Re: New to code ra and controls
Posted: Sun Oct 18, 2015 8:09 pm
Yep
https://forum.reefangel.com/
ReefAngel.DayLights( Port2 );
ReefAngel.PWM.Channel0PWMParabola();
ReefAngel.PWM.Channel1PWMParabola();
DaylightPWMValue=PWMSlopeHighRes(10,30,22,0,0,30,240,0);
DaylightPWMValue=GetChannelValueRaw(1);
ReefAngel.PWM.SetChannelRAW(1,DaylightPWMValue);
sun.setOffset(1,-1); // this will add an hour to the sunrise and remove an hour from sunset
#include <SunLocation.h>
SunLocation sun;
int DaylightPWMValue=0; // For cloud code
int Latitude=-18;
int Longitude=147;
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
sun.Init(Latitude,Longitude);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 7
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(12,00)
#define End_Cloud_Before NumMins(21,00)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Mega2,Mega,Mega};
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=4095;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
/*ReefAngel.LCD.Clear(255,0,120,132,132);
ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
int x=0;
else x=17;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
//ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
//ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
void Strike()
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. I'm using channel 1.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
if (n>cend) return (int) PWMStart;
ReefAngel.Relay.DelayedOn( Port3 );
ReefAngel.Relay.DelayedOn( Port4 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive());
ReefAngel.SingleATOLow( Port7 );
ReefAngel.PWM.SetChannel(0,0); // Make sure we're at 0% at night
ReefAngel.PWM.Channel0PWMParabola(); // Set Channel0 based on Parabola and Memory values
ReefAngel.PWM.Channel1PWMParabola(); // Set Chanenl1 based on Parabola and Memory values
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
CheckCloud(); // Apply cloud routine
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
ReefAngel.Portal( "troylong45" );
ReefAngel.DDNS( "209.18.47.61" ); // Your DDNS is troylong45-209.18.47.61.myreefangel.com
sun.setOffset(10,-10); // this will add an hour to the sunrise and remove an hour from sunsetCode: Select all
SunLocation sun;
int Latitude=-18;
int Longitude=-87;
ReefAngel.FeedingModePorts = Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
case Calm:
break;
case Mega:
// Send the trigger
Strike();
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
int x=0;
else x=17;
else x=35;
int x=0;
else x=57;
else x=75;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
ReefAngel.ActinicLights( Port1 | Port3 ); // actinicLight power
ReefAngel.DayLights( Port2 | Port4 ); // daylight power
ReefAngel.Relay.Set(Port5, ReefAngel.HighATO.IsActive()); // skimmer
ReefAngel.StandardHeater( Port6 ); // heater
ReefAngel.SingleATOLow( Port7 ); // auto top off
ReefAngel.Relay.On(Port8); // return
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMParabola();
CheckCloud();
ReefAngel.DDNS( "reef" ); // Your DDNS is troylong45-reef.myreefangel.com
ReefAngel.ActinicLights(Port1);
ReefAngel.ActinicLights(Port3);
ReefAngel.DayLights(Port2);
ReefAngel.DayLights(Port4);
ReefAngel.PWM.Channel1PWMParabola(); // Set Channel1 based on Parabola and Memory values
CheckCloud();
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit;
ReefAngel.Relay.On( Port7 ); // Return Pump
ReefAngel.ActinicLights( Port1 ); // Left Actinic Light power
ReefAngel.DayLights( Port2 ); // Left Day Light power
ReefAngel.ActinicLights( Port3 ); // Right Actinic Light power
ReefAngel.DayLights( Port4 ); // Right Day Light power
ReefAngel.StandardHeater( Port5 ); // Heater
ReefAngel.SingleATOLow( Port6 ); // Auto top off
ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
ReefAngel.PWM.Channel0PWMParabola(); // Left Actinic Light 0-10v
ReefAngel.PWM.Channel1PWMParabola(); // Left Day Light 0-10v
ReefAngel.PWM.Channel2PWMParabola(); // Right Actinic Light 0-10v
ReefAngel.PWM.Channel3PWMParabola(); // Right Day Light 0-10v
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
