Page 2 of 2
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:11 pm
by icecool2
Oh.... didn't see any mention of that in this thread. That stinks
Are there upgrade options from the RA+ to the RA*? I have everything but the head unit, I suppose.
Re: Alexa Control
Posted: Tue Oct 30, 2018 1:15 pm
We don't have it in the store, but I can probably work it out with you.
You will also need the old relay expansion module because the RA* only has expansion bus and doesn't have the svga connection.
Send me a PM.
Re: Alexa Control
Posted: Thu Nov 01, 2018 9:16 am
by 89delta
It does work with the cloud attachment. Works fine for me. When I ask for pH I have to ask it as what is the pH temp?
Sent from my SM-N920T using Tapatalk
Re: Alexa Control
Posted: Mon Apr 06, 2020 6:38 am
by libertyaquarium
Hi there
Just trying Alexa with RA*. Any reason to just show my 1o relay box?
Re: Alexa Control
Posted: Wed Apr 08, 2020 12:13 pm
by libertyaquarium
Any idea? Is it something wrong?
Re: Alexa Control
Posted: Wed Apr 08, 2020 1:25 pm
I think only one box is enabled for Alexa
Re: Alexa Control
Posted: Sat Feb 03, 2024 9:14 am
by Piper
Is this still supported after the server migration?
Re: Alexa Control
Posted: Sat Feb 03, 2024 11:26 am
by brennyn21
It's on the to do list for sure, but I don't believe it is working since the migration happened
Re: Alexa Control
Posted: Sat Feb 03, 2024 1:01 pm
by Piper
Got it. Thank you.
Re: Alexa Control
Posted: Sun Dec 07, 2025 2:12 am
by brennyn21
Hi Piper, Alexa Control is now working please follow the instructions below to enable the skill.
To enable the Reef Angel Skill, open Alexa app, click the menu bar and select skills and games, then search "Reef Angel" you should see Reef Angel v2 pop up click that skill to enable and it will prompt you to login with your username and password.
Once added it will do a device discovery, and then you will be able to use voice control. Currently the only supported Parameters are Temp 1, Temp 2 Temp 3, pH, Salinity, ORP, pH Exp, Status Flags (Feeding Mode, Water Change Mode, Lights On Mode) Relay Expansion 1, and Relay Expansion 2. These may all show up in Alexa even if you don't have all these expansions.
The command structure is as follows.
Alexa What is [T1 Label] Temperature where t1 label is what you set in the Uapp for the Temp 1 Label.
For the Modes you will say, Alexa turn on Feeding Mode, or Turn on Water change mode, or Turn on lights on mode, For off you say Turn Off Feeding Mode, etc
For Relay Ports you have 3 commands On, Off and Auto. For Example for lets say Port 11 I named "Return Pump" in the Uapp, I will Say Alexa Turn Return Pump On, Or Turn Return Pump Off, or Turn Return Pump to Auto.
Re: Alexa Control
Posted: Sat Dec 27, 2025 12:51 pm
by Piper
Thank you, Brennyn! It's working!! Now I don't have to bend over and press the feeding button anymore
Re: Alexa Control
Posted: Sat Dec 27, 2025 12:55 pm
by brennyn21
Great to hear, glad its working for you! Let me know if you have any issues.
