Page 2 of 6
Re: iOS Reef Angel Status
Posted: Wed Nov 06, 2013 9:18 pm
by AquaO
Wow
I installed and it works well.
Very easy to configure.
Congratulations for your good work.
I find a little issue, in app my Orp value is 47.7mv but in reality it's 477mv.
this is not a major problem.
Thank you very much for this app.
Posted: Wed Nov 06, 2013 9:26 pm
I will look at the formatting. i thought it was that way from my Android app. thanks for pointing that out.
Sent from my Nexus 7
Posted: Thu Nov 07, 2013 8:57 am
by romebaby
Thanks for all the work Curt. Just want to make sure I'm not missing something here - v1.0 is sensor status only, no outlet status or control, feed mode, etc.?
Posted: Thu Nov 07, 2013 9:01 am
romebaby wrote:Thanks for all the work Curt. Just want to make sure I'm not missing something here - v1.0 is sensor status only, no outlet status or control, feed mode, etc.?
Correct. I'm already working on the other stuff. I think I mentioned in an earlier post that I have the relay status control working but not the modes.
Posted: Thu Nov 07, 2013 9:18 am
by mikedizon
Wow Congrats!!! Thanks you. Finally I can view my water parameters using my IOS 7.
Can't wait to check out the updated versions your working on. For more functions work.
Posted: Thu Nov 07, 2013 8:36 pm
I do have a question to ask.....would people like to have this app built to run on iOS 6.1 or 6.0 as well?? Or is leaving it at iOS 7 and later ok? I think I should be able to make it run on iOS 6.1 or 6.0 pretty easily (just compile against that version).
Posted: Thu Nov 07, 2013 8:43 pm
You may not use any features yet that need ios7 but why limit yourself. But if its just a matter of compiling...then why limit it. I think for the most part if someones on the old version of ios then they have the previous version to use as well...
Posted: Thu Nov 07, 2013 9:03 pm
by Robert1969
Outstanding! Thank you Curt
Posted: Fri Nov 08, 2013 4:41 pm
lnevo wrote:You may not use any features yet that need ios7 but why limit yourself. But if its just a matter of compiling...then why limit it. I think for the most part if someones on the old version of ios then they have the previous version to use as well...
Agreed. I believe it's just as simple as compiling against ios6 but I have to confirm. I will have to do some testing to find out for certain.
Posted: Sat Nov 09, 2013 6:27 am
by Thavngr98
Did it get taken down?
Sent from my iPad using
Tapatalk
Posted: Sat Nov 09, 2013 6:33 am
by Thavngr98
Nm I got it. It's not in the store search had to use you web link.
Tapatalk
Posted: Sat Nov 09, 2013 8:27 am
Thavngr98 wrote:Nm I got it. It's not in the store search had to use you web link.
Tapatalk
That's odd. I was able to search for it from my iPad mini and found it just fine. Although I had to search for iPhone Only and not iPad because I currently only have the app listed as an iPhone only app but it runs just fine on my iPad mini. Don't worry, layout improvements are being designed and enhancements being made to operate just fine on iPhone and iPad.
Posted: Sat Nov 09, 2013 10:34 am
by Thavngr98
That's exactly what it was I was searching ipad only.
Tapatalk
Posted: Sat Nov 09, 2013 2:20 pm
by New2novas
Now I didn't read through the whole thread but I know my RA app doesn't work on ios7 and that help is needed there. My brother in law does programming for the OS conversions among other things and I was telling him about the issues and asked if there was a way he could help out. He's not a reefer nor does he have any type of tank but he said he'd be willing to help, he asked if there was a way to send him the current deal and he would look it over. I guess either contact me here or pm and let me know what I could give him as I'm not literate coding at the least. Couldn't hurt to have one more good brain on this I suppose
Posted: Sat Nov 09, 2013 3:01 pm
by johniii
New2novas wrote:Now I didn't read through the whole thread but I know my RA app doesn't work on ios7 and that help is needed there. My brother in law does programming for the OS conversions among other things and I was telling him about the issues and asked if there was a way he could help out. He's not a reefer nor does he have any type of tank but he said he'd be willing to help, he asked if there was a way to send him the current deal and he would look it over. I guess either contact me here or pm and let me know what I could give him as I'm not literate coding at the least. Couldn't hurt to have one more good brain on this I suppose
Binder made a new app for ios7
Posted: Sat Nov 09, 2013 3:26 pm
The old app is beyond repair. I wouldn't even bother at this point at some point binder will put up the source code for the new version and then we'd love for any contributions.
I may have the last copy with fixes on my git repo
github.com/lnevo/RAiOSApp
That app would need to be resubmitted though since the current owner is gone..thats why i said not worth the effort..
Posted: Sun Nov 10, 2013 7:10 am
by carlii
so will there be a new ios7 app?
Posted: Sun Nov 10, 2013 7:52 am
Its there...follow the link in binders signature
Posted: Mon Nov 11, 2013 12:50 am
by Poiromaniax
It's looking very slick - just to confirm though - 1.0.0 is basically just a monitor? No ability to turn on or off etc?
Posted: Mon Nov 11, 2013 5:24 am
Correct. The main purpose was to get established in the app store and get a new release available to ios7 users.
Posted: Mon Nov 11, 2013 10:46 am
by Sebyte
Hi Curt, nice to see that ISO 7 users can access their data again
I was in New Orleans last week when the app was released, it loaded fine and picked up the data via my DYNDNS address.
When I got back to Canada and on my wifi network the app reported that it could not access my DYNDNS address. As I understand it that is because I am within the network and not outside and coming in via port 2000 on my gateway/router.
I am ok with that, but I think I remember that John's app worked both inside and outside of the gatway/router. If that was the case would it be possible to add this ability in a future release?
I should add that I am running the app on an iPad
Keep up the good work.
Posted: Mon Nov 11, 2013 10:49 am
by Poiromaniax
I don't have that issue? Also using dyndns.....
Posted: Mon Nov 11, 2013 11:07 am
Its an issue with specific routers that don't allow access via the external ip address from internal connections. The old iphone app could use the portal as a proxy. But yeah that support is needed. However i could see curt adding home/away profiles like the android app has to address this instead.
Posted: Mon Nov 11, 2013 11:14 am
by Sebyte
I have a Bell connectivity hub, and will take a look at the setup. Before I had a 2Wire router and that worked ok. This unit has more features and may well just need a setting changed.
Posted: Mon Nov 11, 2013 11:38 am
One option is if the router has dns setting where you can add your own entry, you could point your dyndns name to your internal ip.
Posted: Mon Nov 11, 2013 4:57 pm
profiles could be added.....as well as multiple controllers....but i wont get ahead of myself
Posted: Mon Nov 11, 2013 5:32 pm
by jjdezek
I have that issue with my router, I can access it when on the Verizon signal but when I get on my wifi I can't access it, I have to change the IP address to accredit it on the wifi but then it won't access on Verizon signal. Small inconvenience to me, all I have to do is switch my wifi off on my phone and it works.
Posted: Tue Nov 12, 2013 10:27 am
by ReefingHavoc
I'm getting the error message "Error parsing XML data". This doesn't happen when I'm on the wifi network connected to RA
Posted: Tue Nov 12, 2013 2:44 pm
ReefingHavoc wrote:I'm getting the error message "Error parsing XML data". This doesn't happen when I'm on the wifi network connected to RA
Hmm...I will have to look into things some. I'm not sure what to tell you other than something in the XML data stream is failing.
Posted: Tue Nov 12, 2013 4:36 pm
It could be the buffer size on the wifi causing issues. I would suggest upgrading wifi to latest firmware and hopefully roberto can post the command here to increase the buffer, cause i forget.
