Page 2 of 4
Re: Code for DC return pump
Posted: Thu Feb 19, 2015 1:04 pm
Looks like a leak somewhere.
Posted: Thu Feb 19, 2015 1:06 pm
by Ismaclst
I put silicone around the orange part and the coupling, but it didn't fix it. Other than the coupling that I glued on, where else could the leak be?
Posted: Thu Feb 19, 2015 1:15 pm
Use pvc glue
Posted: Thu Feb 19, 2015 4:29 pm
by Ismaclst
Ok I finally hooked up my pump to the RA and now it won't run. I have it plugged into the right dimming port and it doesn't do anything. I did notice that the light on the power supply for the pump flashes when its hooked up to the RA but when I use the stock controller it stays a steady light. Any ideas what could be wrong?
Posted: Fri Feb 20, 2015 4:41 am
by Ismaclst
Still having issues with my water level sensor for my ato and also now my one for the overflow. I caked on PVC cement on the fittings for both tubes. Only thing left is the tubing itself. I wouldn't think that would be the issue. What could it be?
Posted: Fri Feb 20, 2015 9:12 am
The light on the power supply shouldn't blink.
Does this new pump have the same connector? I'm not so sure anyone has used this pump yet. You are the first one I know of that is using the new pumps.
I wonder if they changed anything. Do you also have their WP powerheads?
Posted: Fri Feb 20, 2015 12:16 pm
by Ismaclst
It has the same connector that the jebao cable I bought off this site has. I used to have their wp powerheads on my old tank. Now I have the RW-4 but I'm using the stock controller with that.
Posted: Fri Feb 20, 2015 12:27 pm
Can you see if you can control the RW?
Posted: Fri Feb 20, 2015 12:44 pm
by Ismaclst
It does.
Posted: Fri Feb 20, 2015 2:03 pm
Humm.
So, they must have changed something to those pumps then.
Posted: Fri Feb 20, 2015 2:10 pm
by Ismaclst
Would you have any idea what it might be?
Posted: Fri Feb 20, 2015 2:35 pm
I just commented. They must have changed the pinout.
If you can control the other pump, we eliminated any issue with the controller or the cable. So, it can only be the pump.
Noone has used that pump yet. So you are the first one reporting that it can't be controlled.
Posted: Fri Feb 20, 2015 3:04 pm
by Ismaclst
Do you know the pinout for the old jebao dc pumps?
Posted: Fri Feb 20, 2015 3:40 pm
Posted: Fri Feb 20, 2015 5:10 pm
by Ismaclst
Ok, I opened up the stock controller box and saw that the three wires coming from the connector are brown, blue and yellow with green stripe. Blue was labeled U, Grn/Yel was labeled V, and brown was labeled W. I buzzed out the pins and looking at the male pins, the blue was just right of the key then grn/yel, and finally brown, which would be left of the key. I buzzed out the RA cable and the blue and brown pins are the opposite of the stock ones.
Posted: Fri Feb 20, 2015 6:39 pm
Ahh. There ya go.
Thanks a lot for the info!!!!
Posted: Fri Feb 20, 2015 6:51 pm
by Ismaclst
I thought I was on to something but I just opened the controller for my RW-4 and it's the same way as the DCT 6000.
Posted: Fri Feb 20, 2015 7:25 pm
by Ismaclst
Ok I decided to go back through all three and have another look. I wanted to see what colors where attached to + and - of all three. In the RA cable the blue is tied with the 24V+ and brown is tied with 24V-. In the RW-4 controller blue is tied with 24V- and brown is tied with 24V+. Even though the dct controller has the same pin layout as the RW-4, the blue and brown were not tied directly to 24V + and -. I don't know if this means anything or is helpful, just thought I would share.
Posted: Sat Feb 21, 2015 8:30 am
by Ismaclst
One more thing. I wanted to check the voltage on both controllers going out to the pump. The RW-4 was 24V from blue to brown and it fluctuated from 2-5V between blue to green. I tried checking this on the DCT-6000 but I couldn't get any voltage between any color so I decided to check frequency. From brown to green and brown to blue it showed 290 Hz. From Blue to green it was 4.2 kHz.
Posted: Sat Feb 21, 2015 9:26 am
Wow. So, definitely different.
Posted: Sat Feb 21, 2015 9:33 am
by Ismaclst
Do you think there is any hope of controlling these?
Posted: Sat Feb 21, 2015 9:38 am
I would need to get my hands on that controller to find out what they did.
Posted: Sat Feb 21, 2015 9:42 am
by Ismaclst
Thought this was kind of interesting.
http://digital-reefs.com/?p=9004
Posted: Sat Feb 21, 2015 9:45 am
There ya go. It explains it all. Unfortunately it doesn't seem like it will be possible.
Posted: Sat Feb 21, 2015 10:04 am
by Ismaclst
I guess it's what I get for being an early adopter.
Posted: Sat Feb 21, 2015 10:27 am
Sounds like it can do PWM if you can get in the controller and figure out where to connect
Posted: Sat Feb 21, 2015 12:28 pm
by Ismaclst
Wish I could figure that out.
Posted: Sat Feb 21, 2015 1:03 pm
Can you take a high res photo and email to me?
info@reefangel.com
Posted: Sat Feb 21, 2015 1:58 pm
by Ismaclst
Sent.
Posted: Sat Feb 21, 2015 3:36 pm
Yeah, I can't make nothing out of it, but it is definitely just like what the other blog mentioned.
The driving circuit is in the controller now. The maxspect gyre pumps are the same thing.
