Cloud Wifi Attachment
Re: Cloud Wifi Attachment
You mentioned it was working.
Is it not?
slm222
Post by slm222 »
No it's doing as in my second to last post on page 4. It stays green until I plug in the USB into a computer or wall outlet. Then it acts as if it resets itself so I can't serial monitor it. I had left it connected to just the reef angel since the 8th and it stayed connected until the 11th and had been solid green since then as I am out of the country and have a house sitter telling me the color of the light.
If you are getting this: "Attempting to connect to Network named:
Not connected..."
Your code is wrong. It doesn't have the SSID name.
slm222
Post by slm222 »
It does connect and I have verified data going to the U-App. The problem is after a time it goes to green light only, It's acting as if it locks up. My previous posts explain the steps I've taken after it locks up.
How far is it from router?
I wonder if it is loosing the connection.
slm222
Post by slm222 »
It is 10-15' and open air connection. No blockages. In the same room
slm222
Post by slm222 »
I have been gone to Europe for 2 weeks and upon return it seems to unit is completely dead. Plugging in the USB or the cable to the reef angel. Should I email support?
Yes, send an email to info@reefangel.com
Kungpaoshizi wrote:Can we expect code uploads via the device someday?
I think that's one thing I would really like... Though I have gotten to the point where my reef tank setup is simple enough I don't need to change anything... lol
It seems jeelabs has released a couple months ago an alpha version of a firmware that emulates the stk500v2 that is required to program our microcontrollers :)
https://github.com/jeelabs/esp-link/releases
If someone is interested in investigating and checking if we could use it, let me know.
89delta
Post by 89delta »
Am Getting an error trying to compile...I have the latest Dev library.
My_RA_Version_3_0.cpp: In function 'void loop()':
My_RA_Version_3_0:372: error: 'class ReefAngelClass' has no member named 'CloudPortal'
//Sketch Date May 13, 2018
//Version 3.0
#include <SunLocation.h>
#define NUMBERS_8x16
#define PI 3.141593
//#include <RA_PCA9685.h>
//#define I2CPWM_PCA9685      0x40
SunLocation sl;
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
////// Memory Locations used by all formulas
#define Mem_B_AcclDay  100
// Note - 100 represents the hard coded Memory location used for this variable
// not the value for the variable.
// This variable represents the current day in Acclimation Cycle. Set this value to the same
// number of days as your AcclDuration to begin the acclimation cycle or set it to 0 to use
// your normal dimming end% values.
#define Mem_B_AcclDuration  101 // Set this value to how many days you want your acclimation cycle to take.
#define Mem_B_SlopeStart  102 // Set this to your desired starting acclimation end%.
/////// Memory Locations used by Blue Formula
#define Mem_B_AcclStartEndBlue  105    // Acclimation starting Slope end%
#define Mem_B_SlopeEndBlue  106    // slope End%
////// Memory Locations used by White Formula
#define Mem_B_AcclStartEndWhite  110 // Acclimation starting Slope end%
#define Mem_B_SlopeEndWhite  111    // Slope End%
// Define Portal Variables
#define Var_AcclDay         0  // Days Left in Coral Acclimation
//#define Var_StormMode       1  // Lightning Storm Mode: 0=Slow (For Unresponsive LED Drivers: Meanwell ELN), 1=Fast, 2=Mega
//#define Var_Wmaker       2
//#define Var_Tide         3
//#define Var_TideMode     4
//#define Var_LogATO       5
//#define Var_WCVol        6
#define Var_weekday        7  //Day of the week: 0=Sunday, 1=Monday, 2=Tuesday, 3=Wednsday, 4=Thursday, 5=Friday, 6=Saturday
void DrawCustomMain() {  //5,14
  char buf[16];
  //byte acclDay = InternalMemory.read(Mem_B_AcclDay);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 10, 4, "Paradise Reef");
  // Temp and PH
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,10,65,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,85, 65, "PH:");
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 48, 73, buf);
  ReefAngel.LCD.DrawLargeText(T1TempColor, DefaultBGColor, 10, 75, buf, Num8x16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 85, 75, buf, Num8x16);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 48, 82, buf);
  //ATO
  /*ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,40,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,40,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(55,43,5,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(70,43,5,COLOR_RED);
  //Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,93,"Salinity:");
  ReefAngel.LCD.DrawText(COLOR_NAVY,DefaultBGColor,75,93,text);
  //Sunrise/Sunset Times
  //ReefAngel.LCD.DrawText(0,255,5,52,"Rise:");
  //ReefAngel.LCD.DrawText(0,255,38,52,(sl.GetRiseHour()));
  //ReefAngel.LCD.DrawText(0,255,43,52,":");
  //ReefAngel.LCD.DrawText(0,255,48,52,(sl.GetRiseMinute()));
  //ReefAngel.LCD.DrawText(0,255,65,52,"Set:");
  //ReefAngel.LCD.DrawText(0,255,88,52,(sl.GetSetHour()));
  //ReefAngel.LCD.DrawText(0,255,100,52,":");
  //ReefAngel.LCD.DrawText(0,255,105,52,(sl.GetSetMinute()));
  //Moon Phase
  //ReefAngel.LCD.DrawText(0,255,5,72,"Moon:");
  //ReefAngel.LCD.DrawText(0,255,35,72,MoonPhaseLabel());
  // Display Acclimation timer
  //ReefAngel.LCD.DrawText(0,255,5,82,"Acclimation Day:");
  //ReefAngel.LCD.DrawText(0,255,105,82,acclDay);
  // Display LED %
  //ReefAngel.LCD.DrawText(0,255,12,92, "CW:");
  //ReefAngel.LCD.DrawText(197,255,32,92, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.LCD.DrawText(0,255,72,92, "RB:");
  //ReefAngel.LCD.DrawText(3,255,92,92, ReefAngel.PWM.GetActinicValue());
  // Display Relays
  ReefAngel.LCD.DrawOutletBox(12, 102, TempRelay);
    ReefAngel.LCD.DrawGraph(5, 12);
/*void SeasonalTemps ()
  static int heatArray[][2] = { {792,796},// default in case of error in month=0 (June)
                    {770,774},//January (winter)
                    {774,778},//February (winter)
                    {775,779},//March (early spring)
                    {779,783},//April (spring)
                    {785,789},//May (spring)
                    {792,796},//June (early summer)
                    {799,803},//July (summer)
                    {806,810},//August (summer)
                    {796,800},//September (early fall)
                    {787,791},//October (fall)
                    {780,784},//November (fall)
                    {775,779} };//December (early winter)
  ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
    //ReefAngel.Use2014Screen();  // Let's use 2014 Screen
    ReefAngel.AddSalinityExpansion();
    // Default Salinity compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.FeedingModePorts = Port3Bit| Port5Bit | Port6Bit ;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
  //sl.Init(-21.285833, 150.999722); // In decimal numbers (i.e. -18.285833, 147.699722)
  //sl.SetOffset(11,0,11,0); // rise_hour, rise_seconds, set_hour, set_seconds
    sl.Init(38.8447,-104.8433); // Colorado Springs,CO In decimal numbers (i.e. -18.285833, 147.699722)
    sl.SetOffset(-6,0,-6,0); // rise_hour, rise_seconds, set_hour, set_seconds
  randomSeed(now()/SECS_PER_DAY);
  //if (InternalMemory.read(Mem_B_ResetMemory))
    //init_memory();
        //Temp Code for Fuge Light
    //ReefAngel.StandardLights( Port5,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    //ReefAngel.StandardLights( Port7,sl.GetSetHour(),sl.GetSetMinute(),sl.GetRiseHour(),sl.GetRiseMinute() );
    // 15min Delay on Skimmer coming from Feeding oe Waterchange Modes
    ReefAngel.Relay.DelayedOn(Port3, 10);
    // Custom Variable for Portal
    ReefAngel.CustomVar[Var_weekday]=weekday();
    //Heater
    //SeasonalTemps();
    // Jebao Code
    pinMode(lowATOPin,OUTPUT);
    analogWrite(lowATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.LowATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    pinMode(highATOPin,OUTPUT);
    analogWrite(highATOPin,ReefCrestMode(50,20,true)*2.55);
    ReefAngel.DCPump.HighATOChannel = AntiSync ; // Jebo connected to AtoPINLow
    static int rmode;
    byte modes[] = { Lagoon, ReefCrest, TidalSwell, Sine, Gyre, NutrientTransport, Else };
    changeMode=true;
    static unsigned long feeding;
    if (now()-feeding<900) {
      // First 15 minutes after feeding mode stops. Smart_NTM
    } else if (now()-feeding<2250) { // 15 minutes plus 1 hour
      // Continue NTM for the next 60 minutes (75 minutes total)
    } else if (now()%SECS_PER_DAY<23400 || now()%SECS_PER_DAY>=72000) { // 6:30am / 8:00pm
      // Night mode (go to 30%)
      ReefAngel.DCPump.Speed=32;
      //ReefAngel.DCPump.SetMode(Constant,31,45,30);
      if (modes[rmode]==Else) {
        ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),25,true );    // ElseMode on sync mode, Portal Speed Setting +/- 25%
        ReefAngel.DCPump.Mode=modes[rmode];  // Put the mode to the random mode :)
////////// Variables used for all channels
// What day in the acclimation cycle it is
  byte acclDuration = InternalMemory.read(Mem_B_AcclDuration);
// Acclimation Duration in days
  byte startPercent = InternalMemory.read(Mem_B_SlopeStart);
// Normal start% being used by all 3 channels
////////// Blue Channel Variables
  byte acclStartEndBlue = InternalMemory.read(Mem_B_AcclStartEndBlue);
// Starting End% for Acclimation cycle
  float acclendPercentBlue = InternalMemory.read(Mem_B_SlopeEndBlue);
// Your target Blue end% once acclimation is complete
////////// Blue Channel Formula
  float acclPercentPerDayBlue = (acclendPercentBlue - acclStartEndBlue) / acclDuration;
// How much your Blue end% rises per acclimation day
  float acclFactorBlue = acclDay * acclPercentPerDayBlue;
// endPercentBlue will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentBlue = acclendPercentBlue - acclFactorBlue;
// Your final Blue end% for the day
////////// White Channel Variables
  byte acclStartEndWhite = InternalMemory.read(Mem_B_AcclStartEndWhite);
  float acclEndPercentWhite = InternalMemory.read(Mem_B_SlopeEndWhite);
// Your target White end% once acclimation is complete
////////// White Channel Formula
  float acclPercentPerDayWhite= (acclEndPercentWhite - acclStartEndWhite) / acclDuration;
// How much your White end% rises per acclimation day
  float acclFactorWhite = acclDay * acclPercentPerDayWhite;
// endPercentWhite will be offset by this much. If acclDay = 0 then this value will be 0
  byte endPercentWhite = acclEndPercentWhite - acclFactorWhite;
ReefAngel.CustomVar[Var_AcclDay]=acclDay;
// At the end of the day, we need to decrement the acclimation counter.
  static boolean acclCounterReady=false; // We need a boolean so we only do this once per day
  if (now()%SECS_PER_DAY!=0) acclCounterReady=true; // If it's not midnight we'll get the boolean ready
  if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) { // It's midnight, our bool is true and acclDay is more than 0
    acclDay--; // Reduce the counter
    acclCounterReady=false; // Reset the boolean flag
    InternalMemory.write(Mem_B_AcclDay,acclDay); // Update memory
    // handle updating sunrise and sunset values
    sl.CheckAndUpdate();
    //ReefAngel.Portal( "89delta","collin1123" );
    //ReefAngel.DDNS( "bc29" ); // Your DDNS is 89delta-bc29.myreefangel.com
    ReefAngel.CloudPortal();
  ActinicPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentBlue,120,(MoonPhase()/3));
  DaylightPWMValue=PWMSlope(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),startPercent,endPercentWhite,120,DaylightPWMValue);
  CheckCloud();
// RA_STRING1=U2FsdGVkX19/CQXYxFHutorfRImY8TNubevs+8+6Sjw=
// RA_STRING2=U2FsdGVkX1+7EBoxpKZdEtYXEBfHD+fIe5qrAeDKTa8=
// RA_STRING3=Gundel
// RA_LABEL LABEL_ACTINIC=Actinic
// RA_LABEL LABEL_DAYLIGHT=Daylight
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 6
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(7,30)
#define End_Cloud_Before NumMins(20,00)
#define Lightning_Change_per_Cloud 55
  // Add Random Lightning modes
#define Slow 0    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 1    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 2    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 3   // Like Mega, but with more lightning
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
byte LightningModes[] = { Fast, Mega, Mega2 };
    //ReefAngel.CustomVar[Var_StormMode]=lightningMode;
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
        switch (lightningMode) {
        case Mega:
        int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
        for (int i=0; i<a; i++)
          analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));    // Flash on
          analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
          wdt_reset();
      break;
       case Mega2:
      if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
          wdt_reset();
      break;
        case Fast:
          wdt_reset();
      break;
        case Slow:
        else lightningstatus=0;
        if (lightningstatus)
          DaylightPWMValue=100;
          DaylightPWMValue=0;
        delay(1);
        break;
        default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
    //ReefAngel.LCD.Clear(255,0,62,132,132);
  //ReefAngel.LCD.DrawText(0,255,5,62,"C");
  //ReefAngel.LCD.DrawText(0,255,11,62,"00:00");
  //ReefAngel.LCD.DrawText(0,255,45,62,"L");
  //ReefAngel.LCD.DrawText(0,255,51,62,"00:00");
      int x=0;
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart/60));
      //ReefAngel.LCD.DrawText(0,255,x,62,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,90,62,cloudduration);
    if (lightningchance)
      int x=0;
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))/60));
      //ReefAngel.LCD.DrawText(0,255,x,62,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
You are probably not using dev branch.
I just tested and it compiles without errors.
https://github.com/reefangel/Libraries/archive/dev.zip
madweazl
Post by madweazl »
Would I be able to use this without grabbing an Expansion Hub (currently running an expansion relay plus the original relay)?
Yes
GiraffeCat
Post by GiraffeCat »
Received my new Cloud WiFi Attachment today. Connected to its Wifi, entered all four required fields, and uploaded code via the Web Wizard. Connected the attachment, and had the Cyan light for a minute, and then just the blinking Magenta. Logged into my router and found the attachment was connected. Uploaded the code again and no change. Going to the uapp online tells me:
Cloud Server: Connected
Last Updated: Never
Forum Username: Unknown
Reset the WiFi attachment and input all four fields again ensuring correct username and password for the router and the forum. No change.
Do I need to put anything in the code generated by the Web Wizard? I noticed the web wizard left a few things out in regards to my expansion relays and the dimming expansion, so maybe it is leaving something else out? Do I need to put the forum username and password in the code like the old WiFi adapter?
Tried putting in the username and password like the old Wifi adapter and it wouldn't compile. (Didn't think I needed to since the Cloud attachment gets them up front, but tried anyway...)
Screenshots attached.
Any help would be appreciated.
Thank you in advance,
Dan
Screenshot (6).png (464.67 KiB) Viewed 43841 times
Screenshot (7).png (144.31 KiB) Viewed 43841 times
