Page 2 of 9
Lee's Feature Complete PDE
Posted: Fri Mar 29, 2013 8:34 pm
Yah it's definitely a power user function...we'd need to wrap it in a simple API for users. But the benefit would be whatever number of callbacks with whatever name and other apps wouldn't have to be modified or anything to support more or less, or even the portal too :)
Posted: Fri Mar 29, 2013 8:37 pm
Anyway just an idea I've been wondering how we could do things like add more than 9 menu items or make screen management easier...etc.
Posted: Fri Mar 29, 2013 8:54 pm
Maybe I'm explaining wrong also, because in the long run it could be easier for users... Instead of
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "Vortech Mode";
prog_char menu4_label[] PROGMEM = "Refugium Light";
prog_char menu5_label[] PROGMEM = "ATO Clear";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "WLS Calibration";
prog_char menu9_label[] PROGMEM = "Date / Time";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
They would have
AddMenuItem("Feeding",myFeedingFunction);
AddMenuItem("WaterChange",ReefAngel.WaterChangeModeStart);
AddMenuItem("Vortech Mode",cycleVortechMode);
Anyway, definitely a lot of work but as I said the concept can apply in a lot of places, and we would definitely need some API work...if you don't think it's worth it, never mind...it would need everyone on board to make it worthwhile.
Re: Lee's Feature Complete PDE
Posted: Fri Mar 29, 2013 9:16 pm
I see now where you are trying to get.
I could have gone the route of storing char arrays too when I was coding the menu logic, but you will find out that you will run out of RAM memory quick if you keep storing char arrays in memory.
That's the reason those arrays are stored in PROGMEM. They do not consume RAM memory.
On the RA+, it may work because we got much more memory.
Posted: Sat Mar 30, 2013 5:20 am
Hehe wasn't it bill gates said 64k of ram was plenty :) I forget sometimes that we are working on these little arduino boards.
Posted: Sun Mar 31, 2013 12:52 pm
I originally was going to use function pointers for the menu's but it failed for me...big time. I kept having the controller run out of memory and lose the reference to the pointer and you would get out of memory exceptions and the controller would do random things....lock up, display strange text, etc. Of course, I was also calling new and delete to create the menu and trying to allow for dynamically created menus. This system, unfortunately, isn't designed to handle all that extra overhead. It's the low level logic stuff that works the best on it especially when we have so much involved. It could need to be revisited and retested because that was from 2010 when I was originally updating the menus.
Posted: Sat Apr 06, 2013 9:10 pm
Inspired by the Android apps ability to lock ports, I wrote up this code to reset the masks for my dosing pumps and auto feeder to make sure they don't get tripped by mistake. Gave myself a back door in case I do need to override for some reason, it's important that this runs before ReefAngel.ShowInterface() when Relay.Write() is issued.
// Override masks for things that should not be turned on by mistake
void lockPorts() {
  if(InternalMemory.reas(Mem_B_LockPorts) {
    // Reset RelayMaskOn
    bitClear(ReefAngel.Relay.RelayMaskOnE[0],FeederBit);
    bitClear(ReefAngel.Relay.RelayMaskOnE[0],DPump1Bit);
    bitClear(ReefAngel.Relay.RelayMaskOnE[0],DPump2Bit);
    // Reset RelayMaskOff
    bitSet(ReefAngel.Relay.RelayMaskOffE[0],FeederBit);
    bitSet(ReefAngel.Relay.RelayMaskOffE[0],DPump1Bit);
Posted: Mon Apr 29, 2013 4:05 pm
My new version is finally in production and posted :) Lots of new goodies!
Posted: Thu May 02, 2013 12:01 pm
So, talk about narrow misses and being saved by RA... I have a bug since implementing my new float switch configuration. I was using the same portal variable to alert if either switch was activated. The problem I had was that the skimmate collector switch check came after my other float switches and was resetting the value to true... thus no alert.
Luckily my wife txt'd me on the train that the water level in the display was low... luckily it had only been a few minutes. I was thrown off because I usually get those nice txt alerts that something is wrong before that... I turned my return back on and then my skimmer, and boom they went back off. After some peeking around I figured out what had happened. When the return chamber goes too low, the return and skimmer turn off to prevent cavitation of my pump. I re-enabled the pump but left the skimmer off so that I'd have some time before I got home to let things run.
What I saw when poking around was that my water level in my ATO reservoir had not changed in about 20 hours. It was at 92% for that duration... so I knew something was up. My ATO is a gravity feed.... or I thought. I guess it's more of a siphon feed which is controlled by a float valve. It's worked great for 9 months, but I had taken everything apart to get to my electronics this past weekend. Anyway, after resetting the siphon and hooking it back up, everything was back to normal. Skimmer put back on and all crisis averted.
I would have found out eventually thanks to my wife, but with her help and my RA, I was able to get everything going again and no issues. Without the portal charts, remote control relays, and failsafes programmed into my controller, I could have ended up with a burned up pump and a dead sump.
Anyway, I fixed the bug in my variable usage and a few other fixes that I'm not sure I updated. I'll be updating my code post later tonight after I upload it to my RA.
Posted: Thu May 09, 2013 8:28 pm
Posted: Thu May 09, 2013 8:38 pm
by enigma32
Nice. I wish I had space for fun toys like that :-)
Posted: Thu May 30, 2013 7:36 am
Latest version published. Lots of new stuff.
WiFiAlerts
Dosing by Volume
Log Dosing volume to portal
Virtual Outlets
Posted: Thu May 30, 2013 3:44 pm
by mudcat1
Lee,
I love your INO code. I have stole and learned so much from it. I really appreciate all of the assistance you have giving me working through getting WifiAlert working.
I am courious why you added the delays
skimmerAlert.SetDelay(3600);
atoAlert.SetDelay(3600);
Did you receive frequent alerts because these are float switches and the delays minimized the number of alerts you received? I am having that problem with the float switch that is submerged in my RO container that is used to alert me when the container is empty. It texts me every few minutes. If I add the SetDelay(3600) will it reduce the text frequency to 1 text message per hour?
Posted: Thu May 30, 2013 4:54 pm
mudcat1 wrote:Lee,
Exactly, that alert type will only send once an hour.
If skimmer is full, I don't need an alert either every 15 minutes and if the sump is low on water, I can turn off skimmer and run return till I get home or can have my wife open the shutoff valve I probably left closed. It's gravity based... I want to add a check to make sure it's draining at an expected level measured by the water expansion.
Posted: Sat Jun 01, 2013 9:56 am
Some more features. Some memory location flags (ie Vacation / AutoFeeder) flags are now represented by virtual outlets. They still need to be in memory but now I can change it in either the memory directly or through the outlet. Dosing routines have been fixed a bit and I can now update dosage volume or time and the result is calculated.
Posted: Sun Jun 02, 2013 10:03 pm
Ok. new feature some might be interested. I use the Water Level sensor to monitor my ATO reservoir. I use a gravity feed ATO so it's not something I can easily monitor if something isn't working right. Usually by the time I know of a problem, it's because the return pump has shutdown because the water level dropped too low. So I'm now calculating the ATO reservoir level every 6 hours. If the rate of loss per day is not greater than 15% then send me an alert. I *should* have a rate between 20-25% since my container goes 4-5 days. If a 6 hour period goes by and the rate has not moved by that much then there is a problem.
I also added a counter for the number of times my feeder is activated. Trying to tune an automated feeding schedule and I had an issue previously where it probably ran a few dozen times on me before I caught it. Now I'm paranoid.
Posted: Mon Jun 03, 2013 8:43 am
by cjrudy
lnevo wrote:Latest version published. Lots of new stuff.
WiFiAlerts
Dosing by Volume
Virtual Outlets
I'm sure I am missing something simple here but where exactly is your code published ? Cant seem to find it.
Posted: Mon Jun 03, 2013 9:02 am
At the beginning of the thread. 2nd post
Posted: Mon Jun 03, 2013 9:23 am
by cjrudy
lnevo wrote:At the beginning of the thread. 2nd post
Your just updating that everytime, got it, Thanks
Posted: Tue Jun 04, 2013 5:20 am
Just added daily mode change inside my custom rf mode. So now my speed will follow my tide wave form, but each day i should get a different wave form applied on top.
Posted: Wed Jun 05, 2013 11:36 am
by ufgators2k
Can you post the latest screen grabs of your custom main screens? I think it would help me understand the code more.
Posted: Wed Jun 05, 2013 11:52 am
Sure, here you go!
Took these a while ago and never got around to it!
Posted: Wed Jun 05, 2013 12:16 pm
by ufgators2k
Lee,
Thanks for the pics. That actually helps a lot. I had one quick question on your code. It appears that you have three relays in your draw relay function. Am I misinterpreting the code?
  // Draw Relays
  ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
  y+=12;
  y+=123;
  TempRelay = ReefAngel.Relay.RelayDataE[1];
  TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
  TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
Posted: Wed Jun 05, 2013 1:09 pm
Yes, I took those shots a few months ago before I added the additional relays..I moved the date line to the banner section and added a 3rd relay bar to the drawing. Good eyes!
If you looked close enough, the date on the controller is 4/29.
Posted: Wed Jun 05, 2013 2:17 pm
by ufgators2k
Wow, you have a lot of power going to your tank!
Posted: Wed Jun 05, 2013 5:41 pm
The third really doesn't exist. You reference any outlet you want, whether it is there or not. I use those outlets to interact with my RA and trigger certain functions. :)
Posted: Wed Jun 05, 2013 8:41 pm
Ok, I completely nailed the evaporation calculation routine. The original code worked, but was not very great. This one is it. I need to stop playing with my RA now and work on some other tank maintenance.... like that dreaded re-aquascaping...and more testing so I can get my dosers going finally.
Posted: Sat Jun 08, 2013 9:31 am
So in part of my last few updates I added a sub-mode to my tide simulation to allow it to switch daily the wave pattern that is applied. I think the overall affect is pretty cool. I like the daily switch a lot, it's like getting a different weather pattern each day :)
Posted: Sun Jun 09, 2013 5:14 pm
by jjdezek
got a few questions on this custom code. i read through your tutorial link and at the end it says
Also remember, if you are inside your own function, the controller will not be processing any of the functions
inside loop(). So the heaters/fans will not turn on/off with changes in temperatures. The lights will not turn
on/off on their schedule. The ATO will not turn on/off. The controller will not respond to WIFI requests. (To
respond to the WIFI requests, you will just need to call pingSerial() inside your code).
not sure im understanding this, is it saying if you do this code your heaters not going to turn on when your temp hits the low setting and turn off when hits high setting?
the other question can you make a menu option to toggle between wave patterns manully in the pwm actinic and daylight ports?
Posted: Sun Jun 09, 2013 5:26 pm
First off, you can have your own functions. If you loop inside your own function though you will not be processing other things. As long as your own function does its thing and comes back loop will still be processing.
Im not sure which tutorial your referring, i haven't written any. I don't have Jaebo pumps but i toggle my Vortech modes through a menu item with the joystick so you can use that as an example.
pingSerial is no longer needed in your code with the current libraries.
