Re: Reefology's code
Posted: Mon Feb 09, 2015 6:20 am
What do you want to do with them...if you want to speed one up or slow one down? Which is currently sync/antisync?
https://forum.reefangel.com/
// DC pumps
// To run this code must choose Custom in portal
static int rmode;
byte modes[] = { NutrientTransport, Sine, ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%1200==0 || changeMode==true) { // Change every 20 (1200seconds) mins or controller reboot
rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3000) {
// Continue NutrientTranspot Mode for 45 minutes
} else if (now()%SECS_PER_DAY<37800 || now()%SECS_PER_DAY>=81000) { // 10:30am / 10:30pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Gyre;
ReefAngel.DCPump.Speed=30;
} else {
// DC pumps
static int rmode;
changeMode=false;
} else {
// DC pumps
static int rmode;
changeMode=false;
} else {
ReefAngel.FeedingModePorts = Port5Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardLights( Port5, 19,0,7,0);
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DosingPumpRepeat2( Port7 );
ReefAngel.DosingPumpRepeat3( Port8 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
ReefAngel.DCPump.AntiSyncOffset=125;
// DC pumps
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
changeMode=false;
// Continue NutrientTranspot Mode for 30 minutes after feeding
if (now()-feeding<1800) {
ReefAngel.DCPump.Speed=80;
} else if (now()%SECS_PER_DAY>25200 && now()%SECS_PER_DAY<=68400) { // 7am to 7pm
} else {
ReefAngel.StandardLights( Port5 );
ReefAngel.DCPump.LowATOChannel = Sync; // WP40 & SW 8
ReefAngel.DCPump.HighATOChannel = None; //
// DC pumps....................................
static int rmode;
byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
if (now()%1800==0 || changeMode==true) // Change every 30 mins (1800seconds) or controller reboot
changeMode=false;
ReefAngel.DCPump.Mode=ReefCrest;
// Night/Quiet mode
else if (hour()>=2 && hour()<8 ) // 2am to 8am
ReefAngel.DCPump.SetMode( Sine,35,10 );
else if (hour()>=15 && hour()<19) // 3pm and 7pm
ReefAngel.DCPump.SetMode( LongPulse,30,1 );
//Storm mode
else if (hour()>=1 && hour()<2) // 1am and 2am
ReefAngel.DCPump.SetMode( Else,80,15 );
else if (hour()>=11 && hour()<12) // 11am and 12pm
ReefAngel.DCPump.SetMode( LongPulse,95,2 );
else if (hour()>=21 && hour()<22) // 9pm and 10pm
ReefAngel.DCPump.SetMode( ReefCrest,85,15 );
} else {
InternalMemory.LCDID_write(255); //this line was added when i got a replacement RA+ board
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.DelayedOn(Port5 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
ReefAngel.DCPump.AntiSyncOffset = 125;
// Wavemaker
if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
ReefAngel.Relay.Off(Port6);
ReefAngel.WavemakerRandom( Port6, 30, 300 ); // random between 30 and 300 seconds
static int rmode;
changeMode=false;
ReefAngel.DCPump.Speed=75;
// Night/Quiet mode
ReefAngel.DCPump.SetMode( Gyre,40,10 );
ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
//Storm mode
ReefAngel.DCPump.SetMode( Else,70,15 );
ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
ReefAngel.DCPump.SetMode( ShortPulse,85,30 );
} else {
void SeasonalTemps ()
static int heatArray[][2] = { {782,786},// default in case of error in month=0 (June)
{760,764},//January (winter)
{764,768},//February (winter)
{765,769},//March (early spring)
{769,773},//April (spring)
{775,779},//May (spring)
{782,786},//June (early summer)
{789,793},//July (summer)
{796,800},//August (summer)
{786,790},//September (early fall)
{777,781},//October (fall)
{770,774},//November (fall)
{765,769} };//December (early winter)
ReefAngel.StandardHeater( Port3,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May)
{764,768},//January (winter)
{768,772},//February (winter)
{772,776},//March (early spring)
{776,780},//April (spring)
{780,784},//May (spring)
{784,788},//June (early summer)
{788,792},//July (summer)
{784,788},//August (summer)
{780,784},//September (early fall)
{776,780},//October (fall)
{772,776},//November (fall)
{768,772} };//December (early winter)
ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port5 );
SeasonalTemps ();
ReefAngel.ActinicLights( Port2 ); //ATS pump
ReefAngel.DayLights( Port3 ); //ATS light
ReefAngel.StandardLights( Port4, 23,0,7,0); //Skimmer 11pm-7am
ReefAngel.DCPump.LowATOChannel = Sync; // SW 8
//ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
// koralia 1150
// if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
// else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
// DC pumps
static int rmode;
changeMode=false;
ReefAngel.DCPump.Mode=Else;
} else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
ReefAngel.DCPump.Speed=40;
} else {
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.On( Port2 );
SeasonalTemps();
ReefAngel.ActinicLights( Port3 ); //Skimmer
ReefAngel.DayLights( Port4 ); //ATS light
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 ); //kalk dosing off 5pm-11pm
// koralia 1150
// DC pumps
static int rmode;
changeMode=false;
} else {
