Re: Clouds and Lightining Effects using standard PWM channel
Posted: Thu May 30, 2013 11:24 am
Yeah, totally doable
Let me try to find some time to put this together.
https://forum.reefangel.com/
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(15,00)
#define End_Cloud_Before NumMins(22,00)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,15,180);
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=15;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,8,108,"Cloud");
ReefAngel.LCD.DrawText(0,255,8,118,"00:00");
ReefAngel.LCD.DrawText(0,255,90,108,"Storm");
ReefAngel.LCD.DrawText(0,255,48,108,"Length");
ReefAngel.LCD.DrawText(0,255,90,118,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=8; else x=14;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart/60));
if ((cloudstart%60)>=10) x=58; else x=64;
ReefAngel.LCD.DrawText(37,255,x,118,(cloudstart%60));
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=90; else x=96;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=108; else x=114;
ReefAngel.LCD.DrawText(37,255,x,118,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
