Re: Dimmable LED Acclimation for corals
Posted: Wed Jan 01, 2014 3:25 pm
Thats the whole range of internal memory variables used by RA. Look for the pwm ones in the middle somewhere...
https://forum.reefangel.com/
//Defining different formulas for different channels
// This part would go in your global declarations.
#define Mem_B_AcclDay 100 // 30
#define Mem_B_AcclDuration 101 // 30
#define Mem_B_AcclStartingEndPercent 102 // 25
// The rest of this goes inside your loop() or custom function
// Let's make some variables to work with
byte acclDay = InternalMemory.read(Mem_B_AcclDay); // Let's get what's in memory
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration); //Acclimation Duration
byte acclStartingEndPercent = InternalMemory.read(Mem_B_AcclStartingEndPercent); // Starting End% for Acclimation
byte startPercent = InternalMemory.read(Mem_B_PWMSlopeStart0); // Normal start% 13 //Using Mem_B_PWMSlopeStart0 for all 3 channels
byte endPercentBlue = InternalMemory.read(Mem_B_PWMSlopeEnd1); // Normal Blue end% 65 //Using Mem_B_PWMSlopeEnd1 for both Blue Channels 1,2
byte endPercentWhite = InternalMemory.read(Mem_B_PWMSlopeEnd0); // Normal White end% 75
float acclPercentPerDayBlue = (endPercentBlue-acclStartingEndPercent)/(acclDuration*100); // (65 - 25) / (30 * 100) = 0.013333 = 1.33% increase/day
float acclPercentPerDayWhite = (endPercentWhite-acclStartingEndPercent)/(acclDuration*100); // (75 - 25) / (30 * 100) = 0.016667 = 1.66% incrase/day
// This is how much we're going to alter the dimming
// This number could also be used to adjust the duration
// of the slope... the startPercent, the photoperiod..whatever you want
float acclFactorBlue=acclDay*acclPercentPerDayBlue; // 30 * 0.013333 = .4
float acclFactorWhite=acclDay*acclPercentPerDayWhite; // 30 * 0.016667 = .5
// Adjust the endPercent based on the acclFactor
endPercentBlue=endPercentBlue-(acclFactorBlue*100);
//Here are some samples
// Day 30 = 65 - (0.4 * 100) = 25%
// Day 15 = 65 - (0.199995 * 100) = 45%
// Day 5 = 65 - (0.066665 * 100)= 58%
endPercentWhite=endPercentWhite-(acclFactorWhite*100);
// Here's what some samples look like
// Day 30 = 75 - (0.5 * 100) = 25%
// Day 15 = 75 - (0.25 * 100) = 50%
// Day 5 = 75 - (0.083 * 100) = 67*
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,startPercent,endPercentWhite,40,20) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,startPercent,endPercentBlue,40,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,startPercent,endPercentBlue,40,20) );
// At the end of the day, we need to decrement the acclimation counter.
static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
acclDay--; // Reduce the counter
acclCounterReady=false; // Reset the boolean flag
InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
Mem_B_PWMSlopeEnd0
Mem_B_PWMSlopeEnd1
if ( InternalMemory.read(Mem_B_AcclDay)<=0 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,13,55,40,20) ); // Minimum % for Dimming is 11%
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,13,55,40,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,13,55,40,20) ); // Start Hour, Start Minute, End Hour, End Minute, Start Percentage, End Percentage, Duration, Default Percentage used for lights on mode
if (acclDay>0)
ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,startPercent,endPercentWhite,60,20) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,startPercent,endPercentBlue,90,20) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,startPercent,endPercentBlue,90,20) );
if (acclDay=0)
else if (acclDay>0)
///// ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
//Custom Port Labels
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="BlueLED";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="WhiteLED";
ReefAngel.CustomLabels[4]="KalkATO";
ReefAngel.CustomLabels[5]="Moonlight";
ReefAngel.CustomLabels[6]="WP40";
ReefAngel.CustomLabels[7]="Refugium";
ReefAngel.StandardHeater( Port1,784,790 );
ReefAngel.StandardLights( Port2,12,0,21,30 );
ReefAngel.StandardLights( Port4,13,0,20,30 );
ReefAngel.SingleATO( true,Port5,1200,1 );
ReefAngel.StandardLights( Port8,20,30,13,0 );
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 0, PWMSlope(13,0,20,30,13,55,40,20) ); // Minimum % for Dimming is 11%
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 1, PWMSlope(12,0,21,30,13,55,40,20) );
/// Using custom code at the bottom ReefAngel.PWM.SetChannel( 2, PWMSlope(12,0,21,30,13,55,40,20) ); // Start Hour, Start Minute, End Hour, End Minute, Start Percentage, End Percentage, Duration, Default Percentage used for lights on mode
ReefAngel.PWM.SetActinic( ReefCrestMode (0, 0, false));
if ( (hour()>=11) && (now()%SECS_PER_DAY<73800) ) // 11am - 8:30pm
ReefAngel.PWM.SetDaylight( ElseMode(60,20,true) ); // ReefCrest at 55% +/- 20% on sync mode
else if ( (now()%SECS_PER_DAY>73800) && (hour()<23) ) // 8:30pm - 11pm
ReefAngel.PWM.SetDaylight( NutrientTransportMode(0,70,400,true) ); // Nutrient Transport 0%minspeed - 70%maxspeed - 400ms
else if ( (hour()>=23 || hour()<11) ) // 11pm - 11am
ReefAngel.PWM.SetDaylight( ElseMode(30,10, true) ); // ReefCrest at 35% +/- 15% on sync mode
byte acclDuration = InternalMemory.read(Mem_B_AcclDuration); //Acclimation Duration 15
byte acclStartingEndPercent = InternalMemory.read(Mem_B_AcclStartingEndPercent); // Starting End% 55 for Acclimation
byte startPercent = InternalMemory.read(Mem_B_PWMSlopeStart0); // Normal start% 15 //Using Mem_B_PWMSlopeStart0 for all 3 channels
ReefAngel.Portal("ReEfnWrX","******");
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random(2000,3000); // Set the initial delay - default 500, 3000
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(2000,15000); // If so, come up with a new delay - default - 500, 5000
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
if (WaveSync)
return NewSpeed;
return AntiSpeed;
lnevo wrote:It may interfere with your wifi while doing it, but after you upload the code, you can open Serial Monitor and see what the variables are doing...
Usually you dont want to do that because floats take up 4-8 times as much mem as a byte...so if you do try and keep it to the variables that need it...ReEfnWrX wrote:So if I wanted to use decimals for the formulas to keep them exact, I should assign all the variables as floats and then my final product end% a byte?
