Eheim autofeeder
Piper
Re: Eheim autofeeder
It depends on your relay. I used a 5v relay to trigger so I can use my I/O module. Other have used 12v relays. I would think a 12v relay with the DC power expansion would work just fine.
You will need ~3v to power the feeder though. I had a hard time finding a 3v wall wart so I used a 5v and a LM317T voltage regulator to get to 3.3v.
- Sacohen
You are closing the contact, thereby completing the circuit and letting voltage through to the feed button.
Each port on the Power Expansion Module is relay and would do the same thing that Piper did above.
Unless I'm missing something I don't see the reason to use the DC Expansion port to trigger a relay if we can just set the expansion port to be on for 1 second and then turn off.
No, each port in the power control expansion module is not a relay. Each port has a driver that is capable of closing a relay or driving a small 12VDC motor.
You would still need the relay to close the contact of a relay to simulate a push button press.
- lnevo
That's not true. In the scenarios the 5V/12V relay is closing the circuit that the push-button woudl normally close. The RA relay or Power expansion port is only going to power the relay that closes the circuit. It's not feeding voltage to the button the way you described.
Piper
Lee explained that better than I did. Think of the relay as a pair of hands touching a wire from each side of the feeder button together which essentially bypasses the button. You need to power the relay to activate the hands though. 5v and 12v relays are cheap easy to come by. You'd obviously want to go with the 12v relay if you want to power it with your DC power expansion.
If you can find a 3v wall wart you can use that to replace the batteries in the feeder itself if you want to. Or just leave the batteries in there.
~Charlie
~Charlie
- Sacohen
Finding a 3v PS is not a problem. I found a link in another thread for one at Radio Shack and I just I'll get a small 12v DC relay and fit it into the are where the batteries would go and all should be fine.
- Sacohen
This is the Power Supply that was posted in another thread.
http://www.radioshack.com/product/index ... Id=3802149
I'll connect it to the battery leads.
If I use that and this 12VDC/1A SPDT Micro Relay connected to the push button leads.
http://www.radioshack.com/product/index ... Id=2062481
I should be OK.
I should be able to leave the actual push button connected in place and use that if I were at home and wanted to give an extra feeding, correct?
I should be OK.
- lnevo
I cant see the pics but my push button still works and i use it all the time.
Piper
Yep. Mine works that way too. I also tied it to a button via my I/O module that activates it as well. My feeder is in the far back corner of my canopy and hard to get to. I put a few buttons in a small enclosure that is Velcro's to the inside of the canopy door where it is easy to get to when you open it up to feed.Sacohen wrote:I should be able to leave the actual push button connected in place and use that if I were at home and wanted to give an extra feeding, correct?
egadgetjnr
Hey piper, how did you use it with you IO module? I want to do something similar for my ozone but at the moment only have it setup to power a 12v wall wart relay to trigger it on and off. Could you take some photos and possibly show some code on how you coded it? I just can't get my head around how you use the IO module to trigger the relay or switch.Piper wrote:Yep. Mine works that way too. I also tied it to a button via my I/O module that activates it as well. My feeder is in the far back corner of my canopy and hard to get to. I put a few buttons in a small enclosure that is Velcro's to the inside of the canopy door where it is easy to get to when you open it up to feed.Sacohen wrote:I should be able to leave the actual push button connected in place and use that if I were at home and wanted to give an extra feeding, correct?
- Sacohen
So I've done some looking at this and other Auto Feeder threads and this is the code I've come up with.
The Relay in the feeder will be triggered off my Power Expansion Module Port #3, which I will set up like this...
Lee you are the most familiar with my code (since you just reworked it for me).
Does this look good?
It looks like this will drop the power on the Jebao pumps like turning on Feeding Mode from the head unit or the Andriod App. Is that correct?
Will it work with the NTM that is set up to run after a feeding?
Will this work if I wanted to do a manual feeding from the RA head unit or the Andriod App?
If not I guess I could always do a manual trigger on the Feeder Port.
Am I asking to many questions, just tell me to shut up
static unsigned long feeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( feeding == 0 ) {
feeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-feeding>=60) && (now()-feeding<=61)) //if between 60 and 61 seconds has past
if ( feeding > 0 ) {
feeding = 0;
}Code: Select all
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Feeder Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8Does this look good?
- lnevo
It looks fine and should trigger everything you currently do with Feeding mode. The call to FeedingModeStart() is the same as hitting the feeding button in the apps/portal or with joystick. Good job!
- Sacohen
Thank you. Again the work was done already (I think by you actually for someone else) I just took it and modified it a bit.
Piper
Will do. If not tonight, I can get to it tomorrow night.egadgetjnr wrote: Hey piper, how did you use it with you IO module? I want to do something similar for my ozone but at the moment only have it setup to power a 12v wall wart relay to trigger it on and off. Could you take some photos and possibly show some code on how you coded it? I just can't get my head around how you use the IO module to trigger the relay or switch.
egadgetjnr
No worries. Thank youPiper wrote: Will do. If not tonight, I can get to it tomorrow night.
- Sacohen
Got my feeder today. It's much smaller than I thought.
Will probably mod and set it up this weekend.
Thanks for the help.
Piper
I had a chance to get to this tonight. I'm 90% sure this is the code I uploaded to my I/O module. I basically copied/pasted what Roberto and others put together and haven't really modified much at all.Piper wrote:Will do. If not tonight, I can get to it tomorrow night.egadgetjnr wrote: Hey piper, how did you use it with you IO module? I want to do something similar for my ozone but at the moment only have it setup to power a 12v wall wart relay to trigger it on and off. Could you take some photos and possibly show some code on how you coded it? I just can't get my head around how you use the IO module to trigger the relay or switch.
#include <avr/wdt.h>
byte IOports[] ={3,5,6,9,10,11};
byte ChannelValue[] = {0,0,0,0,0,0};
byte cmdnum=255;
byte datanum=255;
byte IOOut=0;
void setup() {
wdt_enable(WDTO_1S);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
Wire.begin(9);
for (int a=0; a<6; a++) {
pinMode(IOports[a],INPUT);
digitalWrite(IOports[a],HIGH); //pull up resistor
// digitalWrite(IOports[a],LOW); //pull up resistor
void loop() {
wdt_reset();
if (cmdnum != 255) {
ProcessCMD(cmdnum,datanum);
cmdnum=255;
datanum=255;
void requestEvent() {
IOOut=0;
IOOut += digitalRead(IOports[a])<<a; //pull up resistor
Wire.write(IOOut);
wdt_reset();
if (howMany == 5) {
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
if (cmd1=='$' && cmd2=='$' && cmd3=='$') {
cmdnum=cmd4;
datanum=cmd5;
//Serial.println(cmd4,DEC);
//Serial.println(cmd5,DEC);
else {
for (int a=0; a<howMany; a++) {
Wire.read();
void ProcessCMD(byte cmd, byte data) {
wdt_reset();
// Individual Channel
if (cmd>=0 && cmd<=5) {
ChannelValue[cmd]=data;
pinMode(IOports[cmd],OUTPUT);
analogWrite(IOports[cmd],data);
I also added this to the very bottom of my INO file:
// * I/O Expansion
void IOSetChannel( byte channel, boolean status) {
Wire.beginTransmission(I2CIO);
Wire.write("$");
Wire.write("$");
Wire.write("$");
Wire.write(channel);
Wire.write(status?255:0);
Wire.endTransmission();
// Just below my includes I define my I/O ports:
// I/O Module Constants
#define IO_Port_1 0
#define IO_Port_2 1
#define IO_Port_3 2
#define IO_Port_4 3
#define IO_Port_5 4
#define IO_Port_6 5
// I have this in my loop to monitor my I/O ports:
// Check to see if we hit the feeding mode button to trigger the relay
// If so, set it back to low and clear the flag
if (ioAutoFeederRelayTriggered == true) {
IOSetChannel(IO_Port_1,LOW); // Sets channel 0 to LOW
ioAutoFeederRelayTriggered = false;
if(!ReefAngel.IO.GetChannel(IO_Port_5)) {
// ReefAngel.FeedingModeStart();
IOSetChannel(IO_Port_1,HIGH); // Sets channel 0 to HIGH
ioAutoFeederRelayTriggered = true;
// Start/Stop Feeding Mode
if(!ReefAngel.IO.GetChannel(IO_Port_3)) {
if (!ReefAngel.DisplayedMenu==FEEDING_MODE) {
else {
ButtonPress++;
// Start/Stop Water Change Mode
if(!ReefAngel.IO.GetChannel(IO_Port_4)) {
if (!ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
else{
ButtonPress++;
// Trigger Nutrient Export Mode
if(!ReefAngel.IO.GetChannel(IO_Port_6)) {
triggerNutrientExportMode();
//ButtonPress++;
I put 4 small tact switches into a small Radio Shack enclosure and velcro'd that inside my canopy door. That feeds down to my I/O module sitting in a cabinet next to my tank. The buttons are wired into ports 3 through 6 (counting from 1 as #defined above, not 0). If the first button is pressed (IO_Port_3) that will put the tank into feeding mode. Button 2/IO_Port_4 the tank goes into water change mode.
Pressing button 3/IO_Port_5 is what actually triggers the feeder. I have a 5v relay connected to IO_Port_1 (port 0). When you press button 3 it sets IO_Port_1 to high with this: IOSetChannel(IO_Port_1,HIGH);. That sends ~5v to the relay which is wired to both sides of the tact switch on the feeder which triggers it to feed/rotate. I also set a flag so I can check to see if IO_Port_1 is high so I can set it back to low and shut off the relay. You can also eliminate the flags with something along the lines of this:
if (ReefAngel.IO.GetChannel(IO_Port_1)) {
I do have a couple of other problems/TODOs to take care of but I've been too busy lately. I need to "debounce" my buttons. Sometimes I'll get multiple presses when I hit a button once. I'm running a modified version of the dev branch of the libs and the feeding mode and water change mode are not working like they did when I was on the current libs. All are minor issues which wont change the basic concept.
Let me know if you still want pictures. I have the I/O module and related enclosures stuffed in the back of my cabinet. I need to dig them out to get good pics.
~Charlie
ozworld
I also used a small 5V relay inside and ran a thermostat 4 in 1 cable (2 for the 3v power supply and 2 to the ATO port). My questions is: what code can I use to trigger the ATO high port to enable the relay? (I have a Reef Angel + Controller).dcartier wrote:I bought one of these for use over Christmas. I installed a micro 5V relay inside and ran a cable out with an 2 pin ATO connector on it. It worked great. Kept things fed for a week.
Dennis
- Sacohen
I have the code in one of my posts at the top of this page.
You just need to modify it to work with whatever port you are going to use to trigger it.
ozworld
Thanks Steve, what I'm looking for is the actual trigger for the ATO High port that is connected to the auto feeder relay.
- Sacohen
I don't know about that. I'm not doing it that way. I'm using the Power Expansion Module to send a 12v trigger to a 12v relay that will close the circuit of the feed button.
- Sacohen
So what actually triggers the relay here?
I know I'm going to use port #3 on my Power control module (#define Feeder Box1_Port3) to send the 12v to the relay, but I don't see where Port #3 is referenced in the code.
feeding = 0;
}Code: Select all
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
#define Dummy Box1_Port8- lnevo
Is that my code?
That powers the wall wart and then powers the relay...
- Sacohen
I think it is your code. I had been looking at all the threads when the topic first came out and I found this one that I liked.
So since I have Box1_Port3 defined as Feeder it should trigger the port on my Power Control Module.
I had Port 3 defined as Feeder and plugged a shop light into it so I could visually see it come on and nothing happened.
Is it to fast to trigger a light?
- lnevo
Its only on for one second.. You can increase it look for 60 and 61
- Sacohen
That's what I thought. 1 second should be enough for me to see a flash of light but I changed it to 60 and 700 so it should be on for just over 11 min.
Nothing came on.
The port and light both work because I can manually turn the port on from my phone and the light come on.
So something isn't right.
Nothing came on.
#define Feeder 3
#define Pumps 4
#define Sump_Fan 5
#define Unused 8
#define Unused Box1_Port3
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,29,32);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=1200;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
static int rmode;
// Add Else Mode definition..
const int Else=16;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
if ((now()%SECS_PER_DAY==30600)) //if it is 8:30pm
if ((now()-feeding>=60) && (now()-feeding<=700)) //if between 60 and 700 seconds has past
feeding = 0;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Speed=30;
if (rmode==Else) {
ReefAngel.DCPump.Speed=ElseMode(InternalMemory.DCPumpSpeed_read(),20,true ); // ElseMode on sync mode, Portal Speed Setting +/- 20%
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Water Level
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
}- lnevo
You've got a wierd section in there that sets feeding to 0 if its greater than 0. That resets the variable so it never gets > 60...
Its in a wierd else all by itself and it seems like it may have been part of the dcpump feeding section i cant tell...
- Sacohen
Are you talking about this?
feeding = 0;
I thought that was a little strange too, but I wasn't sure about it.
It wasn't part of the of the dcpump feeding section, that was in the code that I had found for the auto feeder that I posted here a while back.
The DCpump feeding was like this before I added the autofeed code.
static unsigned long feeding;
I put the Auto Feed code here.
if (rmode==Else) {
Should I remove the
else {
feeding = 0;
feeding = 0;
if (rmode==Else) {
Should I remove the
else {
feeding = 0;
- lnevo
- Sacohen
Ok. I'm at the Drs with Seth for a wellness checkup.
I'll try it when I get home.
