Page 2 of 3
Re: Portal issues?
Posted: Sat Dec 31, 2016 5:34 pm
by Civics14
rimai wrote:Use $ instead of space.
Thanks!!!
Re: Portal issues?
Posted: Mon Jan 02, 2017 11:39 am
by Paul_Velasco
Tried updating FW no Bueno
Now absolutely no data. Live data working but no historical data
Re: Portal issues?
Posted: Mon Jan 02, 2017 11:40 am
Can you post the get e log?
Re: Portal issues?
Posted: Sat Jan 07, 2017 4:06 am
by Armetas
Hello, sorry, but seems that I have same kind of problem, as portal data is not updating anymore.
Even live data is old. Connection is good, even last update data changes, but values remains the same, all the web charts also are empty.
From reef angel perspective - nothing has changed half a year.
I'm using RA for more than 2,5 years and this is first time when portal does not work at all.
Maybe someone can check what is wrong or help me?
Re: Portal issues?
Posted: Sat Jan 07, 2017 10:30 am
Did you update the WiFi attachment with the macro?
Re: Portal issues?
Posted: Sun Jan 08, 2017 6:06 am
by ucez
Just realized that I'm having the same problem again...Portal says that the last update was 12/23, but I'm pretty sure I get updates between then and now...
Re: Portal issues?
Posted: Sun Jan 08, 2017 10:40 am
If last update is 12/23, you need to update the wifi attachment module with the macro to point to the new server.
Re: Portal issues?
Posted: Sun Jan 08, 2017 11:24 am
by ucez
With this one? http://forum.reefangel.com/viewtopic.php?f=3&t=4601 If so, did that back in early Dec when first started having problems. It was working for a couple of weeks.
Re: Portal issues?
Posted: Sun Jan 08, 2017 2:03 pm
Re: Portal issues?
Posted: Sun Jan 08, 2017 5:18 pm
by ucez
Updated wifi, still not working. Wifi module works fine, just not connecting with RA server.
Re: Portal issues?
Posted: Sun Jan 08, 2017 9:07 pm
Can you post the "get e" dump?
Re: Portal issues?
Posted: Tue Jan 10, 2017 8:13 am
by ucez
Sure. How do I do that?
Sent from my LG-V410 using Tapatalk
Re: Portal issues?
Posted: Tue Jan 10, 2017 10:31 am
by Armetas
For me issue was solved after I've run the macro that was mentioned in this post. Seems that it was only needed to change server address
Re: Portal issues?
Posted: Tue Jan 10, 2017 11:15 am
Use tera term and connect to the serial port at 57600 baud.
Then type $$$ to enter command mode.
It should respond with CMD
Type get e and post what you see on the screen.
Re: Portal issues?
Posted: Wed Jan 11, 2017 3:41 am
by davaraj
I too had the same problem. Last update was 23rd December 2016. Ran the macro once and now its updating correctly.
Dr Davaraj
Re: Portal issues?
Posted: Wed Jan 11, 2017 2:05 pm
by ucez
I can't do it today, buy should be able to tomorrow.
Re: Portal issues?
Posted: Thu Jan 12, 2017 3:46 pm
by ucez
Here it is
get e
wifly-GSX Ver: 4.41 Build: r1057, Jan 17 2014 10:26:29 on RN-131
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
Lease=86400
FTP=198.175.253.161:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.41>
Re: Portal issues?
Posted: Thu Jan 12, 2017 3:57 pm
It is still the old server.
Either you have the old macro or the macro didn't run correctly.
Give it a try again. Make sure to download the macro from the website. Do not use any one that you may have downloaded a few months back.
Re: Portal issues?
Posted: Thu Jan 12, 2017 4:20 pm
by ucez
Looks like it is working now. Thanks!
Re: Portal issues?
Posted: Sun Jan 15, 2017 7:46 pm
by sabo
So is this a matter of changing the reef angel server IP? I don't use the wifi attachment, ive got the ethernet module. Only reason I came on here today is because this morning I noticed that my MH were not on at the right time. Checked the app, and both my MH and my heaters were set to off manually. This worried me so came here and checked portal only to find out last update was 24/12.
Re: Portal issues?
Posted: Mon Jan 16, 2017 11:42 am
Yes, just change the server ip address in the code for your ethernet module
Re: Portal issues?
Posted: Tue Jan 31, 2017 6:55 pm
by Paul_Velasco
still getting blue light of death
This is after running Macro in TeraTerm
ERR: ?-Cmd
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=102
Reboot=0
IF=DOWN
DHCP=ON
IP=192.168.1.3:2006
NM=255.255.255.0
GW=192.168.1.1
HOST=104.36.18.155:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=testing2
Chan=0
ExtAnt=0
Join=1
Auth=WPA1
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=a01b02c03d
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
<4.00>
Re: Portal issues?
Posted: Tue Jan 31, 2017 7:11 pm
by Paul_Velasco
Had to run WIFI utility and all is well now
Re: Portal issues?
Posted: Tue Jan 31, 2017 11:38 pm
You never edited the file with your ssid and password.
Re: Portal issues?
Posted: Wed Feb 01, 2017 3:28 pm
by Paul_Velasco
Yeah I struggle with following directions some times - hahahahah
Re: Portal issues?
Posted: Mon Apr 10, 2017 3:04 pm
by ucez
Ahhh, back to the same problem, no longer getting access to the portal. Looks like it's been going on since March 24.
Re: Portal issues?
Posted: Mon Apr 10, 2017 3:20 pm
by ucez
here is the tera term dump
SSID=WiFly-GSX-32
Pass=
Linkmon=3600
Beacon=102
Reboot=0
IF=UP
DHCP=ON
IP=192.168.1.8:2000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=3
CmdChar=$
DNS=192.168.1.1
Lease=86400
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=XXXXXX
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=XXXXXXXX
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=web_app
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
Re: Portal issues?
Posted: Mon Apr 10, 2017 3:26 pm
Have you uploaded any code around that time?
Re: Portal issues?
Posted: Mon Apr 10, 2017 3:31 pm
by ucez
No, just tried to reload wifi macro, but same thing.
Re: Portal issues?
Posted: Mon Apr 10, 2017 7:00 pm
Everything looks ok with the wifi attachment.
Let's get another log.
Connect the USB-TTL cable to RA.
Open Arduino
Make sure you have the correct serial port selected
Go to Tools->Serial Monitor
Make sure you have 57600 baud. If not, you will need to change to 57600 and close serial monitor and open again
Wait 5 minutes for RA to send data
Send whatever you get on the serial monitor window
