue with the logic I used to increment the counter as you may not hit this function when milis%1000=0. I am using a different method in my other code, so I think this may be the bigger part of your problem. What I do now is start a timer when I see the port go on and disable the timer when it goes off.
If you can look at the LogDosingPumps() function in this post: http://forum.reefangel.com/viewtopic.php?p=27080#p27080 and see what I do now it may help... if you need assistance re-coding what your using, I can try and put something together later tonight.
Posted: Mon Jun 10, 2013 11:23 am
by kirkwood
Inevo,
I will take a look at those links later tonight. I know I run port 3 for 340 seconds ever 2 hours and port4 I run 290 seconds every 2 hours with a 60 minute offset.
Posted: Mon Jun 10, 2013 12:24 pm
Cool, yeah I think it was the methodology I used. I will alter the function for you on the train ride home or later tonight.... sorry for the confusion.
Posted: Mon Jun 10, 2013 2:52 pm
Ok here is a bit of a merger from my current volume based code and what you were originally timing. This tracks how long in seconds the port is on and publishes it to the portal. If you turn it on or mask it on by mistake you could even set an alert... You could also trigger a mask off for the port in your code so your pumps are automatically disabled,..anyway I digress.l, here's the code
#define numPumps=2
byte portalMinutes = { 0, 2 }
byte portalSeconds = { 1, 3 }
      pumpStatus[i]=true;
  } else {
      ReefAngel.CustomVar[portalMinutes[i]]=pumpTimer[i]/60; // Number of Minutes
      ReefAngel.CustomVar[portalSeconds[i]]=pumpTimer[i]%60; // Number of Seconds
Posted: Wed Jun 12, 2013 1:29 pm
Adding in tracking for the ATO pump as well.
const byte numPumps=3;
byte pump[numPumps] = { DPump1, DPump2,  ATOPort };
byte portalMinutes[numPumps] = { 0, 2, 4 };
byte portalSeconds[numPumps] = { 1, 3, 5 };
static time_t pumpTimer[numPumps];
static boolean pumpStatus[numPumps];
static boolean atoDisabled;
for (int i=0;i< numPumps;i++) {
      pumpStatus[i]=true;
  } else {
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[0]=0; // Clear timer for DPump1
if (now()%SECS_PER_DAY==SECS_PER_DAY-1) pumpTimer[1]=0; // Clear timer for DPump2
if (bitRead(ReefAngel.Relay.RelayMaskOff, Port1Bit)==0) { // ATO relay is manually disabled
  atoDisabled=true;
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOff, Port1Bit)==1)) { // ATO override has been cleared
  pumpTimer[2]=0; // Clear timer for ATOPort
  atoDisabled=false;
Posted: Thu Jun 13, 2013 5:23 am
by kirkwood
So I am assuming that I need to delete all the old code for the dosing pump logging from the global variable and custom code sections?
Next does all the new code go into the custom code or do I place some of the code in the global variable section?
Finally, do I need to change any of the DPump names to the actual Port numbers I am using?
Posted: Thu Jun 13, 2013 5:43 am
Yes, you will need to delete everything you added previously. I just fixed a few errors and made it so you can just copy / paste this into the custom section.
You will need to change the DPump1, DPump2, and ATOPort to your ports, or define them :)
You will also need to change the PortXBit to whatever port your ato is on for the timer reset to work.
Posted: Thu Jun 13, 2013 6:51 am
by kirkwood
My ALK is Port3, my CAL is Port4, my ATO is Port7. Did I make the correct changes?
byte pump[numPumps] = { Port3, Port4, Port7 };
if (ReefAngel.Relay.Status(pump)) {
if (!pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was off, timer is now a time
pumpStatus=true;
} else {
if (pumpStatus) {
pumpTimer=now()-pumpTimer; // Pump was on, timer is now a timer
pumpStatus=false;
ReefAngel.CustomVar[portalMinutes]=pumpTimer[i]/60; // Number of Minutes
if (bitRead(ReefAngel.Relay.RelayMaskOff, Port7Bit)==0) { // ATO relay is manually disabled
atoDisabled=true;
if (atoDisabled && (bitRead(ReefAngel.Relay.RelayMaskOff, Port7Bit)==1)) { // ATO override has been cleared
atoDisabled=false;
Posted: Thu Jun 13, 2013 7:05 am
Looks good, let me know if any issues in the compile.
Posted: Thu Jun 13, 2013 9:36 am
by kirkwood
Error when compiling.
scalar object "portalMinutes" requires one element in initializer
