Page 2 of 3
Re: Preloaded code and change...
Posted: Tue Mar 05, 2013 12:04 pm
by baroutas
Roberto what the diferent betwen DP & AP?
Posted: Tue Mar 05, 2013 12:15 pm
Daylight pwm and actinic pwm.
Posted: Tue Mar 05, 2013 1:09 pm
by baroutas
Yes but there is not ather difernts in the usage??
Posted: Tue Mar 05, 2013 1:31 pm
Well that's what AP/DP stand for. But they can be used for other purpose if not LED. Anything PWM or Analog controlled like Tunze or something else can be used.
You would address each seperately with the two functions SetActinic(byte value); and SetDaylight(byte value);
All you need to do is put the percent you want to put in the function for how you want the port set.
Posted: Wed Mar 06, 2013 1:03 pm
by baroutas
I do not know what is the problem?? I Buy a new led driver (Mean Well LPF 60D 12) and I have the same problem......NO DIMMING. if i buy the RA dimming expansion it will be ok? I bored to give my money with no resolts....
Posted: Wed Mar 06, 2013 1:39 pm
Can you post a diagram of how you connected your led strings to the driver?
60W on 12V is a lot of current.
Sent from my Galaxy S3 using Tapatalk 2
Posted: Wed Mar 06, 2013 1:55 pm
by baroutas
I hope to be clear the diagram.
Posted: Wed Mar 06, 2013 2:00 pm
Does it dim if you use the AA and 9V battery?
Did you try the potentiometer option too?
Can you measure the voltage on the RA dimming ports?
Posted: Wed Mar 06, 2013 2:46 pm
by baroutas
At 0% the AP out put 0,3 V and the led driver 2,6 V. At 100% the AP out put 9,8 V and the led driver 11,8 V. I don't try potentiometer or AA batteries . Is the second led driver with this problem . What I am doing wrong ?
Posted: Wed Mar 06, 2013 2:58 pm
Looks like your dimming channels are working fine.
I'm not so sure the drivers were supposed to go down in voltage like that.
Posted: Wed Mar 06, 2013 3:18 pm
by baroutas
I check the driver with AA 1,5 V and 9V batteries and again the same voltage to the led (11,7) V.
Posted: Wed Mar 06, 2013 3:58 pm
The voltage won't change.
It needs to be at about what you are seeing or it would go below the forward voltage and you wouldn't have enough voltage to power the LEDs.
What needs to change is the current. As you apply more or less voltage on the dimming input, the average current increases or decreases making it go brighter or darker.
Most people use only one string or 2 max. You are the first one doing it with several strings.
I would suggest you contact the manufacturer of the driver and check with them.
Posted: Thu Mar 07, 2013 6:22 am
by baroutas
I send mail to the Mean Well. We will see..... Thanks!!
Posted: Sun Mar 10, 2013 12:07 pm
by baroutas
Roberto! Today i use controller testter code in my RA and my led dimming normal (sun rise)! BUT... with Wizard code doesn't work why? Is that a bug?
Posted: Sun Mar 10, 2013 2:35 pm
Can you post your code?
Posted: Mon Mar 11, 2013 5:55 am
by baroutas
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,300,310 );
ReefAngel.StandardLights( Port3,13,50,22,0 );
ReefAngel.StandardLights( Port4,15,30,19,0 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
ReefAngel.StandardLights( Port6,20,30,23,59 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,2,0) );
ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
ReefAngel.Portal( "xxxxxx" );
Posted: Mon Mar 11, 2013 8:49 am
This line is telling the controller to go from 0 to 100 in 2 minutes.
Try a longer period like 60 minutes:
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,60,0) );
Posted: Mon Mar 11, 2013 9:48 pm
by baroutas
Οκ i try it!
Posted: Sun Mar 17, 2013 12:06 pm
by baroutas
Ιf I by dimming expansion module i will need and dimmable led driver, or the module work like led driver?
Posted: Sun Mar 17, 2013 12:14 pm
The ports on the dimming module are just like ap and dp on the relay box...yes you'll need a driver still.
Posted: Thu Apr 25, 2013 7:38 am
by baroutas
Hi again! If my diming port output voltage are 1-10V (during the port operation) then my RA is analog signal?
And if is 10V (during the port operation) stabilization then my RA is PWM?
Posted: Thu Apr 25, 2013 7:42 am
by baroutas
And something else. Τhe PWM led driver work with analog signal and the opposite??
Posted: Thu Apr 25, 2013 8:15 am
http://www.reefangel.com/Product_PWMvsAnalog.aspx
When measured with a standard multimeter, you can't tell which signal you have.
They both show the same voltage. You need a scope to see the signal.
The drivers will work with another signal, but you won't get a very good dimming linearity. It's best to use the correct one.
Posted: Thu Apr 25, 2013 8:26 am
by baroutas
Ok! I understand!!!!Thanks
