Alexa Control
icecool2
Re: Alexa Control
Post by icecool2 »
Oh.... didn't see any mention of that in this thread. That stinks :(
Are there upgrade options from the RA+ to the RA*? I have everything but the head unit, I suppose.
Re: Alexa Control
We don't have it in the store, but I can probably work it out with you.
You will also need the old relay expansion module because the RA* only has expansion bus and doesn't have the svga connection.
Send me a PM.
89delta
Re: Alexa Control
Post by 89delta »
It does work with the cloud attachment. Works fine for me. When I ask for pH I have to ask it as what is the pH temp?
Sent from my SM-N920T using Tapatalk
libertyaquarium
Re: Alexa Control
Post by libertyaquarium »
Hi there
Just trying Alexa with RA*. Any reason to just show my 1o relay box?
libertyaquarium
Re: Alexa Control
Any idea? Is it something wrong?
Re: Alexa Control
I think only one box is enabled for Alexa
Piper
Re: Alexa Control
Post by Piper »
Is this still supported after the server migration?
brennyn21
Re: Alexa Control
Post by brennyn21 »
It's on the to do list for sure, but I don't believe it is working since the migration happened
Sincerely, Brennyn
Piper
Re: Alexa Control
Post by Piper »
Got it. Thank you.
brennyn21
Re: Alexa Control
Post by brennyn21 »
Hi Piper, Alexa Control is now working please follow the instructions below to enable the skill.
To enable the Reef Angel Skill, open Alexa app, click the menu bar and select skills and games, then search "Reef Angel" you should see Reef Angel v2 pop up click that skill to enable and it will prompt you to login with your username and password.
Once added it will do a device discovery, and then you will be able to use voice control. Currently the only supported Parameters are Temp 1, Temp 2 Temp 3, pH, Salinity, ORP, pH Exp, Status Flags (Feeding Mode, Water Change Mode, Lights On Mode) Relay Expansion 1, and Relay Expansion 2. These may all show up in Alexa even if you don't have all these expansions.
The command structure is as follows.
Alexa What is [T1 Label] Temperature where t1 label is what you set in the Uapp for the Temp 1 Label.
For the Modes you will say, Alexa turn on Feeding Mode, or Turn on Water change mode, or Turn on lights on mode, For off you say Turn Off Feeding Mode, etc
For Relay Ports you have 3 commands On, Off and Auto. For Example for lets say Port 11 I named "Return Pump" in the Uapp, I will Say Alexa Turn Return Pump On, Or Turn Return Pump Off, or Turn Return Pump to Auto.
Sincerely, Brennyn
Piper
Re: Alexa Control
Post by Piper »
Thank you, Brennyn! It's working!! Now I don't have to bend over and press the feeding button anymore :)
brennyn21
Re: Alexa Control
Post by brennyn21 »
Great to hear, glad its working for you! Let me know if you have any issues.
Sincerely, Brennyn
