Thanks!!!rimai wrote:Use $ instead of space.
Portal issues?
Civics14
Paul_Velasco
Re: Portal issues?
Tried updating FW no Bueno
Now absolutely no data. Live data working but no historical data
Armetas
Re: Portal issues?
Hello, sorry, but seems that I have same kind of problem, as portal data is not updating anymore.
Even live data is old. Connection is good, even last update data changes, but values remains the same, all the web charts also are empty.
From reef angel perspective - nothing has changed half a year.
I'm using RA for more than 2,5 years and this is first time when portal does not work at all.
Maybe someone can check what is wrong or help me?
ucez
Re: Portal issues?
Just realized that I'm having the same problem again...Portal says that the last update was 12/23, but I'm pretty sure I get updates between then and now...
Re: Portal issues?
If last update is 12/23, you need to update the wifi attachment module with the macro to point to the new server.
ucez
Re: Portal issues?
With this one? http://forum.reefangel.com/viewtopic.php?f=3&t=4601 If so, did that back in early Dec when first started having problems. It was working for a couple of weeks.
Re: Portal issues?
Do it again.
A few posts back: http://forum.reefangel.com/viewtopic.php?p=54096#p54096
ucez
Re: Portal issues?
Updated wifi, still not working. Wifi module works fine, just not connecting with RA server.
ucez
Re: Portal issues?
Sure. How do I do that?
Sent from my LG-V410 using Tapatalk
Armetas
Re: Portal issues?
For me issue was solved after I've run the macro that was mentioned in this post. Seems that it was only needed to change server address
Re: Portal issues?
Use tera term and connect to the serial port at 57600 baud.
Then type $$$ to enter command mode.
It should respond with CMD
Type get e and post what you see on the screen.
davaraj
Re: Portal issues?
I too had the same problem. Last update was 23rd December 2016. Ran the macro once and now its updating correctly.
Dr Davaraj
Dr Davaraj
ucez
Re: Portal issues?
I can't do it today, buy should be able to tomorrow.
ucez
Re: Portal issues?
Here it is
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
get e
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Re: Portal issues?
It is still the old server.
Either you have the old macro or the macro didn't run correctly.
Give it a try again. Make sure to download the macro from the website. Do not use any one that you may have downloaded a few months back.
ucez
Re: Portal issues?
Looks like it is working now. Thanks!
sabo
Re: Portal issues?
So is this a matter of changing the reef angel server IP? I don't use the wifi attachment, ive got the ethernet module. Only reason I came on here today is because this morning I noticed that my MH were not on at the right time. Checked the app, and both my MH and my heaters were set to off manually. This worried me so came here and checked portal only to find out last update was 24/12.
Re: Portal issues?
Yes, just change the server ip address in the code for your ethernet module
Paul_Velasco
Re: Portal issues?
still getting blue light of death
This is after running Macro in TeraTerm
ERR: ?-Cmd
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=192.168.1.3:2006
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=testing2
Chan=0
ExtAnt=0
Join=1
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=a01b02c03d
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>-
Paul_Velasco
Paul_Velasco
ucez
Re: Portal issues?
Ahhh, back to the same problem, no longer getting access to the portal. Looks like it's been going on since March 24.
ucez
Re: Portal issues?
here is the tera term dump
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0-
ucez
Re: Portal issues?
No, just tried to reload wifi macro, but same thing.
Re: Portal issues?
Everything looks ok with the wifi attachment.
Let's get another log.
Connect the USB-TTL cable to RA.
Open Arduino
Make sure you have the correct serial port selected
Go to Tools->Serial Monitor
Make sure you have 57600 baud. If not, you will need to change to 57600 and close serial monitor and open again
Wait 5 minutes for RA to send data
Send whatever you get on the serial monitor window
Open Arduino
