ReefAngel.ActinicLights( Port7 ); // turn port 7 with actinic offset over standard lights schedule
ReefAngel.DelayedStartLights( Port8 ); // turn port 8 using standard lights schedule
ReefAngel.PWM.ActinicPWMParabola(120); // Parabola using actinic offset
ReefAngel.PWM.DaylightPWMParabola(InternalMemory.ActinicOffset_read()); // Parabola using actinic offset
Would this code work
wizard problem
Redadeath
Re: wizard problem
when it comes to programming i "always need help "
Redadeath
Re: wizard problem
I try it doesnt work and both white and blue channels ignored my pwm settings
Redadeath
Re: wizard problem
This is what i needrimai wrote:Ahh..
So, you want mh on the standardlights and both actinic and daylight on the standardlights + offset?
Is that it?
Both AP and DP will dim together, right? Or you also want offset for AP and DP?
Offset for ap and offset for dp
Redadeath
Re: wizard problem
CODE: SELECT ALL
ReefAngel.PWM.StandardActinic(InternalMemory.ActinicOffset_read()+60); // Parabola using actinic offset
When i use this code the relay start at the time of the actinic offset and shut down at the end in the same time the ap pwm signals still works for additional hour while the relay is already been shutdown
Redadeath
Re: wizard problem
would you give me the code for that Roberto please
but it is ignoring my internal memory settings for % of starting parabola
Re: wizard problem
ReefAngel.StandardLights(Port7,60);
http://www.easte.net/RA/html/class_reef ... class.html
