New IDE v1.6.8
troylong45
Re: New IDE v1.6.8
Post by troylong45 »
ok its loaded but the menu is all there but the menu label options are not in a human language the options seem to work tho how do i fix the readout of the options
and wifi is no longer working
i go to local ip address and the away dns thing and i get
HHTTTTPP//11..11  220000  OOKK
SSeerrvveerr::  RReeeeffAAnnggeell
CCaacchhee--CCoonnttrrooll::  nnoo--ssttoorree,,  nnoo--ccaacchhee,,  mmuusstt--rreevvaalliiddaattee
PPrraaggmmaa::  nnoo--ccaacchhee
AAcccceessss--CCoonnttrrooll--AAllllooww--OOrriiggiinn::  **
AAcccceessss--CCoonnttrrooll--AAllllooww--MMeetthhooddss::  GGEETT
CCoonnnneeccttiioonn::  cclloossee
CCoonntteenntt--TTyyppee::  tteexxtt//html
CCoonntteenntt--LLeennggtthh::  103
<<oobbjjeecctt  ttyyppee==tteexxtt//hhttmmll  ddaattaa==hhttttpp::////wwwwww..rreeeeffaannggeell..ccoomm//wwiiffii33//ccoonntteenntt..hhttmmll  wwiiddtthh==110000%%  hheeiigghhtt==9988%%>><<//oobbjjeecctt>>
 // Won't compile without this...
        // ReefAngel.DCPump.UseMemory=true;
        // Custom menus
        #include <avr/pgmspace.h>
        const char menu1_label[] PROGMEM = "Feeding Mode";
        const char menu2_label[] PROGMEM = "Water Change";
        const char menu3_label[] PROGMEM = "ATO Clear";
        const char menu4_label[] PROGMEM = "DC Pump Mode";
        const char menu5_label[] PROGMEM = "Overheat Clear";
        const char menu6_label[] PROGMEM = "PH Calibration";
        const char menu7_label[] PROGMEM = "Date / Time";
        const char menu8_label[] PROGMEM = "Refugium Light";
        const char *menu_items[] = {
        menu4_label, menu5_label, menu6_label, menu7_label, menu8_label
and the Initialize Menu
// Setup on controller startup/reset
          for (int a=0;a<SIZE(menu_items);a++)
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a); // Initialize Menu
and some other menu stuff i have not sure if important
 // Menu Code
void MenuEntry1() {
  ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
  ReefAngel.ATOClear();
void MenuEntry4() {
      NextDCPumpMode();
void MenuEntry5() {
  ReefAngel.SetupCalibratePH();
void MenuEntry6() {
  ReefAngel.OverheatClear();
void MenuEntry7() {
  ReefAngel.SetupDateTime();
void MenuEntry8() {
      // Toggle refugium light between on/auto.
      ReefAngel.Relay.Override(Refugium, ReefAngel.Relay.Status(Refugium)+1);
// Custom Main Screen
void DrawCustomMain() {
  const int NumScreens=4;
  static boolean drawGraph=true;
  // Main Header
  // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
  ReefAngel.LCD.DrawDate(5,2);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
      break;
    case 1: { DrawStatus(5,40); break; }
    case 2: { DrawSunMoon(5,40); break; }
    case 3: { DrawClouds(5,50); break; }
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  // ReefAngel.LCD.DrawDate(5,122);
  if (ReefAngel.Joystick.IsLeft()) {
    ScreenID--; drawGraph=true;
  if (ReefAngel.Joystick.IsRight()) {
    ScreenID++; drawGraph=true;
void DrawCustomGraph() {
  if (ScreenID==0)
    ReefAngel.LCD.DrawGraph(5, 40);
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  y+=12;
 // DC Pump Mode
      ReefAngel.LCD.DrawText(0,255,x,y,"DC:"); x+=20;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,t+(128-t),y+8);
      if (DCPumpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,x,y,"Constant");
      else if (DCPumpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Lagoon");
      else if (DCPumpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Reef Crest");
      else if (DCPumpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Short Pulse");
      else if (DCPumpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Long Pulse");
      else if (DCPumpMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Smart NTM");
      else if (DCPumpMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
      else if (DCPumpMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,x,y,"Night");
      else if (DCPumpMode == 10) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,0,x,y,"Storm");
      else if (DCPumpMode == 11) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,x,y,"Custom");
      y+=10; x=t;
      ReefAngel.LCD.DrawText(0,255,x,y,"DC Speed:"); x+=60;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpSpeed); x+=15;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,"/"); x+=10;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpDuration);
      y+=10; x=t;
  // Display Acclimation timer
  byte acclDay=InternalMemory.read(Mem_B_AcclDay);
  if (acclDay > 0) {
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
    ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
void DrawSunMoon(int x, int y) {
  char buf[16];
  int t=x;
  y+=2;
  /// Display Sunrise / Sunset
  sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
  sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
  y+=15; x=t;
  /// Display Moonrise / Moonset
  sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
  sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
  if (Moon.isUp) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
    else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
  y+=10; x=t;
  // MoonPhase
  ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
  ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,128,y+8);
  ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
  y+=10; x=t;
  // MoonLight %
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:"); x+=68;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor,x,y,1);
  x+=5*(intlength(ReefAngel.PWM.GetDaylightValue())+1);
  ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
void DrawRelays(int x, int y) {
  // Draw Relays
  y+=12;
  y+=12;
  TempRelay = ReefAngel.Relay.RelayDataE[1];
  TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
  TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
void DelayedOnFeedMode(byte relay) {
  static unsigned long startTime=now();
  if ( (startTime==LastStart || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) && ReefAngel.HighATO.IsActive()) {
    ReefAngel.Relay.On(relay);
    ReefAngel.Relay.DelayedOn(relay);
Re: New IDE v1.6.8
I see two things that are not correct.
Change this code:
To this:
Let me know if this fixes the menu issue.
The second is that the libraries packaged with this installer had bugs.
You need to update it manually :(
Download the latest dev branch here:
https://github.com/reefangel/Libraries/archive/dev.zip
Then replace everything inside \Documents\Arduino\libraries with the new one.
This should fix the wifi output duplicate characters you posted above.
troylong45
Re: New IDE v1.6.8
ok i deleted all the old libraries and pasted all the libraried-dev content into that folder after extracting it all
and i added the PROGMEM back and i get the error earlier befor when trying to verify the code
Arduino:  (Reef Angel compilation) v1.6.8 (Windows 8.1), Board: "Reef Angel Plus Controller"
Watchdog Timer
Version Menu
Dimming Expansion Module
Dimming Signal
Wifi Attachment
Custom Main Screen
Custom Variable
Extra Font - Numbers Only - Large Font (8x16 pixels)
Date/Time Setup Menu
Relay Expansion Module
Custom Menu
Moon Phase Label
DC Pump Control (Jebao/Tunze)
Number of Relay Expansion Modules: 2
Number of Menu Options: 8
sketch_edit_troyraino09112016_fix_menu_verify:42: error: variable 'menu_items' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Re: New IDE v1.6.8
Can you post the entire code?
troylong45
Re: New IDE v1.6.8
it works without the PROGMEM in the code but like i said the language is not right and i have not tested the wifi yet with the new lib. cus it wont verify and upload with PROGMEM added to the
to make it
Full code
    #include <SunLocation.h>
    #include <Tide.h>
    #include <Moon.h>
    #include <WiFiAlert.h>
        // Custom menus
        // Define Custom Memory Locations
        #define Mem_B_MoonOffset          100
        #define Mem_B_AtoHourInterval     101
        #define Mem_I_Latitude            108
        #define Mem_I_Longitude           110
        #define Mem_B_AcclRiseOffset      112
        #define Mem_B_AcclSetOffset       113
        #define Mem_B_AcclDay             114
        #define Mem_B_TideMin             117
        #define Mem_B_TideMax             118
        #define Mem_B_PumpOffset          119
        #define Mem_B_FeedingDCPump       120
        #define Mem_B_NightDCPump         121
        #define Mem_B_NightSpeed          122
        #define Mem_B_NightDuration       123
        #define Mem_B_NTMSpeed            124
        #define Mem_B_NTMDuration         125
        #define Mem_B_NTMDelay            126
        #define Mem_B_NTMTime             127
        #define Mem_B_TideMode            143
        #define Mem_B_CloudsEveryXDays    149
        #define Mem_B_CloudChancePerDay   150
        #define Mem_B_MinCloudDuration    151
        #define Mem_B_MaxCloudDuration    152
        #define Mem_B_MinCloudsPerDay     153
        #define Mem_B_MaxCloudsPerDay     154
        #define Mem_B_StartCloudAfterHour 155
        #define Mem_B_StartCloudAfterMin  156
        #define Mem_B_EndCloudBeforeHour  157
        #define Mem_B_EndCloudBeforeMin   158
        #define Mem_B_LightningChance     159
        #define Mem_B_LightMode           160
        #define Mem_B_LightOffset         161
        #define Mem_I_RiseOffset          162
        #define Mem_I_SetOffset           164
        #define Mem_B_AcclActinicOffset   166
        #define Mem_B_AcclDaylightOffset  167
        #define Mem_B_RandomMode          168
        #define Mem_B_GyreOffset          169
        #define Mem_B_MoonMode            170
        #define Mem_B_LightsOffPerc       171
        #define Mem_B_FeedingSpeed        172
        #define Mem_B_WCSpeed             173
        #define Mem_B_EnableStorm         178
        #define Mem_B_ForceRandomTide     179
        #define Mem_B_ResetMemory         199
        void init_memory() {
          // Initialize Custom Memory Locations
          InternalMemory.write(Mem_B_MoonOffset,15);           //mb100
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //mb101
          InternalMemory.write_int(Mem_I_Latitude,-21);        //mi108
          InternalMemory.write_int(Mem_I_Longitude,-147);      //mi110
          InternalMemory.write(Mem_B_AcclRiseOffset,1);        //mb112
          InternalMemory.write(Mem_B_AcclSetOffset,1);         //mb113
          InternalMemory.write(Mem_B_AcclDay,0);               //mb114
          InternalMemory.write(Mem_B_TideMin,10);              //mb117
          InternalMemory.write(Mem_B_TideMax,20);              //mb118
          InternalMemory.write(Mem_B_PumpOffset,80);           //mb119
          InternalMemory.write(Mem_B_FeedingDCPump,true);      //mb120
          InternalMemory.write(Mem_B_NightDCPump,false);       //mb121
          InternalMemory.write(Mem_B_NightSpeed,35);           //mb122
          InternalMemory.write(Mem_B_NightDuration,16);        //mb123
          InternalMemory.write(Mem_B_NTMSpeed,100);            //mb124
          InternalMemory.write(Mem_B_NTMDuration,50);          //mb125
          InternalMemory.write(Mem_B_NTMDelay,0);              //mb126
          InternalMemory.write(Mem_B_NTMTime,5);               //mb127
          InternalMemory.write(Mem_B_TideMode,0);              //mb143
          InternalMemory.write(Mem_B_CloudsEveryXDays,1);      //mb149
          InternalMemory.write(Mem_B_CloudChancePerDay,40);    //mb150
          InternalMemory.write(Mem_B_MinCloudDuration,5);      //mb151
          InternalMemory.write(Mem_B_MaxCloudDuration,10);     //mb152
          InternalMemory.write(Mem_B_MinCloudsPerDay,2);       //mb153
          InternalMemory.write(Mem_B_MaxCloudsPerDay,20);      //mb154
          InternalMemory.write(Mem_B_StartCloudAfterHour,12);  //mb155
          InternalMemory.write(Mem_B_StartCloudAfterMin,1);    //mb156
          InternalMemory.write(Mem_B_EndCloudBeforeHour,19);   //mb157
          InternalMemory.write(Mem_B_EndCloudBeforeMin,1);     //mb158
          InternalMemory.write(Mem_B_LightningChance,25);      //mb159
          InternalMemory.write(Mem_B_LightMode,1);             //mb160
          InternalMemory.write(Mem_B_LightOffset,10);          //mb161
          InternalMemory.write_int(Mem_I_RiseOffset,20);       //mi162
          InternalMemory.write_int(Mem_I_SetOffset,16);        //mi164
          InternalMemory.write(Mem_B_AcclActinicOffset,214);   //mb166
          InternalMemory.write(Mem_B_AcclDaylightOffset,214);  //mb167
          InternalMemory.write(Mem_B_RandomMode,true);         //mb168
          InternalMemory.write(Mem_B_GyreOffset,10);           //mb169
          InternalMemory.write(Mem_B_MoonMode,1);              //mb170
          InternalMemory.write(Mem_B_LightsOffPerc,1);         //mb171
          InternalMemory.write(Mem_B_FeedingSpeed,0);          //mb172
          InternalMemory.write(Mem_B_WCSpeed,0);               //mb173
          InternalMemory.write(Mem_B_ResetMemory,false);       //mb199
        #define NUMBERS_8x16
        #define Var_Tide         4
        #define Var_TideMode     5
        // Define Relay Ports by Name
        #define Return             1
        #define Heater             2
        #define Refugium           3
        #define MediaPump          4
        #define WhiteLeft          5
        #define BlueLeft           6
        #define Autotopoff         7
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
        Tide tide;
        // Jebao Variables
        byte DCPumpMode, DCPumpSpeed, DCPumpDuration;
        // For Cloud and preset code
        int DaylightPWMValue=0;
        int ActinicPWMValue=0;
        int DaylightPWMValue0=0;        // For cloud code, channel 0
        int DaylightPWMValue2=0;        // For cloud code, chennel 2
        int ActinicPWMValue1=0;        // For cloud code, channel 0
        int ActinicPWMValue3=0;        // For cloud code, chennel 2
        // Needs to be global for DrawCustomGraph()
        int ScreenID=1;
          ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
          ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit  | Port8Bit;
          ReefAngel.LightsOnPorts = Port3Bit | Port5Bit | Port6Bit;
          ReefAngel.OverheatShutoffPorts =  Port2Bit | Port4Bit;
        ReefAngel.Relay.On( Return ); // Return Pump
       randomSeed(now()/SECS_PER_DAY);
          if (InternalMemory.read(Mem_B_ResetMemory))
            init_memory();
        DelayedOnFeedMode(Return); // DelayedOn after feed mode change only
        ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(WhiteLeft));
        ReefAngel.SingleATO(true,Autotopoff, InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
        ReefAngel.Relay.Set(Skimmer, ReefAngel.HighATO.IsActive());
        ReefAngel.DCPump.ExpansionChannel[4] = AntiSync; // Left Jebao RW4
        ReefAngel.DCPump.ExpansionChannel[5] = Sync; // Right jebao rw4
        ReefAngel.StandardHeater(Heater);
          // Lighting and Flow
          SetSun();               // Setup Sun rise/set lighting
          AcclimateLED();         // Apply acclimation dimming
          SetMoon();              // Setup Moon rise/set lighting
          FillInMoon();           // Fill in 5% to 0% gap in main LEDs
          LEDPresets();
          CheckCloud();           //  Check for cloud and lightning.
          UpdateLED();
          SetTide();              // Set High/Low tide properties
          SetDCPump();                // Set Vortech modes
           ReefAngel.Portal( "troylong45" );
        ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
        void SetSun() {
          // Start acclimation routine
          int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
          int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
          // See if we are acclimating corals and decrease the countdown each day
          static boolean acclCounterReady=false;
          if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
          if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
            acclDay--;
            InternalMemory.write(Mem_B_AcclDay,acclDay);
          // End acclimation
          // Add some customizable offsets
          sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
          int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
          int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
          sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
          sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
          byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
          byte actinicOffset=InternalMemory.ActinicOffset_read();
          // Make sure light resets to zero at night.
          for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
          switch(InternalMemory.read(Mem_B_LightMode)) {
            case 0: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
              break;
            case 1: {
              // Daylights
              ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
              ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
              break;
          case 2: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
              break;
          case 3: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
              break;
          case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void SetMoon() {
      byte offset=InternalMemory.read(Mem_B_MoonOffset);
      byte startD=InternalMemory.read(Mem_B_PWMSlopeStartD);
      byte endD=InternalMemory.read(Mem_B_PWMSlopeEndD);
      byte timeD=InternalMemory.read(Mem_B_PWMSlopeDurationD);
      byte startA=InternalMemory.read(Mem_B_PWMSlopeStartA);
      byte endA=InternalMemory.read(Mem_B_PWMSlopeEndA);
      byte timeA=InternalMemory.read(Mem_B_PWMSlopeDurationA);
      time_t onTime=ScheduleTime(Moon.riseH, Moon.riseM,0);
      time_t offTime=ScheduleTime(Moon.setH, Moon.setM,0);
      time_t offsetOnTime=ScheduleTime(Moon.riseH, Moon.riseM,0)-(offset*60);
      time_t offsetOffTime=ScheduleTime(Moon.setH, Moon.setM,0)-(offset*60);
      byte actRiseH=(offsetOnTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actRiseM=((offsetOnTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      byte actSetH=(offsetOffTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actSetM=((offsetOffTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      static byte mp=MoonPhase();
      if (mp!=MoonPhase()) {
        InternalMemory.write(Mem_B_PWMSlopeEndD,mp);
        InternalMemory.write(Mem_B_PWMSlopeEndA,mp);
        mp=MoonPhase();
      moon_init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
      switch(InternalMemory.read(Mem_B_MoonMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
        case 1: {
          ReefAngel.PWM.SetDaylightRaw(PWMParabolaHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMParabolaHighRes(actRiseH,actRiseM,actSetH,actSetM, startD,endD,0));
          break;
      case 2: {
          ReefAngel.PWM.SetDaylightRaw(PWMSmoothRampHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSmoothRampHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
      case 3: {
          ReefAngel.PWM.SetDaylightRaw(PWMSigmoidHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSigmoidHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,0));
          break;
    void FillInMoon() {
      // Extend the sunrise/sunset to fill in gaps when fixtures shut off.
      int LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-(actinicOffset+(2*lightOffset));
      int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+(actinicOffset+(2*lightOffset));
      int moonVal=ReefAngel.PWM.GetDaylightValueRaw();
      int channelVal=PWMSlopeHighRes(onTime/60,onTime%60,offTime/60,offTime%60,0,100,lightOffset,0);
      if (ReefAngel.PWM.GetChannelValueRaw(1)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetDaylightValueRaw())
        ReefAngel.PWM.SetDaylightRaw(channelVal);
      if (ReefAngel.PWM.GetChannelValueRaw(3)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetActinicValueRaw())
        ReefAngel.PWM.SetActinicRaw(channelVal);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
    void AcclimateLED() {
          if (acclDay > 0) {
            float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
            float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
            float endPerc;
            endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
            ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
            ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
            ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
            ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1      Box2_Port1
#define LED_2to1      Box2_Port2
#define LED_3to1      Box2_Port3
#define LED_BLUE      Box2_Port4
#define LED_WHITE     Box2_Port5
#define LED_MOON      Box2_Port6
#define LED_STORM     Box2_Port7
#define TRIGGER_STORM Box2_Port8
        void resetRelayBox(byte ID) {
  // toggle all relays except for the one selected
  for (int i=Box2_Port1;i<=Box2_Port4;i++) {
    if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
  static byte lastPreset=0;
  DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
  ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
  DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
  ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
  if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
    if (lastPreset!=1) resetRelayBox(LED_1to1);
    DaylightPWMValue0=90*40.95;
    ActinicPWMValue1=10*40.95;
    DaylightPWMValue2=90*40.95;
    ActinicPWMValue3=10*40.95;
    lastPreset=1;
  if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
    if (lastPreset!=2) resetRelayBox(LED_1to1);
    DaylightPWMValue0=10*40.95;
    ActinicPWMValue1=90*40.95;
    DaylightPWMValue2=10*40.95;
    ActinicPWMValue3=90*40.95;
    lastPreset=2;
  if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
    if (lastPreset!=3) resetRelayBox(LED_2to1);
    DaylightPWMValue0=60*40.95;
    ActinicPWMValue1=40*40.95;
    DaylightPWMValue2=60*40.95;
    ActinicPWMValue3=40*40.95;
    lastPreset=3;
  if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
    if (lastPreset!=4) resetRelayBox(LED_2to1);
    DaylightPWMValue0=40*40.95;
    ActinicPWMValue1=60*40.95;
    DaylightPWMValue2=40*40.95;
    ActinicPWMValue3=60*40.95;
    lastPreset=4;
  if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
    if (lastPreset!=5) resetRelayBox(LED_3to1);
    DaylightPWMValue0=75*40.95;
    ActinicPWMValue1=25*40.95;
    DaylightPWMValue2=75*40.95;
    ActinicPWMValue3=25*40.95;
    lastPreset=5;
  if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
    if (lastPreset!=6) resetRelayBox(LED_3to1);
    DaylightPWMValue0=25*40.95;
    ActinicPWMValue1=75*40.95;
    DaylightPWMValue2=25*40.95;
    ActinicPWMValue3=75*40.95;
    lastPreset=6;
  if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
    if (lastPreset!=9) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=80*40.95;
    ActinicPWMValue3=80*40.95;
    lastPreset=9;
  if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
    if (lastPreset!=10) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
  if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
    if (lastPreset!=11) resetRelayBox(LED_WHITE);
    DaylightPWMValue0=80*40.95;
    ActinicPWMValue1=0;
    DaylightPWMValue2=80*40.95;
    ActinicPWMValue3=0;
    lastPreset=11;
  if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
    if (lastPreset!=12) resetRelayBox(LED_WHITE);
    lastPreset=12;
  if (ReefAngel.Relay.isMaskOn(LED_MOON)) {
    if (lastPreset!=13) resetRelayBox(LED_MOON);
    DaylightPWMValue=4095;
    ActinicPWMValue=4095;
    lastPreset=13;
  if (ReefAngel.Relay.isMaskOff(LED_MOON)) {
    if (lastPreset!=14) resetRelayBox(LED_MOON);
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
// Write updated values to the channels
void UpdateLED() {
  ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
  ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
  ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
  ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
  ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
  ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
  byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
  if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
  if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
void SetTide() {
  byte nightSpeed=InternalMemory.read(Mem_B_NightSpeed);
  byte tideMin=InternalMemory.read(Mem_B_TideMin);
  byte tideMax=InternalMemory.read(Mem_B_TideMax);
  // Set tide offsets
  tide.SetOffset(tideMin, tideMax);
  // Set tide speed. Slope in/out of Night Mode
  tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
    sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,DCPumpSpeed,120,nightSpeed+tideMin));
  // Show tide info on portal
  ReefAngel.CustomVar[Var_Tide]=tide.CalcTide();
void SetDCPump() {
  int ntmDelay=InternalMemory.read(Mem_B_NTMDelay)*60;
  int ntmTime=InternalMemory.read(Mem_B_NTMTime)*60;
  boolean nightDCPump=InternalMemory.read(Mem_B_NightDCPump);
  boolean feedingDCPump=InternalMemory.read(Mem_B_FeedingDCPump);
  static time_t t;
  ReefAngel.DCPump.FeedingSpeed=InternalMemory.read(Mem_B_FeedingSpeed);
  ReefAngel.DCPump.WaterChangeSpeed=InternalMemory.read(Mem_B_WCSpeed);
  DCPumpMode=InternalMemory.DCPumpMode_read();
  DCPumpSpeed=InternalMemory.DCPumpSpeed_read();
  DCPumpDuration=InternalMemory.DCPumpDuration_read();
  if ((now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) && feedingDCPump) {
    // Post feeding mode
    DCPumpMode=Smart_NTM;
    DCPumpSpeed=InternalMemory.read(Mem_B_NTMSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
  } else if (!sun.IsDaytime() && nightDCPump) {
    DCPumpMode=Night;
    DCPumpSpeed=InternalMemory.read(Mem_B_NightSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NightDuration);
    if (DCPumpMode!=Night && ReefAngel.DCPump.Mode==Night)
      ReefAngel.DCPump.SetMode(Night_Stop,0,0);
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    t=now(); // Run post feeding mode when this counter stops
  } else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
    // Not needed anymore.
    // ReefAngel.DCPump.SetMode(Constant,25,0);
    if ((DCPumpMode==Smart_NTM) || (DCPumpMode==ShortPulse)) DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
    (DCPumpMode==Custom) ? DCPumpCustom() : ReefAngel.DCPump.SetMode(DCPumpMode,DCPumpSpeed,DCPumpDuration);
void RefugiumLight() {if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
        ReefAngel.Relay.On(Refugium);} }
void DCPumpCustom() {
  static boolean changeMode;
  byte rcSpeed, rcSpeedAS;
  // Define new modes
  const int BHazard=15;
  const int RA_ReefCrest=16;
  const int RA_Lagoon=17;
  const int RA_TidalSwell=18;
  const int RA_Smart_NTM=19;
  const int RA_ShortPulse=20;
  const int RA_LongPulse=21;
  byte tideSpeed=tide.CalcTide();
  byte tideMode=InternalMemory.read(Mem_B_TideMode);
  float pumpOffset=(float) InternalMemory.read(Mem_B_PumpOffset)/100;
  byte RandomModes[]={ ReefCrest, TidalSwell, Lagoon, ShortPulse, LongPulse, BHazard, Else, Sine, Constant };
//  if (now()%SECS_PER_DAY!=0 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
//  if (now()%SECS_PER_DAY==0 && changeMode) {
  if (now()%(6*SECS_PER_HOUR)!=10 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
  if (now()%(6*SECS_PER_HOUR)==10 && changeMode) {
    tideMode=random(100)%sizeof(RandomModes);
    InternalMemory.write(Mem_B_TideMode,tideMode);
    changeMode=false;
  // Choose another random mode if triggered
  if (InternalMemory.read(Mem_B_ForceRandomTide)) {
    InternalMemory.write(Mem_B_ForceRandomTide,false);
  ReefAngel.CustomVar[Var_TideMode]=tideMode+1;
  switch (RandomModes[tideMode]) {
    case ReefCrest: {
      ReefAngel.DCPump.SetMode(ReefCrest,tideSpeed,DCPumpDuration);
      return;
      break;
    case Lagoon: {
      ReefAngel.DCPump.SetMode(Lagoon,tideSpeed,DCPumpDuration);
      return;
      break;
    case TidalSwell: {
      ReefAngel.DCPump.SetMode(TidalSwell,tideSpeed,DCPumpDuration);
      return;
      break;
    case Smart_NTM: {
      ReefAngel.DCPump.SetMode(Smart_NTM,tideSpeed,DCPumpDuration);
      return;
      break;
    case ShortPulse: {
      ReefAngel.DCPump.SetMode(ShortPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case LongPulse: {
      ReefAngel.DCPump.SetMode(LongPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case RA_ReefCrest: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case RA_Lagoon: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration,false);
      break;
    case RA_TidalSwell: {
      rcSpeed=TidalSwellMode(tideSpeed,true);
      rcSpeedAS=TidalSwellMode(tideSpeed,false);
      break;
    case RA_Smart_NTM: {
      rcSpeed=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_ShortPulse: {
      rcSpeed=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_LongPulse: {
      rcSpeed=LongPulseMode(0,tideSpeed,DCPumpDuration,true);
      rcSpeedAS=LongPulseMode(0,tideSpeed,DCPumpDuration,false);
      break;
    case Else: {
      rcSpeed=ElseMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ElseMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case BHazard: {
      rcSpeed=millis()%1200>800?tideSpeed:0;
      rcSpeedAS=millis()%1200<400?0:tideSpeed;
      break;
    case Sine: {
      rcSpeed=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,true);
      rcSpeedAS=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,false);
      break;
    default: {
      rcSpeed=tideSpeed;
      rcSpeedAS=tideSpeed;
      pumpOffset=(float) InternalMemory.read(Mem_B_GyreOffset)/100;
  ReefAngel.DCPump.SetMode(Custom,rcSpeedAS*pumpOffset,tide.isOutgoing());
  ReefAngel.DCPump.SetMode(Custom,rcSpeed,tide.isIncoming());
void NextDCPumpMode() {
      DCPumpMode++;
      if (DCPumpMode > 12) {
        DCPumpMode=0;
        DCPumpSpeed=50; // Constant
      } else if (DCPumpMode == 1) {
        DCPumpSpeed=40; // Lagoon
      } else if (DCPumpMode == 2) {
        DCPumpSpeed=45; // Reef Crest
      } else if (DCPumpMode == 3) {
        DCPumpSpeed=55; DCPumpDuration=10; // Short Pulse
      } else if (DCPumpMode == 4) {
        DCPumpSpeed=55; DCPumpDuration=20; // Long Pulse
      } else if (DCPumpMode == 5) {
        DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration); // Smart_NTM
      } else if (DCPumpMode == 6) {
        DCPumpSpeed=50; DCPumpDuration=10; // Smart_TSM
      } else if (DCPumpMode == 7) {
        DCPumpMode=9; // Night
      } else if (DCPumpMode == 10) {
        DCPumpSpeed=65; DCPumpDuration=5; // Storm
      } else if (DCPumpMode == 11) {
        DCPumpSpeed=45; DCPumpDuration=10; // Custom
      if (DCPumpMode!=InternalMemory.DCPumpMode_read())
        InternalMemory.DCPumpMode_write(DCPumpMode);
      if (DCPumpSpeed!=InternalMemory.DCPumpSpeed_read())
        InternalMemory.DCPumpSpeed_write(DCPumpSpeed);
      if (DCPumpDuration!=InternalMemory.DCPumpDuration_read())
        InternalMemory.DCPumpDuration_write(DCPumpDuration);
        // Menu Code
void MenuEntry1() {
void MenuEntry2() {
void MenuEntry3() {
void MenuEntry4() {
      NextDCPumpMode();
void MenuEntry5() {
void MenuEntry6() {
void MenuEntry7() {
void MenuEntry8() {
  // Main Header
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      break;
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  if (ScreenID==0)
  char buf[16];
  // Temp and PH
  y+=2;
  y+=6;
  y+=5;
  int t=x;
  y+=12;
 // DC Pump Mode
      y+=10; x=t;
      y+=10; x=t;
  if (acclDay > 0) {
  char buf[16];
  int t=x;
  y+=2;
  y+=15; x=t;
  y+=10; x=t;
  // MoonPhase
  y+=10; x=t;
  // MoonLight %
  // Draw Relays
  y+=12;
  y+=12;
#define Clouds_Every_X_Days InternalMemory.read(Mem_B_CloudsEveryXDays)
#define Cloud_Chance_per_Day InternalMemory.read(Mem_B_CloudChancePerDay)
// Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration InternalMemory.read(Mem_B_MinCloudDuration)
#define Max_Cloud_Duration InternalMemory.read(Mem_B_MaxCloudDuration)
#define Min_Clouds_per_Day InternalMemory.read(Mem_B_MinCloudsPerDay)
#define Max_Clouds_per_Day InternalMemory.read(Mem_B_MaxCloudsPerDay)
#define Start_Cloud_After NumMins(InternalMemory.read(Mem_B_StartCloudAfterHour),InternalMemory.read(Mem_B_StartCloudAfterMin))
#define End_Cloud_Before NumMins(InternalMemory.read(Mem_B_EndCloudBeforeHour),InternalMemory.read(Mem_B_EndCloudBeforeMin))
#define Lightning_Chance_per_Cloud InternalMemory.read(Mem_B_LightningChance)
// Add Random Lightning modes
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = {Slow};
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      // Commenting out to see if it's interfering with our other seed.
      // randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (ReefAngel.Relay.isMaskOn(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,false);
  if (ReefAngel.Relay.isMaskOff(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,true);
  if (InternalMemory.read(Mem_B_EnableStorm)) return;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(TRIGGER_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(TRIGGER_STORM);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(TRIGGER_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      ReefAngel.CustomVar[0]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      ReefAngel.CustomVar[1]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    ReefAngel.CustomVar[2]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[7]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Re: New IDE v1.6.8
Ahh. Sorry, I gave you the wrong stuff.
It needs to be:
PROGMEM const char * const menu_items[] = {
troylong45
Re: New IDE v1.6.8
good to go looks like ill keep an eye on things thanks rimai
Re: New IDE v1.6.8
Do you have the updated source/changes available on github? I was going to build/compile it for Linux (since that's where I do my main development/testing).
Re: New IDE v1.6.8
yeap. should be there.
Re: New IDE v1.6.8
rimai wrote:yeap. should be there.
ok. i looked at the arduino project under the reefangel account and your branch was from 2013. so I was just curious.
edit: sorry I missed the reefangel branch and only saw the reefangel-1.5.x branch.
I see the changes now I think. ☺️
Re: New IDE v1.6.8
Sorry. It was committed to my local git and I never pushed it to github
I just did now
Re: New IDE v1.6.8
rimai wrote:Sorry. It was committed to my local git and I never pushed it to github
I just did now
ok. no worries. thanks!
Re: New IDE v1.6.8
I'm getting some errors when I installed the mac version listed in the OP.
Here's the errors I get:
Arduino:  (Reef Angel compilation) v1.6.8 (Mac OS X), Board: "Reef Angel Plus Controller"
Watchdog Timer
Version Menu
Wifi Attachment
Dimming Signal
2014 Main Screen
Salinity Expansion Module
Water Level Expansion Module
Simple Menu
failed MSpanList_Insert 0x30c6c0 0x399ecd5329b9 0x0
fatal error: MSpanList_Insert
runtime stack:
runtime.MSpanList_Insert(0x2c7e08, 0x30c6c0)
	/usr/local/go/src/runtime/mheap.c:692 +0x8f
runtime.MHeap_Alloc(0x2c6c20, 0x1, 0x1000000002b, 0x10359)
	/usr/local/go/src/runtime/mheap.c:240 +0x66
runtime.MCentral_CacheSpan(0x2d05b8, 0x194ec0)
	/usr/local/go/src/runtime/mcentral.c:85 +0x167
runtime.MCache_Refill(0x307000, 0x10000002b, 0x30b548)
	/usr/local/go/src/runtime/mcache.c:90 +0xa0
goroutine 1 [running]:
runtime.switchtoM()
	/usr/local/go/src/runtime/asm_amd64.s:198 fp=0xc208030fe8 sp=0xc208030fe0
runtime.mallocgc(0x1000, 0x159ce0, 0x1, 0x28)
	/usr/local/go/src/runtime/malloc.go:178 +0x849 fp=0xc208031098 sp=0xc208030fe8
runtime.newarray(0x159ce0, 0x1000, 0x307000)
	/usr/local/go/src/runtime/malloc.go:365 +0xc1 fp=0xc2080310d0 sp=0xc208031098
runtime.makeslice(0x151960, 0x1000, 0x1000, 0x0, 0x0, 0x0)
	/usr/local/go/src/runtime/slice.go:32 +0x15c fp=0xc208031118 sp=0xc2080310d0
os.(*File).readdirnames(0xc208040068, 0xffffffffffffffff, 0x0, 0x0, 0x0, 0x0, 0x0)
	/usr/local/go/src/os/dir_unix.go:23 +0xd9 fp=0xc208031208 sp=0xc208031118
os.(*File).Readdirnames(0xc208040068, 0xffffffffffffffff, 0x0, 0x0, 0x0, 0x0, 0x0)
	/usr/local/go/src/os/doc.go:134 +0x9e fp=0xc208031248 sp=0xc208031208
arduino.cc/builder/gohasissues.readDirNames(0xc208034040, 0x3e, 0x0, 0x0, 0x0, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/gohasissues/go_has_issues.go:93 +0xdd fp=0xc2080312b8 sp=0xc208031248
arduino.cc/builder/gohasissues.walk(0xc208034040, 0x3e, 0x318c98, 0xc208066460, 0xc2080315d8, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/gohasissues/go_has_issues.go:62 +0x1bf fp=0xc2080313f0 sp=0xc2080312b8
arduino.cc/builder/gohasissues.walk(0x7fff5fbffb42, 0x3a, 0x318c98, 0xc208036c80, 0xc2080315d8, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/gohasissues/go_has_issues.go:75 +0x516 fp=0xc208031528 sp=0xc2080313f0
arduino.cc/builder/gohasissues.Walk(0x7fff5fbffb42, 0x3a, 0xc2080315d8, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/gohasissues/go_has_issues.go:46 +0xf2 fp=0xc208031590 sp=0xc208031528
arduino.cc/builder.findBuiltinToolsVersionsFile(0x7fff5fbffb42, 0x3a, 0x0, 0x0, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/tools_loader.go:163 +0xa0 fp=0xc2080315f0 sp=0xc208031590
arduino.cc/builder.(*ToolsLoader).Run(0x2c0908, 0xc20803c510, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/tools_loader.go:50 +0x1ec fp=0xc208031788 sp=0xc2080315f0
arduino.cc/builder.(*ContainerSetupHardwareToolsLibsSketchAndProps).Run(0x2c0908, 0xc20803c510, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/container_setup.go:59 +0x6b8 fp=0xc208031978 sp=0xc208031788
arduino.cc/builder.runCommands(0xc20803c510, 0xc208031b90, 0x1d, 0x1d, 0x19501, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:187 +0x139 fp=0xc208031a08 sp=0xc208031978
arduino.cc/builder.(*Builder).Run(0xc208031d88, 0xc20803c510, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:118 +0xef7 fp=0xc208031d68 sp=0xc208031a08
arduino.cc/builder.RunBuilder(0xc20803c510, 0x0, 0x0)
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/src/arduino.cc/builder/builder.go:218 +0x49 fp=0xc208031d90 sp=0xc208031d68
main.main()
	/Users/jenkins/jenkins/workspace/arduino-builder-macosx/main.go:320 +0x1eb2 fp=0xc208031f98 sp=0xc208031d90
runtime.main()
	/usr/local/go/src/runtime/proc.go:63 +0xf3 fp=0xc208031fe0 sp=0xc208031f98
runtime.goexit()
	/usr/local/go/src/runtime/asm_amd64.s:2232 +0x1 fp=0xc208031fe8 sp=0xc208031fe0
arduino-builder returned 2
Error compiling for board Reef Angel Plus Controller.
I replaced my Arduino folder inside Documents with the new one from the DMG file.
I copied the Arduino15 folder into the Library folder.
I replaced the original Arduino app with the new one from the DMG file.
I launched the arduino program and it shows the 1.6.8 Reef Angel compilation in the title bar. I have the library manager, etc viewable. I originally got this error when I tried to compile my existing sketch file. So I just used the wizard and generated a simple file and this is the same output.
Before I dive into it any further, anybody got any tips on this?
Re: New IDE v1.6.8
Hummm.
I don't get this error here and can't replicate :(
Re: New IDE v1.6.8
Do you happen to have Sierra OSX?
I may need to update the IDE again and recompile :(
https://github.com/arduino/Arduino/issues/5360
Re: New IDE v1.6.8
rimai wrote:Do you happen to have Sierra OSX?
yup. I'm running the latest version. it's not a big deal or big rush. I can still use the webwizard and I'm working on getting it to work under my Linux/Debian desktop (just going slow).
Re: New IDE v1.6.8
I have the latest built for Linux but am missing some of the changes for us. I'm missing the boards.txt custom file and maybe some other stuff. my list of boards is all of the arduino boards (I'm assuming the defaults). is this file in github? are there certain files or certain things you do during the build process to create the package/exe for distribution?
Re: New IDE v1.6.8
board.txt
menu.cpu=Processor
RA.name=Reef Angel Controller w/ optiboot
RA.vid.0=0x2341
RA.pid.0=0x0043
RA.vid.1=0x2341
RA.pid.1=0x0001
RA.vid.2=0x2A03
RA.pid.2=0x0043
RA.vid.3=0x2341
RA.pid.3=0x0243
RA.upload.tool=avrdude
RA.upload.protocol=arduino
RA.upload.maximum_size=32256
RA.upload.maximum_data_size=2048
RA.upload.speed=115200
RA.bootloader.tool=avrdude
RA.bootloader.low_fuses=0xFF
RA.bootloader.high_fuses=0xDE
RA.bootloader.extended_fuses=0x05
RA.bootloader.unlock_bits=0x3F
RA.bootloader.lock_bits=0x0F
RA.bootloader.file=reefangel/optiboot_ReefAngel.hex
RA.build.mcu=atmega328p
RA.build.f_cpu=16000000L
RA.build.board=AVR_RA
RA.build.core=arduino
RA.build.variant=standard
diecimila.name=Reef Angel Controller
diecimila.upload.tool=avrdude
diecimila.upload.protocol=arduino
diecimila.upload.maximum_size=30720
diecimila.upload.maximum_data_size=2048
diecimila.upload.speed=57600
diecimila.bootloader.tool=avrdude
diecimila.bootloader.low_fuses=0xFF
diecimila.bootloader.unlock_bits=0x3F
diecimila.bootloader.lock_bits=0x0F
diecimila.bootloader.high_fuses=0xDA
diecimila.bootloader.extended_fuses=0x05
diecimila.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
diecimila.build.mcu=atmega328p
diecimila.build.f_cpu=16000000L
diecimila.build.board=AVR_DUEMILANOVE
diecimila.build.core=arduino
diecimila.build.variant=standard
RAPlus.name=Reef Angel Plus Controller
RAPlus.vid.0=0x2341
RAPlus.pid.0=0x0010
RAPlus.vid.1=0x2341
RAPlus.pid.1=0x0042
RAPlus.vid.2=0x2A03
RAPlus.pid.2=0x0010
RAPlus.vid.3=0x2A03
RAPlus.pid.3=0x0042
RAPlus.vid.4=0x2341
RAPlus.pid.4=0x0210
RAPlus.vid.5=0x2341
RAPlus.pid.5=0x0242
RAPlus.upload.tool=avrdude
RAPlus.upload.protocol=wiring
RAPlus.upload.maximum_size=253952
RAPlus.upload.maximum_data_size=8192
RAPlus.upload.speed=115200
RAPlus.bootloader.tool=avrdude
RAPlus.bootloader.low_fuses=0xFF
RAPlus.bootloader.unlock_bits=0x3F
RAPlus.bootloader.lock_bits=0x0F
RAPlus.bootloader.high_fuses=0xD8
RAPlus.bootloader.extended_fuses=0xFD
RAPlus.bootloader.file=reefangel/stk500boot_RAPlus.hex
RAPlus.build.mcu=atmega2560
RAPlus.build.f_cpu=16000000L
RAPlus.build.board=AVR_MEGA2560
RAPlus.build.core=arduino
RAPlus.build.variant=RAPlus
RAStar.name=Reef Angel Star Controller
RAStar.vid.0=0x2341
RAStar.pid.0=0x0010
RAStar.vid.1=0x2341
RAStar.pid.1=0x0042
RAStar.vid.2=0x2A03
RAStar.pid.2=0x0010
RAStar.vid.3=0x2A03
RAStar.pid.3=0x0042
RAStar.vid.4=0x2341
RAStar.pid.4=0x0210
RAStar.vid.5=0x2341
RAStar.pid.5=0x0242
RAStar.upload.tool=avrdude
RAStar.upload.protocol=wiring
RAStar.upload.maximum_size=253952
RAStar.upload.maximum_data_size=8192
RAStar.upload.speed=115200
RAStar.bootloader.tool=avrdude
RAStar.bootloader.low_fuses=0xFF
RAStar.bootloader.unlock_bits=0x3F
RAStar.bootloader.lock_bits=0x0F
RAStar.bootloader.high_fuses=0xD8
RAStar.bootloader.extended_fuses=0xFD
RAStar.bootloader.file=reefangel/stk500boot_RA_Star.hex
RAStar.build.mcu=atmega2560
RAStar.build.f_cpu=16000000L
RAStar.build.board=AVR_MEGA2560
RAStar.build.core=arduino
RAStar.build.variant=RAPlus
Re: New IDE v1.6.8
The exe for windows is done with Inno Setup to create an installation file.
It's not part of the build process.
The files that the installer goes through and places in the proper spots are:
Source: "arduino-1.6.8\*"; DestDir: "{app}"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "Wifi_Utility.exe"; DestDir: "{app}";
Source: "INO\*"; DestDir: "{userdocs}\Arduino\Example Codes\"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "RA_Preloaded\*"; DestDir: "{userdocs}\Arduino\RA_Preloaded\"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "libraries\*"; DestDir: "{userdocs}\Arduino\libraries\"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "tools\*"; DestDir: "{userdocs}\Arduino\tools\"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "update\*"; DestDir: "{userdocs}\Arduino\update\"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "drivers\*"; DestDir: "{app}\drivers"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "lib\*"; DestDir: "{app}\lib"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "data\*"; DestDir: "{app}\data"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "Arduino15\*"; DestDir: "{localappdata}\Arduino15"; Flags: ignoreversion recursesubdirs createallsubdirs
Source: "preferences.txt"; DestDir: "{userappdata}\Arduino";
Mostly the example codes and wizard files.
Re: New IDE v1.6.8
rimai wrote:The exe for windows is done with Inno Setup to create an installation file.
awesome! thanks. that looks like it will help me build/create a package for Linux to be "unzipped" and ran. :mrgreen:
Re: New IDE v1.6.8
I did some further digging into everything to get a build working for me.
I tested both of the installers linked in the OP and I came across some stuff:
  • None of the installers contain the RA* board. (I have to use the boards.txt file that was provided in the discussion.)
  • The RA* bootloader is not included in the github repository.
I know that it's not a big deal but I did notice in the boards.txt file that the bootloader folder has changed a little and there's a reefangel folder that contains all the bootloaders for simplicity.
I'm assuming that the bootloader files were just copied and renamed to the appropriate RAPlus and RAStar hex files. Is there anything else different with them? Or can I just create the Star file using the same RAPlus file? I'm assuming this is safe and the way I need to handle it based on other discussions.
Re: New IDE v1.6.8
SUCCESS!!
I now have a working arduino build for 64bit linux and uses the latest dev libraries and can talk to the RA* just fine. Woohoo!
Now I can get some of these fixes made and posted. :ugeek:
Re: New IDE v1.6.8
Yeah, the bootloader is only required once.
We never had to burn bootloader in the past, but if someone were to create RA* from scratch, they would need that.
Attached is a revised board.txt and the bootloader. I changed the name to comply with what I had in here.
RA Star boards and bootloader.zip
(8.79 KiB) Downloaded 672 times
Re: New IDE v1.6.8
cool. i didn't think we needed to worry about it because it was already set. however arduino wouldn't let me compile and upload without having it.
i remember with the original ra when you switched bootloaders and we had to burn the optiboot one....i still have my programmer from back then for it....never had to use it since either. :-)
Naptalene
Re: New IDE v1.6.8
Post by Naptalene »
Hi,
When I use the Dev IDE and the web wizard, my custom labels don't come up on the head unit and my DCpump mode doesn't reflect the correct mode on startup. The DCpump mode is a bit of a non-issue as once I re-set it via the U-App it's fine.
If I revert to the standard IDE (1.1.3 not the dev) it all loads as expected.
Have I missed something?
Re: New IDE v1.6.8
We were running into issues with the labels being declared the way they were.
So everything got moved to RA_CustomsLabels.h file.
You need to manually edit it if you are using the Arduino IDE.
The web wizard needs to be updated still. It's on my todo list.
Naptalene
Re: New IDE v1.6.8
Post by Naptalene »
Ah, ok cool, thanks :)
I have gotten a second RA system for my new build and I've started coding it. Am I correct that the web wizard and IDEv1.6.8 are where the system is headed? So it makes sense to keep programming with one of those two instead of the older standard version?
EDIT- Geez, after using the WebPlugin, the IDE is EXTREMELY ugly and bright lol. It's much more pleasant to use the webplug.
Re: New IDE v1.6.8
I think you are better off using the web wizard from now on.
Naptalene
Re: New IDE v1.6.8
Post by Naptalene »
Ok Cool, thanks :)
Re: New IDE v1.6.8
I know this is on your list of items, but just checking on the status of this. I'm running High Sierra OSX as my main setup for now (and probably will be for several months).
I can switch to running a VM of linux to get things working for me (since I already had/have it running under linux).
Anyways, just curious. :?:
