Page 2 of 2
Re: Who is using Comcast???
Posted: Tue Dec 15, 2015 1:04 pm
by Sacohen
I can't seem to figure out how to use Tera Term or putty to even connect to the WiFi unit.
I removed the WiFi unit from the RA head unit and plugged the Serial to TTL cable into and into my PC.
Then when it was asking for an address to connect to I gave it the IP address that has been assigned to it (10.0.0.11).
Is there some thing else I should be using to connect to it.
Posted: Tue Dec 15, 2015 1:21 pm
You must choose Serial connection.
Posted: Tue Dec 15, 2015 2:00 pm
by Sacohen
I think I did, but I'll check again.
Posted: Tue Dec 29, 2015 8:23 am
by Sacohen
rimai wrote:Use Tera Term or putty and type $$$ after you connect at 57600 baud.
It will prompt with CMD>
Type enter and anything else and it will show the version.
Ok I connected with TeraTerm and typed $$$.
Got the CMD
If I hit "Enter: it returns <4.00>
If I try enter with the word anything (or any other word) it returns
ERR: ?-Cmd
<4.00>
Posted: Tue Dec 29, 2015 9:36 am
That means you are in command mode.
All you need to do is type the command you want to send.
What are you trying to change?
You can make a mistake. It won't recognize backspace.
If you type anything wrong, you will have to type it again.
Posted: Tue Dec 29, 2015 9:39 am
by Sacohen
I'm trying to find the firmware on the WiFi module, like you asked me too.
Posted: Tue Dec 29, 2015 9:41 am
4.00 is the firmware version
If you want to update, send command ftp u
Posted: Tue Dec 29, 2015 10:07 am
by Sacohen
Do you think I need to update it?
What is the current firmware?
Could that be why I'm having problems keeping connectivity?
Do I need to download the current firmware from anywhere or will it do it automatically when I enter ftp u?
Posted: Tue Dec 29, 2015 10:51 am
I think you should also look at the recent thread about fixing connection issues...
I'm still unclear what issues you are having. After our last review we were all set...is it still where it works on wifi and not elsewhere or the reverse?
Posted: Tue Dec 29, 2015 10:54 am
by Sacohen
It works on everything, when it works.
I lose connectivity about 2 times a week and I have to reboot the head unit to regain it.
Posted: Tue Dec 29, 2015 11:07 am
Try this?
Have to reset WIFI every Night
This thread addresses this same issue. The fix there works for most, but not all people.
[url=
http://forum.reefangel.com/viewtopic.ph ... 1&start=70]viewtopic.php?f=3&t=1871&start=70
http://forum.reefangel.com/viewtopic.php?t=5787#p50762
Posted: Tue Dec 29, 2015 9:12 pm
Sorry, I forgot to mention you also need save and reboot.
So:
The latest is version 4.41
