Page 2 of 3
Re: Reefology's code
Posted: Thu Feb 16, 2017 4:16 am
by Reefology
    InternalMemory.LCDID_write(255); //this line was added when i got a replacement RA+ board
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.Relay.DelayedOn(Port5 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // WP40
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW-8
    ReefAngel.DCPump.AntiSyncOffset = 125;
    // Wavemaker
    if ( ((hour() >= 2) && (hour() < 8)) || ((hour() >= 15) && (hour() < 19)) ) // off from 2am-8am & 3pm-7pm
        ReefAngel.Relay.Off(Port6);
        ReefAngel.WavemakerRandom( Port6, 30, 300 ); // random between 30 and 300 seconds
    // DC pumps....................................
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, Else, Gyre, NutrientTransport };
    if (now()%1800==0 || changeMode==true)  // Change every 30 mins (1800seconds) or controller reboot
    rmode=random(100)%sizeof(modes); // Change the mode by picking from our array
    changeMode=false;
    static unsigned long feeding;
    // Continue NutrientTranspot Mode for 30 minutes after feeding
    if (now()-feeding<1800)
    ReefAngel.DCPump.Mode=ReefCrest;
    ReefAngel.DCPump.Speed=75;
    // Night/Quiet mode
      else if (hour()>=2 && hour()<8 ) // 2am to 8am
    ReefAngel.DCPump.SetMode( Gyre,40,10 );
      else if (hour()>=15 && hour()<19) // 3pm and 7pm
    ReefAngel.DCPump.SetMode( ShortPulse,40,30 );
    //Storm mode
    else if (hour()>=1 && hour()<2) // 1am and 2am
    ReefAngel.DCPump.SetMode( Else,70,15 );
      else if (hour()>=11 && hour()<12) // 11am and 12pm
    ReefAngel.DCPump.SetMode( ReefCrest,80,15 );
    else if (hour()>=21 && hour()<22) // 9pm and 10pm
    ReefAngel.DCPump.SetMode( ShortPulse,85,30 );
    else if (InternalMemory.DCPumpMode_read()==11)
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
Posted: Wed Oct 11, 2017 2:36 pm
by Reefology
Hoping someone can help with this. I'd like to add Seasonal changes to my code but can't get it to compile.
void SeasonalTemps ()
  static int heatArray[][2] = { {782,786},// default in case of error in month=0 (June)
                    {760,764},//January (winter)
                    {764,768},//February (winter)
                    {765,769},//March (early spring)
                    {769,773},//April (spring)
                    {775,779},//May (spring)
                    {782,786},//June (early summer)
                    {789,793},//July (summer)
                    {796,800},//August (summer)
                    {786,790},//September (early fall)
                    {777,781},//October (fall)
                    {770,774},//November (fall)
                    {765,769} };//December (early winter)
  ReefAngel.StandardHeater( Port3,heatArray[month()][0],heatArray[month()][1]);
 }//end seasonalTemps
where exactly do I input this?
Posted: Thu Oct 12, 2017 7:15 pm
you have to simply copy the entire function and paste it into your INO file, most likely at the end of it. well after the last curly brace of the loop.
Posted: Fri Oct 08, 2021 5:15 am
by Reefology
  static int heatArray[][2] = { {780,784},// default in case of error in month=0 (May)
                    {764,768},//January (winter)
                    {768,772},//February (winter)
                    {772,776},//March (early spring)
                    {776,780},//April (spring)
                    {780,784},//May (spring)
                    {784,788},//June (early summer)
                    {788,792},//July (summer)
                    {784,788},//August (summer)
                    {780,784},//September (early fall)
                    {776,780},//October (fall)
                    {772,776},//November (fall)
                    {768,772} };//December (early winter)
  ReefAngel.StandardHeater( Port1,heatArray[month()][0],heatArray[month()][1]);
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
    SeasonalTemps ();
    ReefAngel.ActinicLights( Port2 ); //ATS pump
    ReefAngel.DayLights( Port3 ); //ATS light
    ReefAngel.StandardLights( Port4, 23,0,7,0); //Skimmer 11pm-7am
    ReefAngel.DosingPumpRepeat1( Port6 );
    ReefAngel.DosingPumpRepeat2( Port7 );
    ReefAngel.DosingPumpRepeat3( Port8 );
    ReefAngel.DCPump.LowATOChannel = Sync; // SW 8
    ReefAngel.DCPump.HighATOChannel = AntiSync; // SW 8
    //ReefAngel.DCPump.AntiSyncOffset = 125; // % (0-255) of main pump (Sync)
    // koralia 1150
    // if (hour()>=23 || hour()<11) ReefAngel.Relay.Off( Port5 );
    // else ReefAngel.WavemakerRandom( Port5, 120, 1800 );
    // DC pumps
    // To run this code must choose Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, TidalSwell, ShortPulse, Sine, LongPulse, Else, Gyre, NutrientTransport };
    if (now()%3600==0 || changeMode==true) { // Change every 60 mins (3600seconds) or controller reboot
    changeMode=false;
    if (now()-feeding<1800) {
    ReefAngel.DCPump.Mode=Else;
    ReefAngel.DCPump.Speed=80;
    // Night mode (go to 30%)
    } else if (now()%SECS_PER_DAY<39600 || now()%SECS_PER_DAY>=82800) { // 11pm to 11am
    ReefAngel.DCPump.Mode=Gyre;
    ReefAngel.DCPump.Speed=40;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    } else {
Posted: Mon Jan 31, 2022 8:24 am
by Reefology
Hoping someone from this great community can help as I'm not sure how to implement this. I'm looking to turn my kalk stirrer (port 7) off between 5pm and 11pm.
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 );
if the statement above is correct, where should I input it into my code?
Posted: Mon Jan 31, 2022 11:08 am
It has to be the line right after the kalkwasser function
Posted: Mon Jan 31, 2022 1:45 pm
by Reefology
Hi Roberto,
so like this?
if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off(Port7 );
Yes. Looks good
Posted: Mon Jan 31, 2022 4:50 pm
by Reefology
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit;
    ReefAngel.Relay.On( Port2 );
    SeasonalTemps();
    ReefAngel.ActinicLights( Port3 ); //Skimmer
    ReefAngel.DayLights( Port4 ); //ATS light
    if ( hour(now()) >= 17 && hour(now()) <= 23 ) ReefAngel.Relay.Off( Port7 ); //kalk dosing off 5pm-11pm
    // koralia 1150
    // DC pumps
    static int rmode;
    changeMode=false;
    } else {
Posted: Mon Jan 31, 2022 9:54 pm
by Reefology
hey Roberto, didnt work! any other ideas?
Posted: Mon Jan 31, 2022 10:11 pm
by Reefology
I tried the following in the custom code section instead and it worked:
// kalk reactor
else ReefAngel.DosingPumpRepeat2( Port7 );
Posted: Mon Jan 31, 2022 10:14 pm
by Reefology
    SeasonalTemps();
    //ReefAngel.DosingPumpRepeat2( Port7 );
    // koralia 1150
    // kalk reactor
    // DC pumps
    static int rmode;
    changeMode=false;
    } else {
Posted: Wed Feb 02, 2022 8:33 am
by Reefology
hey Roberto, wondering if this would work to turn off kalk reactor according to ph?
ReefAngel.PHControl( Port7 );
add this to the loop section and use it with the above code?
thanks
Posted: Wed Feb 02, 2022 9:51 am
Yes
Posted: Wed Mar 29, 2023 10:55 am
by Reefology
note to self: add something like this for my fish room fan.
if (ReefAngel.Params.Temp[T3_PROBE] >= 825) ReefAngel.Relay.On(Port6);
if (ReefAngel.Params.Temp[T3_PROBE] <= 805) ReefAngel.Relay.Off(Port6);
Posted: Tue Jul 09, 2024 9:36 am
by Reefology
My First RA* ino
#include <RA_TS.h>
#include <RA_TouchLCD.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <RA_Wiznet5100.h>
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetDHCP.h>
#include <PubSubClient.h>
#include <RA_CustomLabels.h>
#include <SoftwareSerial.h>
  static int heatArray[][2] = { {778,784},// default in case of error in month=0 (May)
                    {762,768},//January (winter)
                    {766,772},//February (winter)
                    {770,776},//March (early spring)
                    {774,780},//April (spring)
                    {778,784},//May (spring)
                    {782,788},//June (early summer)
                    {786,792},//July (summer)
                    {782,788},//August (summer)
                    {778,784},//September (early fall)
                    {772,780},//October (fall)
                    {770,776},//November (fall)
                    {766,772} };//December (early winter)
  ReefAngel.StandardHeater( Box1_Port1,heatArray[month()][0],heatArray[month()][1]);
    ReefAngel.Star();
    ReefAngel.FeedingModePortsE[0] = Port2Bit;
    ReefAngel.WaterChangePortsE[0] = Port2Bit;
    ReefAngel.WaterChangePortsE[1] = 0;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.LightsOnPortsE[0] = Port3Bit;
     // Ports that default on
    ReefAngel.Relay.On( Box1_Port8 );// Return
   SeasonalTemps();
    ReefAngel.ActinicLights( Box1_Port3 ); // Royal blue led strip
    ReefAngel.DayLights( Box1_Port4 ); // T5's
    ReefAngel.StandardLights( Box1_Port5,23,0,9,0 ); //Sump light
    ReefAngel.StandardFan( Box1_Port6 ); // Hood Fan
    ReefAngel.StandardLights( Box1_Port7 ); //Radions
    boolean buzzer=false;
 // Skimmer
    if ((ReefAngel.HighATO.IsActive()) || (hour()>=9 && hour()<=19)) ReefAngel.Relay.Off( Box1_Port2); // Turns off when collection container is full or from 9am-7pm
    else ReefAngel.Relay.DelayedOn( Box1_Port2,5); //delay start 5 mins
    ReefAngel.Network.Cloud();
Tested for a day and have since added;
1. 2nd relay box (original RA+ box) via the relay expansion.
2. calcium reactor (formally controlled via smart bar)
3. Ozone (formally controlled via smart bar)
4. extra temp probes
Posted: Thu Jul 11, 2024 7:28 am
by Reefology
Last night I added this to shut down skimmer if return pump shuts down.
// turn off skimmer if return pump is off
    if (!ReefAngel.Relay.Status(Box1_Port8)) ReefAngel.Relay.Override(Box1_Port2,0); // Turn off skimmer
I also define my relay ports by name, but have commented them out until I double check everything.
As well, trying to set up triggers using virtual relays, but am not having much luck. I tried this which reboots my RA*
// Virtual relay to purge Co2 from calcium reactor
    if (ReefAngel.Relay.Status(Box3_Port1)) {
        // Turn off Co2 and recirculation pump
        ReefAngel.Relay.Off(Box2_Port2);
        ReefAngel.Relay.Off(Box2_Port3);
        // Delay for 2 minutes
        delay(120000); // 120000 milliseconds = 2 minutes
        // Turn on feed pump for 10 minutes
        ReefAngel.Relay.On(Box2_Port1);
        delay(600000); // 600000 milliseconds = 10 minutes
        // Turn off Box3_Port1
        ReefAngel.Relay.Off(Box3_Port1);
Then I tried to simplify with this:
// Virtual relay test
    if (ReefAngel.Relay.Status(Box3_Port8)) {
        // Turn on fan
        ReefAngel.Relay.On(Box1_Port6);
        delay(30000); // 30000 milliseconds = 30 seconds
        // Turn off Virtual switch
        ReefAngel.Relay.Off(Box3_Port8);
...same result.
According to the coding assistant in the webwizard, the delay function is the issue but not sure how to fix this?
If anyone has a work around, would love to hear it.
Posted: Thu Jul 11, 2024 10:47 am
by brennyn21
You typically don't want to use delays in codes as it will halt all other code below the delay statements. You can use the millis() instead to keep track of the time passed and execute lines bases on the time passed. Here is an example below
Place in global Variables
enum State {
    IDLE,
    TURN_OFF_CO2_AND_PUMP,
    WAIT_TO_FEED_PUMP,
    TURN_ON_FEED_PUMP,
    WAIT_TO_TURN_OFF_FEED_PUMP,
    COMPLETE_CYCLE
State currentState = IDLE;  // Initial state
unsigned long lastUpdateTime = 0;  // Last update time
Place in Void Loop
unsigned long currentMillis = millis();
    // Check if the condition to start the sequence is true
    if (ReefAngel.Relay.Status(Box3_Port1) && currentState == IDLE) {
        currentState = TURN_OFF_CO2_AND_PUMP;
    switch (currentState) {
        case TURN_OFF_CO2_AND_PUMP:
            // Turn off CO2 and recirculation pump
            lastUpdateTime = currentMillis;  // Reset the timer
            currentState = WAIT_TO_FEED_PUMP;
            break;
        case WAIT_TO_FEED_PUMP:
            // Wait for 2 minutes before turning on the feed pump
            if (currentMillis - lastUpdateTime >= 120000) { // 120000 milliseconds = 2 minutes
                currentState = TURN_ON_FEED_PUMP;
            break;
        case TURN_ON_FEED_PUMP:
            // Turn on the feed pump
            currentState = WAIT_TO_TURN_OFF_FEED_PUMP;
            break;
        case WAIT_TO_TURN_OFF_FEED_PUMP:
            // Wait for 10 minutes before turning off the feed pump
            if (currentMillis - lastUpdateTime >= 600000) { // 600000 milliseconds = 10 minutes
                currentState = COMPLETE_CYCLE;
            break;
        case COMPLETE_CYCLE:
            currentState = IDLE;  // Reset the state to IDLE
            break;
        case IDLE:
            // Do nothing or handle other tasks
            break;
Posted: Thu Jul 11, 2024 12:01 pm
by Reefology
Thanks Brennyn, I'll give that a try later and let you know how it went.
I also tried the code below. And though it didn't reboot, it simply shut off the relays and nothing else
   //Virtual relay to purge Co2 from calcium reactor
    unsigned long startTime = 0;
    unsigned long delayDuration = 0;
    int state = 0;
    // Check if co2purge is on
    if (ReefAngel.Relay.Status(co2purge)) {
        switch (state) {
            case 0:
                // Turn off Co2, feed pump and recirculation pump
                ReefAngel.Relay.Off(co2);
                ReefAngel.Relay.Off(cafeed);
                ReefAngel.Relay.Off(carecirc);
                startTime = millis();
                delayDuration = 60000; // 1 minute
                state = 1;
                break;
            case 1:
                // Check if 2 minutes delay has passed
                if (millis() - startTime >= delayDuration) {
                    ReefAngel.Relay.On(cafeed);
                    delayDuration = 600000; // 10 minutes
                    state = 2;
                break;
            case 2:
                // Check if 10 minutes delay has passed
                    ReefAngel.Relay.Off(co2purge);
                    state = 0;
                break;
Posted: Fri Jul 12, 2024 10:39 am
by Reefology
Unfortunately nothing happens.
Heres the code I tried. Maybe you'll see something I don't. Thanks
#include <RA_TS.h>
#include <RA_TFT.h>
#include <RA_TS.h>
#include <Font.h>
#include <SD.h>
#include <SPI.h>
// Define Relay Ports by Name
#define heaters            Box1_Port1
#define skimmer            Box1_Port2
#define actinics           Box1_Port3
#define t5                 Box1_Port4
#define sumplight          Box1_Port5
#define fan                Box1_Port6
#define radions            Box1_Port7
#define return             Box1_Port8
#define cafeed             Box2_Port1 // CaRx Feed Pump
#define co2                Box2_Port2 // Co2 Solenoid
#define carecirc           Box2_Port3 // CaRx Recirculation Pump
#define dosing1            Box2_Port4
#define ozone              Box2_Port5
#define dosing2            Box2_Port6
#define powerheads         Box2_Port7
#define dosing3            Box2_Port8
// Virtual Relays
#define co2purge           Box3_Port1
  ReefAngel.StandardHeater( heaters,heatArray[month()][0],heatArray[month()][1]);
 //co2purge
 enum State {
    IDLE,
    TURN_OFF_CO2_AND_PUMPS,
    WAIT_TO_FEED_PUMP,
    TURN_ON_FEED_PUMP,
    COMPLETE_CYCLE
//end co2purge
    ReefAngel.Star();
    ReefAngel.AddExtraTempProbes(); // Adds 3 More Temp Probes
    ReefAngel.AddHumidityExpansion();  // Humidity Expansion
    ReefAngel.FeedingModePortsE[0] = Port8Bit;
    ReefAngel.FeedingModePortsE[1] = Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port8Bit;
    ReefAngel.WaterChangePortsE[1] = Port7Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.LightsOnPortsE[0] = Port5Bit | Port7Bit;
    ReefAngel.Relay.On( return );// Return
    ReefAngel.Relay.On( powerheads ); // DC power heads on smart bar
    // Ports that default off
    ReefAngel.Relay.Off( heaters ); // Heaters
    ReefAngel.Relay.Off( dosing1 ); // Dosing Pump 1
    ReefAngel.Relay.Off( dosing2 ); // Dosing Pump 2
    ReefAngel.Relay.Off( dosing3 ); // Dosing Pump 3
      //Virtual Relays
    ReefAngel.Relay.Off( co2purge );// Purge Co2 from Calcium Reactor
    ReefAngel.Relay.Off( Box3_Port2 );
    ReefAngel.Relay.Off( Box3_Port3 );
    ReefAngel.Relay.Off( Box3_Port4 );
    ReefAngel.Relay.Off( Box3_Port5 );
    ReefAngel.Relay.Off( Box3_Port6 );
    ReefAngel.Relay.Off( Box3_Port7 );
    ReefAngel.Relay.Off( Box3_Port8 );//Test Virtual Switch
    SeasonalTemps();
    ReefAngel.ActinicLights( actinics ); // Royal blue led strip
    ReefAngel.DayLights( t5 ); // T5's
    ReefAngel.StandardLights( sumplight,23,0,9,0 ); //Sump light
    ReefAngel.StandardFan( fan ); // Hood Fan
    ReefAngel.StandardLights( radions,1,30,9,30 ); //Radions
    ReefAngel.StandardLights( co2,12,35,23,30 ); // Co2 Solenoid
    ReefAngel.StandardLights( carecirc,12,30,23,55 ); // CaRx Recirculation Pump
    ReefAngel.DosingPumpRepeat1( dosing1 );
    ReefAngel.DosingPumpRepeat( ozone,180,1440,1200 ); // Ozone, on 3am=180mins offset from midnight, 1440=every 1440 mins (once a day), for 20 mins=1200 sec's
    ReefAngel.DosingPumpRepeat2( dosing2 );
    ReefAngel.DosingPumpRepeat3( dosing3 );
    // Dimming Channels
    ReefAngel.PWM.ActinicPWMParabola(14,15,21,45,0,100,0);
    ReefAngel.PWM.Daylight2PWMParabola();
    ReefAngel.PWM.Actinic2PWMParabola();
    // Turn off skimmer if return pump is off
    if (!ReefAngel.Relay.Status(return)) {
    ReefAngel.Relay.Override(skimmer, 0); // Turn off skimmer
    } else {
    ReefAngel.Relay.DelayedOn(skimmer,5); // Delay start skimmer when return pump is back on
    // Skimmer
    if ((ReefAngel.HighATO.IsActive()) || (hour()>=9 && hour()<=18)) ReefAngel.Relay.Off( skimmer); // Turns off when collection container is full or from 9am-7pm
    else ReefAngel.Relay.DelayedOn( skimmer,5); //delay start 5 mins
     // CaRx Feed Pump
    if ((hour() == 6 && minute() <=10) || (hour()>=13 && hour()<23) || (hour() == 23 && minute() <50)) ReefAngel.Relay.On(cafeed);//On from 6-6:10am and 1-11:50pm
    else ReefAngel.Relay.Off(cafeed);
    //start co2purge
    if (ReefAngel.Relay.Status(co2purge) && currentState == IDLE) {
        currentState = TURN_OFF_CO2_AND_PUMPS;
        case TURN_OFF_CO2_AND_PUMPS:
            // Turn off CO2 and Calcium Reactor pumps
            break;
            // Wait for 1 minute before turning on the feed pump
            if (currentMillis - lastUpdateTime >= 60000) { // 60000 milliseconds = 1 minute
            break;
            break;
            break;
            break;
        case IDLE:
            break;
    //end co2purge
    //light mover
    //if (hour()>=9 && hour()<=21) ReefAngel.DosingPumpRepeat( Port6,0,90,2 );   //  from 9am - 9pm, with 0 minutes offset from midnight moves every 90 minutes 2 seconds
    //else ReefAngel.Relay.Off( Port6);
   //carbon dosing
    //if (hour()>=6 && hour()<23) ReefAngel.DosingPumpRepeat1( Port8 );
    //else ReefAngel.Relay.Off( Port8);
  //kalk dosing
    //if ((hour()>13 && hour()<20) || (ReefAngel.Params.PH > 845)) ReefAngel.Relay.Off( Port7); //  Kalk off 1pm - 8pm & if pH is > 8.45
   // else ReefAngel.PHControl( Port7 );
// RA_STRING1=4rBCB5aEN369IDJFYl/ESQ==::NTdkYmJkMzM0ODdmMmE0NA==
// RA_STRING2=null
// RA_STRING3=null
// RA_LABEL LABEL_TEMP1=FishRoom
// RA_LABEL LABEL_TEMP2=Sump
// RA_LABEL LABEL_TEMP3=OverFlow
// RA_LABEL LABEL_TEMP4=LightCanopy
// RA_LABEL LABEL_TEMP5=Cabinet
// RA_LABEL LABEL_TEMP6=NotInUse
// RA_LABEL LABEL_ACTINIC2=Actinic 2
// RA_LABEL LABEL_DAYLIGHT2=Daylight 2
// RA_LABEL LABEL_PORT11=Heaters
// RA_LABEL LABEL_PORT12=Skimmer
// RA_LABEL LABEL_PORT13=Blue Leds
// RA_LABEL LABEL_PORT14=T5's
// RA_LABEL LABEL_PORT15=Sump Light
// RA_LABEL LABEL_PORT16=Fan
// RA_LABEL LABEL_PORT17=Radions
// RA_LABEL LABEL_PORT18=Return
// RA_LABEL LABEL_PORT21=Ca Feed
// RA_LABEL LABEL_PORT22=Co2 Sol
// RA_LABEL LABEL_PORT23=Ca Recir
// RA_LABEL LABEL_PORT24=Doser1
// RA_LABEL LABEL_PORT25=Ozone
// RA_LABEL LABEL_PORT26=Doser2
// RA_LABEL LABEL_PORT27=Power Heads
// RA_LABEL LABEL_PORT28=Doser3
// RA_LABEL LABEL_PORT31=Purge Co2
// RA_LABEL LABEL_PORT32=Virtual
// RA_LABEL LABEL_PORT33=Virtual
// RA_LABEL LABEL_PORT34=Virtual
// RA_LABEL LABEL_PORT35=Virtual
// RA_LABEL LABEL_PORT36=Virtual
// RA_LABEL LABEL_PORT37=Virtual
// RA_LABEL LABEL_PORT38=Test
Posted: Fri Jul 19, 2024 5:37 am
by Reefology
I've continued to try make this work using coding assistant with the following:
in Globals:
bool co2PurgeActive = false;
unsigned long co2PurgeStartTime = 0;
in void loop:
 // Check if the co2purge virtual relay is turned on
        // Step 1: Turn off co2, cafeed, and carecirc
        // Step 2: Use millis() to turn on cafeed after 30 seconds
        if (!co2PurgeActive) {
            co2PurgeActive = true;
            co2PurgeStartTime = millis();
        if (co2PurgeActive && millis() - co2PurgeStartTime >= 30000) { // 30 seconds
        // Step 3: Turn off cafeed after 10 minutes
        if (co2PurgeActive && millis() - co2PurgeStartTime >= 60000) { // 10 minutes
            co2PurgeStartTime = 0; // Reset the start time
It completes all tasks with the exception of turning off co2purge virtual relay. After numerous attempts, I can't seem to make anymore progress!
Posted: Sat Nov 02, 2024 7:24 am
by Reefology
Also tried to change the last line to ReefAngel.Relay.Override(co2purge,0); but the just executes the over ride and nothing else.
I'm also having the same issue with my auto feeder.
  doesn't work...executes everything correctly but runs indefinately when ReefAngel.Relay.Off is used.
  if using ReefAngel.Relay.Override(feednow,0); to turn off the virtual relay in the last Step,
  nothing executes and it overrides instantly to the off position
//add to globals:
  static unsigned long feedNowStartTime = 0;
  const unsigned long feedNowDuration = 13000; // 13 seconds in milliseconds
 //add to loop:
 // Check if the "feednow" virtual relay is turned on
if (ReefAngel.Relay.Status(feednow)) {
    feedNowStartTime = millis(); // Record the start time
    ReefAngel.Relay.On(feeder);
    // Check if the "feednow" relay should be turned off after 13 seconds
    if (millis() - feedNowStartTime >= feedNowDuration) {
        ReefAngel.Relay.Off(feeder); // Turn off the "feeder" relay
        ReefAngel.Relay.Off(feednow); // Turn off the "feednow" virtual relay
Posted: Sat Nov 02, 2024 11:40 am
by Reefology
latest attempt:
    if (ReefAngel.Relay.Status(co2purge) && !co2PurgeCompleted) {
            co2PurgeCompleted = true;
        if (co2PurgeCompleted = true) ReefAngel.Relay.Off(co2purge);
if (ReefAngel.Relay.Status(feednow) && !feedNowCompleted) {
        feedNowCompleted = true;
    if (feedNowCompleted = true) ReefAngel.Relay.Off(feednow);
Posted: Sat Nov 02, 2024 1:18 pm
by brennyn21
So I see 2 issues on each the feeder code and the Co2 Purge code
First lest address the co2 Purge code
This line is incorrect. You are setting the c02PurgeCompleted to true, but you should be comparing it to see if its true to turn off the port since it was set to true in the line above.
if (co2PurgeCompleted == true) ReefAngel.Relay.Off(co2purge);
The same issue with the feeder
which since we are comparing it to see if its true it should be double ==
if (feedNowCompleted == true) ReefAngel.Relay.Off(feednow);
Also just a heads up in your step 3 you have
but you are missing a zero so you have it for one minute 10 minutes should be 600000
Posted: Sun Nov 03, 2024 7:24 pm
by Reefology
thanks for taking the time to have a look but unfortunately I previously tried that as recommended via the coding assistant. Logic says it should work but doesn't in practice. I'll keep plugging along :)
