Page 2 of 2
Re: jebo wp40
Posted: Mon Jun 10, 2013 9:31 pm
Yes, there is a way...
It's your homework now to change the position of the stuff to your liking
It's all based on the x and y, which are coordinates of where you want to display stuff.
The top left corner is 0,0 and it goes to 132,132 at the bottom right corner.
Just go changing the coordinates for each stuff you want to move and play around until you get what you want
Re: jebo wp40
Posted: Mon Jun 10, 2013 9:37 pm
by 805reefer
ok that sounds good to me so it showing its in tidal swell mode but is should be in sine mode? so whats showing on the screen is what mode its in right
Re: jebo wp40
Posted: Mon Jun 10, 2013 9:38 pm
by 805reefer
static time_t feeding;
// Time schedule first
if (hour()>=6 && hour()<11) {
//ReefAngel.PWM.SetDaylight( TidalSwellMode(45,true) ); // TidalSwell at 45% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(30,true) ); // TidalSwell at 30% on sync mode
wpMode=1;
} else if (hour()>=11 && hour()<15) {
//ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(40,20,true) ); // ReefCrest at 40% +/- 20% on anti-sync mode
wpMode=2;
} else if ( (hour()>=15 && hour()<18) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
// ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(25,35,6000,true) );
wpMode=3;
} else if (hour()>=15 && hour()<18) {
// ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
ReefAngel.PWM.SetActinic(ShortPulseMode(15,42,3000,true));
wpMode=2;
} else if (hour()>=18 && hour()<20) {
ReefAngel.PWM.SetActinic( ReefCrestMode(32,20,true) ); // ReefCrest at 32% +/- 20% on anti-sync mode
wpMode=2;
} else if (hour()>=20 && hour ()<23) {
// ReefAngel.PWM.SetDaylight(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
wpMode=1;
} else {
//ReefAngel.PWM.SetDaylight(SineMode(15,40,30,true) ); //SineMode from 15% to 40% for 30 seconds on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(20,true) ); // TidalSwell at 20% on sync mode
wpMode=4;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
//ReefAngel.PWM.SetDaylight(0);
ReefAngel.PWM.SetActinic(0);
// If we are feeding override the schedule
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
// ReefAngel.PWM.SetDaylight(30);
wpMode=0;
feeding=now();
Re: jebo wp40
Posted: Mon Jun 10, 2013 9:42 pm
I think you got it inverted....
Look at your code that displays the modes:
if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Feeding");
else if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x,y,"Reef Crest");
else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_RED,255,x,y,"Nutrient");
else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x,y,"Sine Wave");
And look at what you are assigning to wpMode here:
wpMode=1;
} else {
wpMode=4;
Can you see that they are inverted?
Re: jebo wp40
Posted: Mon Jun 10, 2013 9:47 pm
by 805reefer
oh got you so thats because i changed some of the modes around right?
Re: jebo wp40
Posted: Tue Jun 11, 2013 3:50 am
Exactly
Re: jebo wp40
Posted: Tue Jun 11, 2013 10:22 am
my tutorial on custom main screens covers the x,y coordinates of the screen. if you get confused, read that tutorial and it should help.
Re: jebo wp40
Posted: Tue Jun 11, 2013 3:35 pm
by 805reefer
Ok will do I'm going to start working on it in about an hour I really appreciate all the help
Re: jebo wp40
Posted: Tue Jun 11, 2013 7:15 pm
by 805reefer
ok thanks to binder and his tutorial i got my screen to show the whole mode now and not only half... now another issue so i put it in feeding mode for the first time today and noticed that my pump didnt shut off which i have it set to 0 what do i need to do here
wpMode=1;
wpMode=2;
wpMode=3;
wpMode=5;
wpMode=2;
wpMode=4;
} else {
wpMode=1;
wpMode=0;
feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR) {
//ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
ReefAngel.PWM.SetActinic( NutrientTransportMode(25,40,6000,true) );
wpMode=3;
Re: jebo wp40
Posted: Tue Jun 11, 2013 7:28 pm
Hmm well oddly you have the WaterChange mode code twice...which isn't the issue here, but it makes me wonder what we may not be seeing...can you post your whole code? I don't see any reason why it wouldn't set to 0. The code looks good...
Re: jebo wp40
Posted: Tue Jun 11, 2013 8:02 pm
by 805reefer
wow just saw that so i removed one of the water changes and still nothing heres the code
static byte wpMode;
ReefAngel.LightsOnPorts = Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.DosingPumpRepeat1( Port3 );
ReefAngel.DosingPumpRepeat2( Port5 );
ReefAngel.DayLights( Port6 );
ReefAngel.ActinicLights( Port7 );
ReefAngel.PWM.Channel0PWMSlope(40);
ReefAngel.PWM.Channel1PWMSlope(10);
ReefAngel.PWM.Channel2PWMSlope(20);
ReefAngel.PWM.Channel3PWMSlope(35);
ReefAngel.PWM.Channel4PWMSlope(25);
if (hour()>=6 && hour()<9) {
wpMode=1;
} else if (hour()>=9 && hour()<12) {
wpMode=2;
} else if ( (hour()>=12 && hour()<15) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
wpMode=3;
wpMode=5;
wpMode=2;
wpMode=4;
} else {
wpMode=1;
ReefAngel.PWM.SetActinic (0);
wpMode=0;
feeding=now();
wpMode=3;
ReefAngel.Portal( "805reefer" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// WP40 Mode
x = 15;
y = 33;
ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
else if (wpMode == 5) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Short Pulse");
// Parameters
// Main Relay Box
// Date and Time
Re: jebo wp40
Posted: Tue Jun 11, 2013 8:40 pm
by 805reefer
when i push water change the pump does turn off..... as far as the wave patterns they all work each time the mode changes the flow is changing... what are you seeing
Re: jebo wp40
Posted: Tue Jun 11, 2013 8:50 pm
by 805reefer
ya im tying to learn but im just having so many different problems trying to figure this stuff out im glad we have some pros on here thats for sure
Re: jebo wp40
Posted: Tue Jun 11, 2013 10:43 pm
I see what the problem is. Move the feeding_mode section below the nutrient transport mode section. That is overriding the feeding mode. My bad on that one.
Re: jebo wp40
Posted: Wed Jun 12, 2013 8:43 pm
by 805reefer
ok cool that fixed it i really appreciate all you help and time you spent with me on this thanks again im sure there will be more to come
Re: jebo wp40
Posted: Fri Jun 14, 2013 10:11 am
by Smotz
Any way this can get displayed on my tablet via the app?
Re: jebo wp40
Posted: Fri Jun 14, 2013 10:20 am
If everything goes well, yes.
I'm working on a libraries update and creating a new class for these dc pumps.
They will have new XML tags for mode, speed and duration, which apps and the portal will be able to leverage and utilize it to display in the user interface.
Re: jebo wp40
Posted: Fri Jun 14, 2013 10:25 am
by Smotz
rimai wrote:If everything goes well, yes.
Thats awesome.
Re: jebo wp40
Posted: Fri Jun 14, 2013 12:08 pm
by bhazard
Awesome! Loving the Reef Angel. Support is top notch.
Re: jebo wp40
Posted: Fri Jun 14, 2013 7:05 pm
