Re: Auxilliary LCD monitor
Posted: Mon Feb 13, 2012 8:20 pm
				You can try filing the connector so it doesn't get caught so tight or pull the connector and not the cable.
https://forum.reefangel.com/
/* Main ReefAngelPlus controller with communication for sound,
auxillary monitor, I/O expansion, and extra relaybox, send master time,
flow, buzzer, overflow and reservoir alarms on the I/O
The following features are enabled for this File:
#define DisplayImages
#define SetupExtras
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define RelayExp
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 9
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define NUMBERS_8x8
#define CUSTOM_VARIABLES
#include <avr/pgmspace.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte MoonPWMValue;
byte Sound;
int maxTemp=0;
int minTemp=2000;
int maxPH=0;
int minPH=1000;
int flow =0;
int maxflow=0;
int minflow=1000;
//timestamp
time_t mastertime=now();
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
time_t flowmax=now();
time_t flowmin=now();
// Moon Global Variables - Thanks Deckoz2302!
byte ThisPhase;
double AG;
double IP;
long YY, MM, K1, K2, K3, JD;
//wire.write variable number
byte param[2];
//wavemaker dalay variables
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
//time variables for time between sounds
long previousMillis = 0;
long interval = 5000;      // interval at which a sound can play (milliseconds)
//varibles for input module data
byte IOIn[10];
int Flow0;
int Flow1;
int Flow2;
byte buzz = 1;
byte Overflow = 0;
byte Reservoir = 0;
byte HATO = 0;
byte LATO = 0;
byte wm = 0;
byte level = 0;
byte atos = 0;
byte powerOut;
static int swidth = 90; // change these
static int sheight = 60; // change these
static const prog_int16_t header_data[] PROGMEM = { // add data here
void DrawBitmap(int xpos, int ypos) {
int count = 0;
for (int j = 0; j < sheight; j++) {
for (int i = 0; i < swidth; i++) {
ReefAngel.LCD.PutPixel(pgm_read_word_near(header_data + count),xpos+i,ypos+j);
count++;
// Custom Menu Code
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "pH Calibration";
prog_char menu4_label[] PROGMEM = "pH Detail";
prog_char menu5_label[] PROGMEM = "Temp Detail";
prog_char menu6_label[] PROGMEM = "Date / Time";
prog_char menu7_label[] PROGMEM = "Flow Cells";
prog_char menu8_label[] PROGMEM = "Version";
prog_char menu9_label[] PROGMEM = "Sound Bytes";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.SetupCalibratePH();
void MenuEntry4()
//pH detail screen with 24 hr. max/min, time stamps, and graph
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 36, 13, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5, 23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxPH, 0, 23, 23, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 23,"at");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minPH, 0, 23, 33, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 33,"at");
DrawTime(60,23,0, COLOR_WHITE,PHmax);
DrawTime(60,33,0,COLOR_WHITE, PHmin);
    ReefAngel.LCD.Clear(DefaultBGColor,0,75,131,125);
    ReefAngel.LCD.Clear(DefaultFGColor,1,75,1,125);
    for (byte i=6; i<=131; i+=3)
        ReefAngel.LCD.PutPixel(GraphDotLineColor, i, 100);
ReefAngel.LCD.DrawSingleGraph(PHColor,1,75,InternalMemory.T1Pointer_read()+360);
bool bDone = false;
do
// wait indefinitely for a button press
delay(200);
if ( ReefAngel.Joystick.IsButtonPressed() )
bDone = true;
} while ( ! bDone );
void MenuEntry5()
//Temperature detail screen with sump and room temp, 24 hr. max/min, time stamps, and graph
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TANK:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 36, 13, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 23, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,23,"at");
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,33,"at");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 5 ,43,"R00M:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 36, 43, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor, 5, 53,"SUMP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 36, 53, 10);
DrawTime(60,23,0, COLOR_WHITE,tsmax);
DrawTime(60,33,0,COLOR_WHITE, tsmin);
ReefAngel.LCD.DrawSingleGraph(T1TempColor,1,75,InternalMemory.T1Pointer_read());
ReefAngel.LCD.DrawSingleGraph(T2TempColor,1,75,InternalMemory.T1Pointer_read()+120);
ReefAngel.LCD.DrawSingleGraph(T3TempColor,1,75,InternalMemory.T1Pointer_read()+240);
bool bDone = false;
do
delay(200);
bDone = true;
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
//Flow detail screen with 24 hr. max/min, & time stamps
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"FLOW0:");
ReefAngel.LCD.DrawSingleMonitor(Flow1, 0,46,13, 1);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 66, 13,"gal/hr");
ReefAngel.LCD.DrawSingleMonitor(maxflow, 0, 23, 23, 1);
ReefAngel.LCD.DrawSingleMonitor(minflow, 0, 23, 33, 1);
DrawTime(60,23,0, COLOR_WHITE,flowmax);
DrawTime(60,33,0,COLOR_WHITE, flowmin);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 43,"FLOW1:");
ReefAngel.LCD.DrawSingleMonitor(Flow2, 0,46,43, 1);
bool bDone = false;
do
delay(200);
bDone = true;
void MenuEntry8()
ReefAngel.DisplayVersion();
DrawBitmap(5,60);
void MenuEntry9()
   Sound++;
   if ( Sound > 9 ) Sound = 1;
//  Sound=random(0,8);
Soundsend(Sound,1);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"Playing Sound #");
ReefAngel.LCD.DrawSingleMonitor(Sound, 0,90,13, 1);
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 23,"just keep swimming");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 33,"Under the sea");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 43,"anemone");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 53,"H20 intolerant");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 63,"fronds like these");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 73,"Sharkbait");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 83,"Seabirds");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 93,"fish are friends");
ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor, 5, 103,"Aquascum");
if (Sound==0) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 23,"just keep swimming");
else if (Sound==1) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 33,"Under the sea");
else if (Sound==2) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 43,"anemone");
else if (Sound==3) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 53,"H20 intolerant");
else if (Sound==4) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 63,"fronds like these");
else if (Sound==5) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 73,"Sharkbait");
else if (Sound==6) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 83,"Seabirds");
else if (Sound==7) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 93,"fish are friends");
else if (Sound==8) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor, 5, 103,"Aquascum");
void DrawTime(byte x, byte y, byte FGcolor, byte BGcolor, time_t ts)
    char text[13];
    char temp[]="  ";
    strcpy(text,"");
    itoa(hourFormat12(ts),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(ts),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(ts),temp,10);
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
    ReefAngel.LCD.DrawText(FGcolor, BGcolor, x, y, text);
//function to backage int into bytes for parameters temp, pH, timers, actinic%)
void paramsend(int a)
  param[0]=(byte)(a>>8);
  param[1]=(byte)(a);
  Wire.write(param,2);
void FillCircle(int a, int b, int r, byte color)
   int f = 1 - r;
   int ddF_x = 1;
   int ddF_y = -2 * r;
   int x = 0;
   int y = r;
for (int i=b-r; i<=b+r; i++)
  ReefAngel.LCD.PutPixel(color, a, i);
while (x<y)
if (f >= 0)
   y--;
   ddF_y += 2;
   f += ddF_y;
   x++;
   ddF_x += 2;
   f += ddF_x;
   for (int i=b-y; i<=b+y; i++)
ReefAngel.LCD.PutPixel(color, a+x, i);
ReefAngel.LCD.PutPixel(color, a-x, i);
for (int i=b-x; i<=b+x; i++)
ReefAngel.LCD.PutPixel(color,a+y, i);
ReefAngel.LCD.PutPixel(color,a-y, i);
  // update the min and max temps
if (now()%86400==0)
  minTemp=ReefAngel.Params.Temp[T1_PROBE];
  maxTemp=ReefAngel.Params.Temp[T1_PROBE];
if (ReefAngel.Params.Temp[T1_PROBE]<minTemp)
  tsmin=now();
if (ReefAngel.Params.Temp[T1_PROBE]>maxTemp)
  tsmax=now();
// update the min and max pH
if (now()%86400==0)
  minPH=ReefAngel.Params.PH;
  maxPH=ReefAngel.Params.PH;
if (ReefAngel.Params.PH<minPH)
  PHmin=now();
if (ReefAngel.Params.PH>maxPH)
  PHmax=now();
if (now()%86400==0)
  minflow=flow;
  maxflow=flow;
if (flow<minflow)
  minflow=flow;
  flowmin=now();
if (flow>maxflow)
  maxflow=flow;
  flowmax=now();
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
GetFlow();
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TK:");
  if (ReefAngel.Params.Temp[T1_PROBE]>830) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_RED, 23, 13, 10);
  else if (ReefAngel.Params.Temp[T1_PROBE]>810) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_ORANGE, 23, 13, 10);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 23, 13, 10);
  // Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 64, 13,"PH:");
  if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_RED, 82, 13, 100);
  else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_ORANGE, 82, 13, 100);
  else ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 82, 13, 100);
// Display status of ato's
if (Reservoir == 0)
FillCircle(15,26,5,COLOR_RED);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_RED,14,22,"R");
else if (Reservoir == 1)
FillCircle(15,26,5,COLOR_GREEN);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_GREEN,14,22,"R");
if (Overflow == 0)
FillCircle(26,26,5,COLOR_GREEN);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_GREEN,23,22,"O");
else if (Overflow == 1)
FillCircle(26,26,5,COLOR_RED);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_RED,23,22,"O");
HATO = 1;
FillCircle(36,26,5,COLOR_GREEN);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_GREEN,34,22,"H");
HATO = 0;
FillCircle(36,26,5,COLOR_RED);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_RED,34,22,"H");
LATO = 1;
FillCircle(46,26,5,COLOR_RED);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_RED,44,22,"L");
LATO = 0;
FillCircle(46,26,5,COLOR_GREEN);
ReefAngel.LCD.DrawText(COLOR_WHITE,COLOR_GREEN,44,22,"L");
// Display the % Moonlight
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 23,"MN:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), COLOR_BLACK, 82, 23, 1);
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 100, 23,"%");
// Display the Flow 1
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,5,33,"FL0:");
ReefAngel.LCD.DrawSingleMonitor(Flow1, COLOR_BLACK, 33, 33, 1);
// Display the Flow 0
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,64,33,"FL1:");
ReefAngel.LCD.DrawSingleMonitor(Flow2, COLOR_BLACK, 92, 33, 1);
// moonphase------------------------------------------------------------
  YY = (year()) - floor((12 - (month())) / 10);
  MM = (month()) + 9;
  if (MM >= 12)
    MM = MM - 12;
  K1 = floor(365.25 * (YY + 4712));
  K2 = floor(30.6 * MM + 0.5);
  K3 = floor(floor((YY / 100) + 49) * 0.75) - 38;
  JD = K1 + K2 + (day()) + 59;
  if (JD > 2299160)
    JD = JD - K3;
  IP = (JD - 2451550.1) / 29.530588853;
  IP = IP - floor(IP);
  if (IP < 0)
    IP = IP + 1;
  AG = IP*29.53;
  if (AG < 1.84) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"New");
  else if (AG < 5.53) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Waxing Crescent");
  else if (AG < 9.92) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"First Quarter");
  else if (AG < 12.91) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Waxing Gibbous");
  else if (AG < 16.61) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Full");
  else if (AG < 20.30) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Waning gibbous");
  else if (AG < 23.99) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Last Quarter");
  else if (AG < 27.68) ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"Waning Crescent");
  else  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 43,"New") ;
//temperature room
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,5,53,"RM:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 23, 53, 10);
//temperature sump
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,64,53,"SP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 82, 53, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 63,"WV:");
  if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 23, 63,"-->"); //port 5 on
  else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 23, 63,"<--");  //port 6 on
  else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 43, 63," O "); //port5 and port 6 off, wavemaker delay
//Timer and trigger to keep wavemaker timing correct after setting date/time
    int t=ReefAngel.Timer[1].Trigger-now();
    if (t>=0)
      ReefAngel.LCD.Clear(255,23,73,53,83);
      ReefAngel.LCD.DrawText(0, DefaultBGColor,23,73,t);
    if (t>300) ReefAngel.Timer[1].ForceTrigger();
    //wavemakers extra
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 64, 63,"WV:");
  if (bitRead(ReefAngel.Relay.RelayDataE[0],Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63,"v  "); //port 5 on
  else if (bitRead(ReefAngel.Relay.RelayDataE[0],Port6-1)==1)  ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63,"  v");  //port 6 on
  else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 82, 63," O "); //port5 and port 6 off, wavemaker delay
    int u=ReefAngel.Timer[2].Trigger-now();
    if (u>=0)
      ReefAngel.LCD.Clear(255,82,73,112,83);
      if (bitRead(ReefAngel.Relay.RelayDataE[0],Box1_Port5-1)==1 || bitRead(ReefAngel.Relay.RelayDataE[0],Box1_Port6-1)==1)
      ReefAngel.LCD.DrawText(0, DefaultBGColor,82,73,u);
    if (u>300) ReefAngel.Timer[2].ForceTrigger();
//  power status on LCD
if (powerOut)
    ReefAngel.LCD.Clear(255,1,92,102,102);
    ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor,1,92,"BACKUP Power ON");
    ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor,1,92,"Main Power ON");
ReefAngel.LCD.DrawOutletBox(12, 110, TempRelay);
// draw 1st expansion relay
ReefAngel.LCD.DrawOutletBox(12, 120, TempRelay);
void Soundsend(byte x, long y)  //function to play sound and delay before it plays again.
  interval = y*100;
  unsigned long currentMillis = millis();
    if(currentMillis - previousMillis > interval)
      // save the last time you played a sound
      previousMillis = currentMillis;
      // if longer than 100 sec than play a sound
         Wire.beginTransmission(9);      // transmit to device #9
         Wire.write('$');         // send the $$$
         Wire.write('$');
         Wire.write('$');
         Wire.write(x);         // send the command
         Wire.endTransmission();      // stop transmitting
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.PHMin=546;
  ReefAngel.PHMax=868;
// Set the ports that get toggled on & off during the following modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Uncomment and update as needed
// Port 87654321
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.FeedingModePortsE[1] = B00110100;
  ReefAngel.WaterChangePorts = B10110000;
  ReefAngel.WaterChangePortsE[1] = B11111111;
  ReefAngel.Relay.On(Port7);  //main pump
  ReefAngel.Relay.On(Box1_Port1); //chiller
  ReefAngel.Relay.On(Box1_Port2); //chiller pump
  ReefAngel.Relay.On(Box1_Port4); //phosban pumpo
// Top smaller pumps once an hour for 5 minutes
  ReefAngel.Relay.On(Box1_Port5);
  ReefAngel.Timer[2].SetInterval(30);
  ReefAngel.Timer[2].Start();
//Side to side Wavemaker Pumps
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(200);
  ReefAngel.Timer[1].Start();
  // Specific functions
  //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
  ReefAngel.StandardHeater(Port1,788,792);
  ReefAngel.StandardHeater(Port2,770,792);
  ReefAngel.MHLights(Port3,10,0,20,0,5);
  ReefAngel.StandardLights(Port4,9,0,21,0);
  ReefAngel.StandardFan(Port8,792,820);
  ReefAngel.DosingPumpRepeat(Box1_Port7,0,60,4); // Dose for 4 seconds every 60 minutes with 0 minutes offset
  ReefAngel.DosingPumpRepeat(Box1_Port8,5,60,4); // Dose for 4 seconds every 60 minutes with 5 minutes offset
  ReefAngel.CustomVar[1]=Flow0;
  ReefAngel.CustomVar[2]=Flow1;
  ReefAngel.CustomVar[3]=Flow2;
  ReefAngel.CustomVar[6]=buzz;
//Sump refill, check reservoir level first, then standard ATO
  if (Reservoir == 1)
   ReefAngel.StandardATO(Box1_Port3,60);  //Setup relay unit Port3 as Auto Top-Off function with 60s timeout
 //Alarm state
  buzz = 1;
  buzz = 0;
  GetFlow();
   // Wavemaker Code with night option
  if (ReefAngel.Timer[1].IsTriggered() )
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-10p normal wave settings
      ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
//extra small powerheads to increase circulation once an hour
//for 5 min during the day
if (hour()>=8 && hour()<=21)
    if (minute()<5)
       if (ReefAngel.Timer[2].IsTriggered())
          ReefAngel.Relay.Toggle(Box1_Port5);
          ReefAngel.Relay.Set(Box1_Port6,!ReefAngel.Relay.Status(Box1_Port5));
       ReefAngel.Relay.Off(Box1_Port5);
       ReefAngel.Relay.Off(Box1_Port6);
//Moonlight
 MoonPWMValue=MoonPhase();
  if (hour()==21 || hour()==8)
     MoonPWMValue=PWMSlope(21,00,9,00,0,MoonPhase(),60,0);
  if (ReefAngel.Relay.Status(Port4)) MoonPWMValue=0;
  ReefAngel.PWM.SetActinic(MoonPWMValue);
  ReefAngel.PWM.SetDaylight(MoonPWMValue);
//I/O module communication
  Wire.beginTransmission(7);      // transmit to device #7
  Wire.write('$');
  Wire.write('$');
  Wire.write(buzz);
//Overflow blocked alarm & main pump shut-off, Reservoir alarm
  // Overflow blocked, Reservoir Full
  if (Overflow == 1  && Reservoir == 0)
     ReefAngel.Relay.Off(Port7);
     ReefAngel.CustomVar[4]=1;  // overflow: 0 good, 1 bad
     ReefAngel.CustomVar[5]=0;  // reservoir: 0 good, 1 bad
     level = 0;
  // Overflow open, Reservoir Full
  else if (Overflow == 0  && Reservoir == 0)
     ReefAngel.CustomVar[4]=0;
     level = 1;
       // Overflow blocked, Reservoir Empty
  else if (Overflow == 1  && Reservoir == 1)
     ReefAngel.CustomVar[5]=1;
     level = 2;
       // Overflow open, Reservoir Empty
  else if (Overflow == 0  && Reservoir == 1)
     level = 3;
//ATO status
  if (HATO == 1 && LATO == 1)
     atos = 0;
  else if (HATO == 1 && LATO == 0)
     atos = 1;
  else if (HATO == 0 && LATO == 1)
     atos = 2;
  else if (HATO == 0 && LATO == 0)
     atos = 3;
 // power sensor with scanner
    powerOut = !ReefAngel.Relay.IsRelayPresent(0);
    // turn off power hogs if the power is out
    if (powerOut)
    ReefAngel.Relay.Off(Port1);
    ReefAngel.Relay.Off(Port2);
    ReefAngel.Relay.Off(Port3);
    ReefAngel.Relay.Off(Port4);
    ReefAngel.Relay.Off(Port8);
    ReefAngel.CustomVar[7]=1;
    ReefAngel.CustomVar[7]=0;
//send sound requests
      if (ReefAngel.DisplayedMenu==FEEDING_MODE) Soundsend(7,100);     //feeding time
      if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) Soundsend(8,100);     //feeding time
//send data parameter package to the auxillary monitor
         Wire.beginTransmission(10);      // transmit to device #10
         Wire.write('$');
         Wire.write('$');
         paramsend(ReefAngel.Params.Temp[T1_PROBE]);
         paramsend(ReefAngel.Params.Temp[T2_PROBE]);
         paramsend(ReefAngel.Params.Temp[T3_PROBE]);
         paramsend(ReefAngel.Params.PH);
         paramsend(ReefAngel.Timer[1].Trigger-now());
         paramsend(ReefAngel.PWM.GetActinicValue());
         Wire.write(level);
         Wire.write(atos);
         Wire.write(ReefAngel.Relay.RelayData);
         Wire.write(ReefAngel.Relay.RelayDataE[0]);
         paramsend(Flow0);
         paramsend(Flow1);
         paramsend(Flow2);
         Wire.write(hour());
         Wire.write(minute());
         Wire.write(second());
         Wire.write(day());
         Wire.write(month());
         paramsend(year());
   ReefAngel.Portal("jsclownfish");
void GetFlow()
  Wire.requestFrom(7,9);
  if(Wire.available())
    for (int a=0;a<10;a++)
      IOIn[a]=Wire.read();
  Flow0=(IOIn[1]<<8)+IOIn[2];
  Flow1=(IOIn[3]<<8)+IOIn[4];
  Flow2=(IOIn[5]<<8)+IOIn[6];
  Overflow=IOIn[7];
  Reservoir=IOIn[8];
/* Auxillary LCD monitor connected to the ReefAngel Controller (328)
requires a custom cable to connect from I2C main to the serial port
#define RelayExp
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define NUMBERS_8x8
#define NUMBERS_16x16
#include <avr/wdt.h>
//screen set-up
#define NumScreens 9
int ScreenID=0;
//define for data over I2C
int maxTemp=0;
int minTemp=2000;
int maintemp=800;
int roomtemp=780;
int sumptemp=780;
int ph=700;
int maxPH=600;
int minPH=900;
int moonlight=0;
byte TempRelay =15;
byte TempRelay2=15;
int wavetime=0;
int wavetime2=0;
int flow0=0;
int flow1=0;
int flow2=0;
int wmaker2;
byte mhour;
byte mminute;
byte msecond;
byte mday;
byte mmonth;
int myear;
byte Overflow;
byte Reservoir;
byte LATO;
byte HATO;
byte level;
byte atos;
//Analog Clock constants
    const float pi = 3.141592653;
    byte clock_center_x = 65;
    byte clock_center_y = 65;
    byte clock_radius = 55;
    byte secondhand_radius = 33;
    float secondangle;
    byte secondend_x;
    byte secondend_y;
    float minuteangle;
    float hourangle;
   // Analog Clock Structure
       int minutebase_radius = 3;
       int minutehand_radius = 33;
       int hourbase_radius = 3;
       int hourhand_radius = 25;
       int seconds_hand_x, seconds_hand_y, minutes_hand_x, minutes_hand_y, hours_hand_x, hours_hand_y;
       int hours_hand_base_x, hours_hand_base_y, hours_hand_base_x1, hours_hand_base_y1;
       int minutes_hand_base_x, minutes_hand_base_y, minutes_hand_base_x1, minutes_hand_base_y1;
       int minutebase_x, minutebase_y, minutebase_x1, minutebase_y1;
       int minuteend_x, minuteend_y;
       int hourbase_x, hourbase_y, hourbase_x1, hourbase_y1;
       int hourend_x, hourend_y;
       float minfloat;
//time stamp
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
int mastertime;
byte ThisPhase;
double AG;
double IP;
byte MoonPWMValue;
// Draw Minutes Hand
void draw_minute(int color)
  Drawline(minutebase_x, minutebase_y, minutebase_x1, minutebase_y1, color);
  Drawline(minutebase_x, minutebase_y, minuteend_x, minuteend_y, color);
  Drawline(minutebase_x1, minutebase_y1, minuteend_x, minuteend_y, color);
// Draw Hour Hand
void draw_hour(int color)
   Drawline(hourbase_x, hourbase_y, hourbase_x1, hourbase_y1, color);
   Drawline(hourbase_x, hourbase_y, hourend_x, hourend_y, color);
   Drawline(hourbase_x1, hourbase_y1, hourend_x, hourend_y, color);
void Drawline (int x0, int y0, int x1, int y1, int color)
  int dy = y1 - y0;
  int dx = x1 - x0;
  int stepx, stepy;
  if (dy < 0) { dy = -dy; stepy = -1; } else { stepy = 1; }
  if (dx < 0) { dx = -dx; stepx = -1; } else { stepx = 1; }
  dy <<= 1; // dy is now 2*dy
  dx <<= 1; // dx is now 2*dx
  ReefAngel.LCD.PutPixel(color, x0, y0);
  if (dx > dy) {
    int fraction = dy - (dx >> 1); // same as 2*dy - dx
    while (x0 != x1) {
      if (fraction >= 0) {
        y0 += stepy;
        fraction -= dx; // same as fraction -= 2*dx
      x0 += stepx;
      fraction += dy; // same as fraction -= 2*dy
  } else {
  int fraction = dx - (dy >> 1);
  while (y0 != y1) {
    x0 += stepx;
    fraction -= dy;
  y0 += stepy;
  fraction += dx;
    char text[13];
    char temp[]="  ";
    strcpy(text,"");
    strcat(text,temp);
    strcat(text,":");
    strcat(text,temp);
    strcat(text,":");
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
void DrawCircle(int a, int b, int r, byte color)
  int f = 1 - r;
  int ddF_x = 1;
  int ddF_y = -2 * r;
  int x = 0;
  int y = r;
 ReefAngel.LCD.PutPixel(color, a, b+r);
 ReefAngel.LCD.PutPixel(color ,a, b-r);
 ReefAngel.LCD.PutPixel(color, a+r, b);
 ReefAngel.LCD.PutPixel(color, a-r, b);
 while (x<y)
 if (f >= 0)
 {      y--;
       ddF_y += 2;
       f += ddF_y;
   x++;
   ddF_x += 2;
   f += ddF_x;
   ReefAngel.LCD.PutPixel(color, a + x, b + y);
   ReefAngel.LCD.PutPixel(color, a - x, b + y);
   ReefAngel.LCD.PutPixel(color, a + x, b - y);
   ReefAngel.LCD.PutPixel(color, a - x, b - y);
   ReefAngel.LCD.PutPixel(color, a + y, b + x);
   ReefAngel.LCD.PutPixel(color, a - y, b + x);
   ReefAngel.LCD.PutPixel(color, a + y, b - x);
   ReefAngel.LCD.PutPixel(color, a - y, b - x);
   int f = 1 - r;
   int ddF_x = 1;
   int ddF_y = -2 * r;
   int x = 0;
   int y = r;
while (x<y)
if (f >= 0)
   y--;
   ddF_y += 2;
   f += ddF_y;
   x++;
   ddF_x += 2;
   f += ddF_x;
void DrawCircleBox (byte x, byte y, byte RelayData)
 byte b = 0;
 byte c = 0;
 byte d = 0;
    for (byte a=0;a<2;a++)
        DrawCircle ((a*10)+x,y+30,5,COLOR_BLACK);
        if ((RelayData&(1<<a))==1<<a)
          FillCircle((a*10)+x,y+30,3,OutletOnBGColor);
          FillCircle((a*10)+x,y+30,3,OutletOffBGColor);
   for (byte a=2;a<4;a++)
        b=(a-2)*10;
       DrawCircle (b+x,y+20,5,COLOR_BLACK);
          FillCircle(b+x,y+20,3,OutletOnBGColor);
          FillCircle(b+x,y+20,3,OutletOffBGColor);
    for (byte a=4;a<6;a++)
        c=(a-4)*10;
       DrawCircle (c+x,y+10,5,COLOR_BLACK);
          FillCircle(c+x,y+10,3,OutletOnBGColor);
          FillCircle(c+x,y+10,3,OutletOffBGColor);
    for (byte a=6;a<8;a++)
        d=(a-6)*10;
       DrawCircle (d+x,y,5,COLOR_BLACK);
          FillCircle(d+x,y,3,OutletOnBGColor);
          FillCircle(d+x,y,3,OutletOffBGColor);
void DrawWeeklyAvg (byte hr, int sensor, byte color, byte x, byte y, byte z)
  const int numReadings = 7;
  int dailyread;
  int readings[numReadings];      // the readings from the analog input
  int index = 0;                  // the index of the current reading
  int total = 0;                  // the running total
  int average = 0;                // the average
  if (hour()==hr && minute()==0 && second()==0)
    dailyread=sensor;
  total= total - readings[index];   // subtract the last reading:
  readings[index] = dailyread;   // read from the sensor:
  total= total + readings[index];   // add the reading to the total:
     index = index + 1;  // advance to the next position in the array:
  if (index >= numReadings)     // if we're at the end of the array...
    index = 0;       // ...wrap around to the beginning:
  average = total / numReadings;    // calculate the average:
  delay (1000);
  ReefAngel.LCD.DrawSingleMonitor(average, color, x, y, z);
void DrawDailyAvg (int sensor, byte color, byte x, byte y, byte z)
  const int numReadings = 24;
  int dailyread;
  if (minute()==0 && second()==0)
    dailyread=sensor;
  delay (1000);
  setTime(19,59,0,6,3,12);
  Wire.begin(10); // I2C address 10
  Wire.onReceive(receiveEvent);
  ReefAngel.Timer[LCD_TIMER].SetInterval(180);
  ReefAngel.Timer[LCD_TIMER].Start();  // start timer
  setTime(mhour,mminute,msecond,mday,mmonth,myear);
  if ( ReefAngel.Timer[LCD_TIMER].IsTriggered() )  // process screensaver timeout
	{// Screensaver timeout expired
	ReefAngel.LCD.BacklightOff();
  if ( ReefAngel.Joystick.IsButtonPressed())
	{// turn the backlight on
	ReefAngel.LCD.BacklightOn();
  // TODO check Timer[LCD_TIMER] code
  if ( ReefAngel.Timer[LCD_TIMER].Trigger == 0 )
	return;
	}// update the min and max temps
  if (now()%86400==0)
    minTemp=maintemp;
    maxTemp=maintemp;
  if (maintemp<minTemp)
    minTemp=maintemp;
    tsmin=now();
  if (maintemp>maxTemp)
    maxTemp=maintemp;
    tsmax=now();
if (now()%86400==0)
  minPH=ph;
  maxPH=ph;
if (ph<minPH)
  minPH=ph;
  PHmin=now();
if (ph>maxPH)
  maxPH=ph;
  PHmax=now();
  if (ReefAngel.Joystick.IsLeft() || ReefAngel.Joystick.IsDown())
    ScreenID--;
  if (ReefAngel.Joystick.IsRight() || ReefAngel.Joystick.IsUp())
    ScreenID++;
  if (ScreenID<0) ScreenID=NumScreens;
  if (ScreenID>=NumScreens) ScreenID=0;
  switch (ScreenID)
  case 0:  //Initial first screen
    ReefAngel.Refresh();
    ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 0, "                 ", Font8x8); //Top Banner
    ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 1, " Jon's Reef Tank ", Font8x8); //Top Banner
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#1", Font8x8);
    // Display Temp Text
    ReefAngel.LCD.DrawLargeText(0,255,30,15,"Tank Temp", Font8x8);
    // Display the T1 temp
    char text[7];
    ConvertNumToString(text, maintemp, 10);
    ReefAngel.LCD.Clear(255, 35, 25, 50, 60);
    if (maintemp>830) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 35, 25, text);
    else if (maintemp>830) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 35, 25, text);
    else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 35, 25, text);
    // Display pH Text
    ReefAngel.LCD.DrawLargeText(0,255,82,85,"  pH  ", Font8x8);
    // Display pH Value
    ConvertNumToString(text, ph, 100);
    ReefAngel.LCD.Clear(255, 65, 95, 132, 115);
    if (ph>840 || ph<790) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 65, 95, text);
    else if (ph>830 || ph<800) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 65, 95, text);
    else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 65, 95, text);
    // Display Sump Temp
    ReefAngel.LCD.DrawLargeText(0,255,8,50,"Sump Temp", Font8x8);
    ReefAngel.LCD.Clear(255, 90, 50, 132, 60);
    ConvertNumToString(text, sumptemp, 10);
    ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 50, text, Num8x8);
    // Display Room Temp
    ReefAngel.LCD.DrawLargeText(0,255,8,60,"Room Temp", Font8x8);
    ReefAngel.LCD.Clear(255, 90, 60, 132, 70);
    ConvertNumToString(text, roomtemp, 10);
    ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 60, text, Num8x8);
    DrawCircleBox (10,90,TempRelay);
    DrawCircleBox (40,90,TempRelay2);
    break;
  case 1:  //same as first screen with position changes
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#2", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,30,15,"   pH    ", Font8x8);
    ReefAngel.LCD.Clear(255, 35, 25, 50, 50);
    if (ph>830) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 35, 25, text);
    else if (ph>830) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 35, 25, text);
    // Display pH Text
    ReefAngel.LCD.DrawLargeText(0,255,25,105,"Tank", Font8x8);
    // Display pH Value
    if (maintemp>840 || ph<790) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 65, 95, text);
    else if (maintemp>830 || ph<800) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 65, 95, text);
    // Display Flow0
    ReefAngel.LCD.DrawLargeText(0,255,8,50,"Pump1Flow", Font8x8);
    ConvertNumToString(text, flow0, 10);
    // Display Flow1
    ReefAngel.LCD.DrawLargeText(0,255,8,60,"Pump2Flow", Font8x8);
    ConvertNumToString(text, flow1, 10);
    // Display light level
    ReefAngel.LCD.DrawLargeText(0,255,8,70,"Moonlight", Font8x8);
    ReefAngel.LCD.Clear(255, 90, 70, 132, 90);
    ConvertNumToString(text, moonlight, 1);
    ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 70, text, Num8x8);
  MM = (month()) + 9;
  if (MM >= 12)
    MM = MM - 12;
  if (JD > 2299160)
    JD = JD - K3;
  if (IP < 0)
    IP = IP + 1;
  AG = IP*29.53;
  if (AG < 1.84) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"New", Font8x8);
  else if (AG < 5.53) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Waxing Crescent", Font8x8);
  else if (AG < 9.92) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"First Quarter", Font8x8);
  else if (AG < 12.91) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Waxing Gibbous", Font8x8);
  else if (AG < 16.61) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Full", Font8x8);
  else if (AG < 20.30) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Waning gibbous", Font8x8);
  else if (AG < 23.99) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Last Quarter", Font8x8);
  else if (AG < 27.68) ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"Waning Crescent", Font8x8);
  else  ReefAngel.LCD.DrawLargeText(DPColor,DefaultBGColor, 5, 80,"New") ;
    break;
  case 2:  //Temperature detail screen with sump and room temp, 24 hr. max/min, time stamps, and graph
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#3", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,10,15,"Temp Details", Font8x8);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,33,"TANK:");
    ReefAngel.LCD.DrawSingleMonitor(maintemp, COLOR_BLACK, 36, 33, 10);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,43,"HI:");
    ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 43, 10);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,43,"at");
    DrawTime(60,43,0, COLOR_WHITE,tsmax);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,53,"LO:");
    ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 53, 10);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,53,"at");
    DrawTime(60,53,0,COLOR_WHITE, tsmin);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,63,"Range:");
    ReefAngel.LCD.DrawSingleMonitor((maxTemp-minTemp), COLOR_BLACK, 46, 63, 10);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,69,63,"degreesF");
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,73,"Avg:");
    DrawDailyAvg(maintemp, COLOR_BLACK, 43, 73, 1);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,83,"WeeklyAvg:");
    DrawWeeklyAvg(12,maintemp, COLOR_BLACK, 66, 83, 1);
    ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor, 86,83,"at noon");
    ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 5 ,93,"R00M:");
    ReefAngel.LCD.DrawSingleMonitor(roomtemp, COLOR_BLACK, 36, 93, 10);
    ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor, 5, 103,"SUMP:");
    ReefAngel.LCD.DrawSingleMonitor(sumptemp, COLOR_BLACK, 36, 103, 10);
    break;
  case 3:  //pH details
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#4", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,20,15,"pH Details", Font8x8);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,33,"pH:");
    ReefAngel.LCD.DrawSingleMonitor(ph, COLOR_BLACK, 36, 33, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,43,"HI:");
    ReefAngel.LCD.DrawSingleMonitor(maxPH, 0, 23, 43, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,48,43,"at");
    DrawTime(60,43,0, COLOR_WHITE,PHmax);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,53,"LO:");
    ReefAngel.LCD.DrawSingleMonitor(minPH, 0, 23, 53, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,48,53,"at");
    DrawTime(60,53,0,COLOR_WHITE, PHmin);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,63,"Range:");
    ReefAngel.LCD.DrawSingleMonitor((maxPH-minPH), COLOR_BLACK, 46, 63, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,73,"Avg:");
    DrawDailyAvg(ph, COLOR_BLACK, 43, 73, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,83,"WeeklyAvg:");
    DrawWeeklyAvg(12,ph, COLOR_BLACK, 66, 83, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 86,83,"at noon");
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,93,"WeeklyAvg:");
    DrawWeeklyAvg(0,ph, COLOR_BLACK, 66, 93, 100);
    ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 86,93,"at midnt");
    break;
 case 4:  //relay box key
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#5", Font8x8);
    DrawCircleBox (56,46,TempRelay);
    ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 1", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,44,"MainP", Font8x8); //7
    ReefAngel.LCD.DrawLargeText(0,255,7,54,"WaveL", Font8x8); //5
    ReefAngel.LCD.DrawLargeText(0,255,7,64,"MH LT", Font8x8); //3
    ReefAngel.LCD.DrawLargeText(0,255,7,74,"Heat2", Font8x8); //1
    ReefAngel.LCD.DrawLargeText(0,255,75,44,"Fans", Font8x8);  //8
    ReefAngel.LCD.DrawLargeText(0,255,75,54,"WaveR", Font8x8);  //6
    ReefAngel.LCD.DrawLargeText(0,255,75,64,"StdLT", Font8x8); //4
    ReefAngel.LCD.DrawLargeText(0,255,75,74,"Heat1", Font8x8);  //2
    break;
  case 5:  //relay box key
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#6", Font8x8);
    DrawCircleBox (56,46,TempRelay2);
    ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 2", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,44,"Dose1", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,54,"Wave3", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,64,"  ATO", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,74,"Chill", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,75,44,"Dose2", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,75,54,"Wave4", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,75,64,"PO4", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,75,74,"Chill", Font8x8);
    break;
  case 6:  //level sensors
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#7", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,20,20,"Level Sensors", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,44," Overflow", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,54,"Reservoir", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,64,"  Low ATO", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,7,74," High ATO", Font8x8);
    if (level == 0)
      Overflow = 0;
      Reservoir = 0;
    else if (level == 1)
      Overflow = 1;
      Reservoir = 0;
    else if (level == 2)
      Overflow = 0;
      Reservoir = 1;
    else if (level == 3)
      Overflow = 1;
      Reservoir = 1;
    if (atos == 0)
      HATO = 1;
      LATO = 1;
    else if (atos == 1)
      HATO = 1;
      LATO = 0;
    else if (atos == 2)
      HATO = 0;
      LATO = 1;
    else if (atos == 3)
      HATO = 0;
      LATO = 0;
    DrawCircle (90,48,5,COLOR_BLACK);
        if (Overflow == 1)
          FillCircle(90,48,3,OutletOnBGColor);
          ReefAngel.LCD.Clear(255, 100, 44, 132, 54);
        else if (Overflow == 0)
          FillCircle(90,48,3,OutletOffBGColor);
          ReefAngel.LCD.DrawLargeText(OutletOffBGColor,255,100,44,"HIGH", Font8x8);
    DrawCircle (90,58,5,COLOR_BLACK);
        if (Reservoir == 1)
          FillCircle(90,58,3,OutletOffBGColor);
          ReefAngel.LCD.DrawLargeText(OutletOffBGColor,255,100,54,"FILL", Font8x8);
        else if (Reservoir == 0)
          FillCircle(90,58,3,OutletOnBGColor);
          ReefAngel.LCD.Clear(255, 100, 54, 132, 64);
    DrawCircle (90,68,5,COLOR_BLACK);
        if (LATO == 1)
          FillCircle(90,68,3,OutletOffBGColor);
          ReefAngel.LCD.DrawLargeText(OutletOffBGColor,255,100,64,"FILL", Font8x8);
        else if (LATO == 0)
          FillCircle(90,68,3,OutletOnBGColor);
          ReefAngel.LCD.Clear(255, 100, 64, 132, 74);
    DrawCircle (90,78,5,COLOR_BLACK);
        if (HATO == 1)
          FillCircle(90,78,3,OutletOnBGColor);
          ReefAngel.LCD.Clear(255, 100, 74, 132, 84);
        else if (HATO == 0)
          FillCircle(90,78,3,OutletOffBGColor);
          ReefAngel.LCD.DrawLargeText(OutletOffBGColor,255,100,74,"LOW", Font8x8);
       break;
  case 7:  //setclock
  // Analog clock is modified from the original source by Jeff Miller
  // Author: Jeff Miller   http://arduinofun.blogspot.com/
    // Frame
    DrawCircle(clock_center_x, clock_center_y, clock_radius, COLOR_CORNFLOWERBLUE);
    DrawCircle(clock_center_x, clock_center_y, clock_radius - 1, COLOR_CORNFLOWERBLUE);
    DrawCircle(clock_center_x, clock_center_y, clock_radius - 2, COLOR_CORNFLOWERBLUE);
    // Face Tick Marks  (x = r cos theta, y = r sin theta)
    for (byte r=0; r < 12; r++) {
      float angle = (2 * pi / 12)*r;
      int tick_x_out = (clock_radius - 8) * cos (angle) + clock_center_x;
      int tick_y_out = (clock_radius - 8) * sin (angle) + clock_center_y;
      int tick_x_in = clock_radius *.72 * cos (angle) + clock_center_x;
      int tick_y_in = clock_radius * .72 * sin (angle) + clock_center_y;
      Drawline(tick_x_in, tick_y_in, tick_x_out, tick_y_out, COLOR_CORNFLOWERBLUE);
    // Face Characters
    ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8,106," 6", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8, 25,"12", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,clock_center_x + 34,clock_center_y," 3", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 50, clock_center_y - 4,"9 ", Font8x8);
   // Draw Seconds Hand
       secondangle = (2 * pi / 60) * second();
              if (second() > 15)
        {secondangle = secondangle -1.57;
        {secondangle = secondangle +4.71;
       Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, WHITE);
       secondend_x = secondhand_radius * cos (secondangle) + clock_center_x;
       secondend_y = secondhand_radius * sin (secondangle) + clock_center_y;
       Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, BLACK);
// Redraw minutes hand since the section closest to the center gets erased by the seconds hand
       draw_minute(BLACK);
// Redraw hour hand
       draw_hour(BLACK);
       minuteangle = (2 * pi / 60) * minute();
       if (minute() > 15)
        {minuteangle = minuteangle -1.57;
        {minuteangle = minuteangle +4.71;
        // Erase old minutes Hand
       draw_minute(WHITE);
  // Calculate Minute Hand Base
      minutebase_x = minutebase_radius * cos (minuteangle - pi/2) + clock_center_x;
      minutebase_y = minutebase_radius * sin (minuteangle - pi/2) + clock_center_y;
      minutebase_x1 = minutebase_radius * cos (minuteangle + pi/2) + clock_center_x;
      minutebase_y1 = minutebase_radius * sin (minuteangle + pi/2) + clock_center_y;
// Calculate Minute Hand Point
      minuteend_x = minutehand_radius * cos (minuteangle) + clock_center_x;
      minuteend_y = minutehand_radius * sin (minuteangle) + clock_center_y;
// Draw new minutes Hand
      draw_minute(BLACK);
// Redraw hour hand
      draw_hour(BLACK);
// Draw Hour Hand
      minfloat = minute(); // Convert minute short to float
      hourangle = (2 * pi / 12) * ((hourFormat12()) + (minfloat/60)); // Find angle for hour hand
      hourangle = hourangle -1.57;
// Erase old Hour Hand
      draw_hour(WHITE);
// Calculate hour Hand Base
      hourbase_x = hourbase_radius * cos (hourangle - pi/2) + clock_center_x;
      hourbase_y = hourbase_radius * sin (hourangle - pi/2) + clock_center_y;
      hourbase_x1 = hourbase_radius * cos (hourangle + pi/2) + clock_center_x;
      hourbase_y1 = hourbase_radius * sin (hourangle + pi/2) + clock_center_y;
// Calculate hour Hand Point
      hourend_x = hourhand_radius * cos (hourangle) + clock_center_x;
      hourend_y = hourhand_radius * sin (hourangle) + clock_center_y;
// Draw new hours Hand
      draw_hour(BLACK);
    ReefAngel.LCD.DrawLargeText(0,255,110,110,"#8", Font8x8);
    ReefAngel.LCD.DrawDate(5,121);
    break;
  case 8:  //menu
    ReefAngel.LCD.DrawLargeText(0,255,100,120,"#9", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,20,15,"Power Heads", Font8x8);
    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 8, 33,"Top wave:");
    ReefAngel.LCD.Clear(255,78,33,103,43);
    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 8, 108,"Side wave:");
    ReefAngel.LCD.Clear(255,78,108,103,120);
    ReefAngel.LCD.DrawText(0,DefaultBGColor, 78, 108, wavetime);
//    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 104, 113,TempRelay2);
    ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 104, 108,"sec");
  if ((TempRelay&(1<<5))==1<<5)
    ReefAngel.LCD.Clear(255,5,75,90,105);
    ReefAngel.LCD.DrawLargeText(0,255,90,75,"<---", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,90,85,"<---", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,90,95,"<---", Font8x8);
  else if ((TempRelay&(1<<6))==1<<6)
    ReefAngel.LCD.Clear(255,45,75,130,105);
    ReefAngel.LCD.DrawLargeText(0,255,5,75,"--->", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,5,85,"--->", Font8x8);
    ReefAngel.LCD.DrawLargeText(0,255,5,95,"--->", Font8x8);
    ReefAngel.LCD.Clear(255,5,75,45,105);
    ReefAngel.LCD.DrawLargeText(0,255,45,85," ~~~", Font8x8);
  if ((TempRelay2&(1<<5))==1<<5)
   ReefAngel.LCD.Clear(255,80,45,100,65);
   ReefAngel.LCD.DrawLargeText(0,255,40,45,"|", Font8x8);
   ReefAngel.LCD.DrawLargeText(0,255,40,55,"v", Font8x8);
  else if ((TempRelay2&(1<<6))==1<<6)
   ReefAngel.LCD.Clear(255,40,45,60,65);
   ReefAngel.LCD.DrawLargeText(0,255,80,45,"|", Font8x8);
   ReefAngel.LCD.DrawLargeText(0,255,80,55,"v", Font8x8);
   ReefAngel.LCD.Clear(255,40,45,100,65);
    break;
void receiveEvent(int howMany)
    if (howMany==32)  // Our custom protocol is 13 bytes
    byte cmd1,cmd2,cmd3,cmd4,cmd5,cmd6,cmd7,cmd8,cmd9,cmd10;
    byte cmd11,cmd12,cmd13,cmd14,cmd15,cmd16,cmd17,cmd18,cmd19,cmd20;
    byte cmd21,cmd22,cmd23,cmd24,cmd25,cmd26,cmd27,cmd28,cmd29,cmd30;
    byte cmd31,cmd32;
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    cmd5=Wire.read();
    cmd6=Wire.read();
    cmd7=Wire.read();
    cmd8=Wire.read();
    cmd9=Wire.read();
    cmd10=Wire.read();
    cmd11=Wire.read();
    cmd12=Wire.read();
    cmd13=Wire.read();
    cmd14=Wire.read();
    cmd15=Wire.read();
    cmd16=Wire.read();
    cmd17=Wire.read();
    cmd18=Wire.read();
    cmd19=Wire.read();
    cmd20=Wire.read();
    cmd21=Wire.read();
    cmd22=Wire.read();
    cmd23=Wire.read();
    cmd24=Wire.read();
    cmd25=Wire.read();
    cmd26=Wire.read();
    cmd27=Wire.read();
    cmd28=Wire.read();
    cmd29=Wire.read();
    cmd30=Wire.read();
    cmd31=Wire.read();
    cmd32=Wire.read();
   if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
    maintemp=(cmd4<<8)+cmd5;
    sumptemp=(cmd6<<8)+cmd7;
    roomtemp=(cmd8<<8)+cmd9;
    ph=(cmd10<<8)+cmd11;
    wavetime=(cmd12<<8)+cmd13;
    moonlight=(cmd14<<8)+cmd15;
    level=cmd16;
    atos=cmd17;
    TempRelay=cmd18;
    TempRelay2=cmd19;
    flow0=(cmd20<<8)+cmd21;
    flow1=(cmd22<<8)+cmd23;
    flow2=(cmd24<<8)+cmd25;
    mhour=cmd26;
    mminute=cmd27;
    msecond=cmd28;
    mday=cmd29;
    mmonth=cmd30;
    myear=(cmd31<<8)+cmd32;
    for (int a=0;a<howMany;a++)
      Wire.read(); // if the number of bytes is not 32, discard everything
