Page 3 of 5
Re: Coding Pwm module.
Posted: Sun May 20, 2012 10:34 am
by abhi_123
Will check it with multimeter & update you. Btw the channels which are assigned with fans are working as well as their status is also updating on the portal.
Posted: Mon May 21, 2012 7:19 am
by abhi_123
Have checked the channel with the help of multimeter.
reading is 3.9 on all channel at 3:00 p.m. local time & 1.1 at 5:00 p.m.
Posted: Mon May 21, 2012 8:42 am
Looks like it is working.
Are the drivers not turning on?
Posted: Mon May 21, 2012 9:00 am
by abhi_123
havnt attached any drivers yet. they are on their way will be reaching me this week.
Posted: Mon May 21, 2012 9:08 am
Ahh.
So, everything seems to be working if the voltage is changing.
But, this conversation actually gave me new ideas and I think we can make it so the parabola code can still be kept in the main code, so you can see the values on the Portal and we can override them in the PWM module when it's time for lightning.
Let me put something together.
Posted: Mon May 21, 2012 9:51 am
by abhi_123
Robert you are the man buddy. One noob question can't we make modules to communicate with the head unit so as to show the value on portal or any way to make them communicate directly with portal?
Posted: Mon May 21, 2012 8:16 pm
I think this should do it:
#include "Globals.h"
#include "ReefAngel_Features.h"
#include <avr/wdt.h>
byte PWMports[] ={
  3,5,6,9,10,11};
byte ChannelValue[] = {
  0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
  Serial.begin(57600);
  Wire.begin(8);
  Wire.onReceive(receiveEvent);
  randomSeed(analogRead(0));
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  wdt_enable(WDTO_1S);
  now();
  wdt_reset();
  //Serial.println(ChannelValue[0],DEC);
  if (cmdnum!=255)
    ProcessCMD(cmdnum,datanum);
    cmdnum=255;
    datanum=255;
  CheckCloud();
  for (int a=0;a<6;a++)
    analogWrite(PWMports[a],ChannelValue[a]);
  wdt_reset();
  if (howMany==5)
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    cmd5=Wire.read();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$')
      cmdnum=cmd4;
      datanum=cmd5;
      //Serial.println(cmd4,DEC);
      //Serial.println(cmd5,DEC);
    for (int a=0;a<howMany;a++)
      Wire.read();
void ProcessCMD(byte cmd, byte data)
  wdt_reset();
  // Individual Channel
  if (cmd>=0 && cmd<=5)
    ChannelValue[cmd]=data;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
  // Channels used by the actinic LEDs on the PWM Expansion module
  // These channels will not be dimmed when the cloud effect is triggered
  // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000100
  // Channels used by the daylight LEDs on the PWM Expansion module
  // These channels will be used for the spike when lightning effect is triggered
  // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B001011
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      // let's go through all channels to pick which ones will be dimmed
        if (bitRead(Actinic_Channels,a)==0)
          // this will slope down the channel from the current PWM to 0 within 3minutes.
          // then it will stay at 0 for the duration of the cycle
          // and finally slope up from 0 to PWM value within 3 minutes
          // it is basically an inversed slope
          ChannelValue[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ChannelValue[a],0,180);
        for (int b=0;b<6;b++)
          if (bitRead(Daylight_Channels,b)==1)
            else lightningstatus=0;
            if (lightningstatus) ChannelValue[b]=100;
            else ChannelValue[b]=0;
            //delay(10);
            ChannelValue[b]=0;
      cloudindex++;
      if (cloudindex < numclouds)
//  if (LastNumMins!=NumMins(hour(),minute()))
//    LastNumMins=NumMins(hour(),minute());
//    ReefAngel.LCD.Clear(255,0,120,132,132);
//    ReefAngel.LCD.DrawText(0,255,5,120,"C");
//    ReefAngel.LCD.DrawText(0,255,11,120,"00:00");
//    ReefAngel.LCD.DrawText(0,255,45,120,"L");
//    ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
//    if (cloudchance && (NumMins(hour(),minute())<cloudstart))
//      int x=0;
//      if ((cloudstart/60)>=10) x=11; else x=17;
//      ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
//      if ((cloudstart%60)>=10) x=29; else x=35;
//      ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
//    ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
//    if (lightningchance)
//      int x=0;
//      if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
//      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
//      if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
//      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Posted: Mon May 21, 2012 8:50 pm
by abhi_123
If m not wrong this code is using slope whereas the one which is uploaded in the module is using parabola. Should i update that code with this one?
Posted: Mon May 21, 2012 9:20 pm
I'm sorry... :(
Forgot to explain.
This code will override the settings coming from your main code when it is time for cloud/lightning.
Simply place the parabola for channels 0-3 back into your code.
Posted: Mon May 21, 2012 10:15 pm
by abhi_123
So i have to place parabola setting on my head unit code & lightning code in my pwm module?
Posted: Mon May 21, 2012 10:16 pm
yes
Posted: Tue May 22, 2012 4:04 am
by abhi_123
One small issue roberto. I want to keep all codes associated with my lighting inside the module only as i don't have enough memory space left in my head unit.
Posted: Tue May 22, 2012 7:21 am
You have memory for the sunrise/sunset effect just fine.
What you don't have space is for the lightning code, which I moved to the module.
Posted: Tue May 22, 2012 8:04 am
by abhi_123
Should i enter this in my head unit code
 ReefAngel.PWM.SetChannel(0,PWMParabola(9,0,17,0,10,90,0));
    ReefAngel.PWM.SetChannel(1,PWMParabola(9,0,16,30,20,95,0));
    ReefAngel.PWM.SetChannel(2,PWMParabola(9,0,20,0,0,100,0));
    ReefAngel.PWM.SetChannel(3,PWMParabola(9,0,12,0,25,100,0));
Posted: Tue May 22, 2012 8:06 am
exactly :)
Posted: Tue May 22, 2012 8:38 am
by abhi_123
Great. Can we make wavemaker to toggle along with lightning & thunderstorm to givemore natural look?
Do i am becoming greedy.lol
Posted: Tue May 22, 2012 8:45 am
Let's get the other stuff done first.
You still need to test to see if it worked :)
Posted: Sun May 27, 2012 12:12 pm
by abhi_123
Hi,
I havn't saw any cloud or lightning feature yet with my lights.
Posted: Sun May 27, 2012 2:02 pm
Did you get your leds hooked up already?
Posted: Sun May 27, 2012 8:01 pm
by abhi_123
Yep.
Posted: Sun May 27, 2012 8:45 pm
Nice. Is the Portal updating all right?
Posted: Sun May 27, 2012 9:10 pm
by abhi_123
Yep. No prob with the portal now. The only prob is that i am not getting features of led lighting like sunrise sunset as per calender, cloud, thounderstorm etc etc.
Posted: Mon May 28, 2012 10:20 am
by abhi_123
Bump.
Posted: Mon May 28, 2012 2:42 pm
I can't test it now, but try this:
PWM code:
   int cloudstart=0;
   byte numclouds=0;
   byte cloudindex=0;
   int LastNumMins=0;
byte PWMports[] ={
  3,5,6,9,10,11};
  0,0,0,0,0,0};
byte SeasonsVar[]={
  0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
  Wire.begin(8);
  Wire.onRequest(requestEvent);
  pinMode(3,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
  now();
  wdt_reset();
  if (cmdnum!=255)
    cmdnum=255;
    datanum=255;
  CheckCloud();
void requestEvent() {
  SeasonsVar[0]=cloudstart/60;
  SeasonsVar[1]=cloudstart%60;
  SeasonsVar[2]=(cloudstart+(cloudduration/2))/60;
  SeasonsVar[3]=(cloudstart+(cloudduration/2))%60;
  SeasonsVar[4]=cloudchance;
  SeasonsVar[5]=lightningchance;
  Wire.write(SeasonsVar,6);
  wdt_reset();
  if (howMany==5)
    cmd1=Wire.read();
    cmd2=Wire.read();
    cmd3=Wire.read();
    cmd4=Wire.read();
    cmd5=Wire.read();
      cmdnum=cmd4;
      datanum=cmd5;
      Wire.read();
  wdt_reset();
void CheckCloud()
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            ChannelValue[b]=0;
      cloudindex++;
//      int x=0;
//      int x=0;
  cstart*=60;
  cend*=60;
Posted: Mon May 28, 2012 2:59 pm
On your main code, add this above setup():
byte SeasonsVar[]={
  0,0,0,0,0,0};
int LastNumMins=0;
This to loop():
  Wire.requestFrom(8,6);
    if (Wire.available()) SeasonsVar[a]=Wire.read();
    if (SeasonsVar[4])
      int x=0;
      if (SeasonsVar[0]>=10) x=11; else x=17;
      ReefAngel.LCD.DrawText(0,255,x,120,SeasonsVar[0]);
      if (SeasonsVar[1]>=10) x=29; else x=35;
      ReefAngel.LCD.DrawText(0,255,x,120,SeasonsVar[1]);
    if (SeasonsVar[5])
      int x=0;
      if (SeasonsVar[3]>=10) x=51; else x=57;
      ReefAngel.LCD.DrawText(0,255,x,120,SeasonsVar[3]);
      if (SeasonsVar[4]>=10) x=69; else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,SeasonsVar[4]);
Posted: Tue May 29, 2012 5:17 am
by abhi_123
well do i need to delete the parabola setting before putting this inside the loop?
Posted: Tue May 29, 2012 7:47 am
No, what this is supposed to do is draw the time that the next cloud will happen.
It should draw right below the clock.
Posted: Tue May 29, 2012 8:29 am
by abhi_123
Alright. So should i put this in custom code below the parabola?
Posted: Tue May 29, 2012 8:38 am
That works.
Posted: Tue May 29, 2012 9:22 am
by abhi_123
loaded the code. its displaying C16:51 & L56:31. What does it means?
