Re: RANet Ready Dimmable LED Driver
Posted: Wed Feb 18, 2015 3:48 pm
Im getting an overheat problem with the LED driver, channel 0 was shutting off for a few seconds about every 10 seconds. I unplugged the driver and checked the temp inside the case and found it at 150 degrees. I took the cover off and let it cool. Plugged it back in and it appears to be ok for now except the green power led is no longer working.
I have the driver in my cabinet that is running about 72 degrees right now.
Channel 0 is being run at 950 ma
Channel 1 and 2 are run at 600 ma
This is going to end up being a problem in the summer when my thermostat will not be set at 66 degrees.
