Page 3 of 5
Re: Multiple on/off times
Posted: Thu May 30, 2013 5:35 am
by Sacohen
Lee; I haven't had a chance to try your code out, but thanks for the work on it.
When I went to upload it the Arduino software said that it could find the com port.
I check the Tools > Com Port and it was grayed out, so I gotta figure out what happened there before I can upload anything.
As soon as I get ti upload an tested I'll let you know how it worked.
Thanks again for the work on it though.
Posted: Thu May 30, 2013 5:53 am
Sometimes that happens...try resetting the cable and also rebooting sometimes to clear things up if necessary.
Posted: Thu May 30, 2013 6:04 am
by Sacohen
I did try resetting the cable, but I haven't tried rebooting the unit.
I'll try that when I get home, but I did remove the drivers from Device Manager hoping they would re-install on a boot up, but they didn't so I have to re-install the drivers first and then see what happens.
Posted: Thu May 30, 2013 6:30 am
by cosmith71
Sacohen wrote:Lee; I haven't had a chance to try your code out, but thanks for the work on it.
I get this when I've stuck the cable in wrong, either backwards or too far to the left.
Posted: Thu May 30, 2013 6:43 am
by Sacohen
Thanks Colin. I will double check that too, but I'm certain it was not backwards.
It may have been to far over to the left, but I don't think so.
I always check that because I read you can damage the head unit if it's not plugged in correctly.
Posted: Thu May 30, 2013 4:43 pm
by Sacohen
Lee that code seems to have worked.
As soon as I was done uploading it the ATO pump kicked on, because the Water Level was at 29% and it ran until it got to 31%.
I missed the 7pm cycle on this test, but since we didn't touch that portion of the code, I'm sure it is fine, but I'll see at the 1am cycle, or at least see what the relay activity says happened.
Thanks for the help again.
Posted: Thu May 30, 2013 4:57 pm
Sweet
Posted: Thu May 30, 2013 7:03 pm
by Sacohen
Yes. Very sweet. I love this controller.
I don't think what I was asking for was doable with any of the other controllers.
I don;t know how to thank you guys enough for helping me out with this.
Posted: Thu May 30, 2013 7:40 pm
Sacohen wrote:Yes. Very sweet. I love this controller.
Most likely not at all :)
Posted: Fri May 31, 2013 6:01 am
by Sacohen
Something still isn't right with the code.
It did the fill right after the code was uploaded, but this morning it was at 28% and had not kicked in during the night.
I guess it did the fill right after the code was uploaded because it had not been stopped or turned off, but when the 1am cycle came it did not turn the ATO watch back on.
I'm going to triple check the code to see if I didn't delete something when I placed it Lee's new code into my existing code.
Posted: Fri May 31, 2013 6:22 am
Can you post your whole new code again...want to make sure also I didnt miss anything.
Posted: Fri May 31, 2013 6:59 am
by Sacohen
No problem.
I was going to check it first, but here it is.
I didn't want to bother you for something I may have messed up.
#include <Globals.h>
#include <RA_Wifi.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <[color=#006699]LED[/color].h>
#include <RA_TempSensor.h>
#include <[color=#006699]Relay[/color].h>
#include <RA_PWM.h>
#include <[color=#006699]Timer[/color].h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#CC6600]unsigned[/color] [color=#CC6600]long[/color] ATOUpdate=0;
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
    [color=#7E7E7E]// This must be the first line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color]();  [color=#7E7E7E]//Initialize controller[/color]
    [color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = 0;
    [color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port4Bit[/color] | [color=#006699]Port6Bit[/color];
    [color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color];
    [color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port2Bit[/color];
    [color=#7E7E7E]// Use T2 probe as temperature and overheat functions[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T2_PROBE[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T2_PROBE[/color];
    [color=#7E7E7E]// Set the Overheat temperature setting[/color]
    [color=#CC6600]InternalMemory[/color].[color=#CC6600]OverheatTemp_write[/color]( 825 );
    [color=#7E7E7E]//Set Standard Menu[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]AddStandardMenu[/color]();
    [color=#7E7E7E]// Ports that are always on[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port4[/color] );
    [color=#7E7E7E]////// Place additional initialization code below here[/color]
    [color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port1[/color],12,0,22,0 );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port2[/color],13,0,21,0 );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]( [color=#006699]Port3[/color], ![color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]( [color=#006699]Port1[/color] ) );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardLights[/color]( [color=#006699]Port7[/color],13,0,21,0 );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]([color=#006699]Port5[/color],([color=#CC6600]now[/color]()-3600)%21600<1200); [color=#7E7E7E]// Runs for 1200s every 21600 seconds[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]([color=#006699]Port8[/color],(([color=#CC6600]now[/color]()-3600)-1200)%21600<1200); [color=#7E7E7E]// Runs for 1200s every 21600 seconds with 1200s offset[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]WaterLevelATO[/color]([color=#006699]Port6[/color],720,29,31);   [color=#7E7E7E]// Enable ATO the ATO[/color]
    [color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]([color=#006699]Port5[/color]))          [color=#7E7E7E]// Check to see if port 5 is on and update time is empty[/color]
        ATOUpdate = [color=#CC6600]now[/color]();                           [color=#7E7E7E]// If so, set the update time to now[/color]
    [color=#CC6600]if[/color] ([color=#CC6600]now[/color]() - ATOUpdate < 120)                [color=#7E7E7E]// If it hasnt been 120 seconds turn off the port[/color]
        [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color] ([color=#006699]Port6[/color]);            [color=#7E7E7E]// and turn off the ATO pump[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](MyCustomWave(50));
    [color=#CC6600]if[/color]( [color=#CC6600]ReefAngel[/color].[color=#006699]DisplayedMenu[/color]==[color=#006699]FEEDING_MODE[/color] ) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](0);
    [color=#CC6600]if[/color]( [color=#CC6600]ReefAngel[/color].[color=#006699]DisplayedMenu[/color]==[color=#006699]WATERCHANGE_MODE[/color] ) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](0);
    [color=#CC6600]if[/color] (hour()<12 || hour()>=22) [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]SetActinic[/color](30);
    [color=#7E7E7E]////// Place your custom code below here[/color]
    [color=#7E7E7E]////// Place your custom code above here[/color]
    [color=#7E7E7E]// This should always be the last line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"Sacohen"[/color],[color=#006699]"Seth0310"[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawCustomMain()
    [color=#CC6600]int[/color] x,y;
    [color=#CC6600]char[/color] text[10];
    [color=#7E7E7E]// Parameters[/color]
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color],
    [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color]() );
#else [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color] );
#endif [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
    [color=#CC6600]pingSerial[/color]();
    [color=#7E7E7E]// Water Level[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, [color=#006699]"WL:"[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, [color=#CC6600]ReefAngel[/color].[color=#006699]WaterLevel[/color].[color=#CC6600]GetLevel[/color]() );
    [color=#7E7E7E]// Main Relay Box[/color]
    [color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
    TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
    TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 92, TempRelay );
    [color=#7E7E7E]// Date and Time[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color]( 6, 122 );
[color=#CC6600]void[/color] DrawCustomGraph()
[color=#CC6600]byte[/color] MyCustomWave([color=#CC6600]byte[/color] maxspeed)
  [color=#CC6600]static[/color] [color=#CC6600]byte[/color] randomspeed=0;
  [color=#CC6600]if[/color] ([color=#CC6600]now[/color]()%11<5)
    [color=#CC6600]return[/color] randomspeed;
  [color=#CC6600]else[/color] [color=#CC6600]if[/color] ([color=#CC6600]now[/color]()%11>=5 && [color=#CC6600]now[/color]()%11<10)
    [color=#CC6600]return[/color] maxspeed;
    randomspeed=[color=#CC6600]random[/color](35,maxspeed);
    [color=#CC6600]return[/color] 0;
Posted: Fri May 31, 2013 7:08 am
by cosmith71
Took the liberty of making it easier to read. :D
Steve, when you do the copy from the Arduino editor, just select "Copy" and you won't get all the extra markup stuff.
unsigned long ATOUpdate=0;
ReefAngel.WaterChangePorts = Port4Bit | Port6Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port1,12,0,22,0 );
ReefAngel.StandardLights( Port2,13,0,21,0 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.StandardLights( Port7,13,0,21,0 );
ReefAngel.Relay.Set(Port5,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
ReefAngel.Relay.Set(Port8,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
ReefAngel.WaterLevelATO(Port6,720,29,31); // Enable ATO the ATO
if (ReefAngel.Relay.Status(Port5)) // Check to see if port 5 is on and update time is empty
ATOUpdate = now(); // If so, set the update time to now
if (now() - ATOUpdate < 120) // If it hasnt been 120 seconds turn off the port
ReefAngel.Relay.Off (Port6); // and turn off the ATO pump
ReefAngel.PWM.SetActinic(MyCustomWave(50));
if( ReefAngel.DisplayedMenu==FEEDING_MODE ) ReefAngel.PWM.SetActinic(0);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE ) ReefAngel.PWM.SetActinic(0);
if (hour()<12 || hour()>=22) ReefAngel.PWM.SetActinic(30);
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
byte MyCustomWave(byte maxspeed)
static byte randomspeed=0;
if (now()%11<5)
return randomspeed;
else if (now()%11>=5 && now()%11<10)
return maxspeed;
randomspeed=random(35,maxspeed);
return 0;
Posted: Fri May 31, 2013 7:32 am
by Sacohen
Thanks Collin. I use the Copy for Forum, should I use just Copy?
Posted: Fri May 31, 2013 7:34 am
by cosmith71
Sacohen wrote:Thanks Collin. I use the Copy for Forum, should I use just Copy?
Yes. If you're going to use the Code box, just use Copy.
Posted: Fri May 31, 2013 7:58 am
by Sacohen
No Problem.
Learn something new everyday. :)
Posted: Fri May 31, 2013 9:23 am
by cosmith71
I've verified the problem on my test unit, and I want you to try something.
Replace this:
With this:
ReefAngel.WaterLevelATO(Port6,720,0,1);
And see if that changes anything. I can't test it because I don't have the water level module.
Posted: Fri May 31, 2013 10:03 am
by Sacohen
Unless I'm mistaken that is the code to define the Water Level parameters.
Instead of turning on the pump plugged into Port6 when then percentage of water in the sensor goes below 29% and stop it when it reaches 31% with a time out is 720 (12 min).
What you have is turning on the pump plugged into Port6 when then percentage of water in the sensor goes to 0% and stop it when it reaches 1%. with a time out is 720 (12 min).
Posted: Fri May 31, 2013 10:07 am
by cosmith71
Yep. Instead of over-riding the relay, we're just going to set the ATO to something that it will never see, and therefore not turn on while we're waiting the extra 2 minutes.
I have a feeling that over-riding the relay may be the issue. I just can't test it.
Posted: Fri May 31, 2013 10:18 am
by Sacohen
OK. I'll try it.
I really don't want to tie up everyone's time (you, Lee and Roberto).
If this doesn't work. I will probably just go back to the first code I had working.
The amount of time it takes for the water exchange to finish is less than :30 so if the ATO kicks in for that amount of time it is not going to really effect anything.
Posted: Fri May 31, 2013 10:19 am
No need to give up!! We'll get it working.
Posted: Fri May 31, 2013 10:23 am
by cosmith71
It's a challenge now. Can't give up!
You know, a man thing. :mrgreen:
Posted: Fri May 31, 2013 10:28 am
by Sacohen
I had a feeling you would say something like that, but I feel like I'm taking all your time.
If it was me along and had the knowledge to do it I would keep working at it.
Posted: Fri May 31, 2013 11:35 am
That's like saying, oh I have this joke to tell you... Knock Knock...whose there? Oh nvm don't want to waste your time..
Posted: Fri May 31, 2013 11:43 am
by jjdezek
lnevo wrote:That's like saying, oh I have this joke to tell you... Knock Knock...whose there? Oh nvm don't want to waste your time..
Lol that's a good one
Posted: Fri May 31, 2013 12:19 pm
by Sacohen
I understand you point Lee, but a knock, knock joke takes about 30-40 seconds. This has been going back and forth for a while now.
I know you guys have lives besides this and I do appreciate what you are putting into it.
If we can get it working great, but if you ever want to say that's enough I understand.
Colins comment summed it up the best I think.
PS A Rabbi and Priest are sitting a a bar..
Posted: Fri May 31, 2013 2:23 pm
Ok try this instead...
        Serial.print (ATOUpdate);
        Serial.print (now()-ATOUpdate);
        Serial.println ("off");
        Serial.println ("on");
Run Serial monitor and record some output...put wifi back on and turn on port 5 for a quick second. After run serial monitor again, record some output, wait two minutes and record again.
Just need a few lines for each scenario.
Posted: Fri May 31, 2013 2:38 pm
by Sacohen
OK Lee. I'm not sure what you want me to do exactly.
1 Upload the new code and then run Serial Monitor for about :30.
2 Unplug the TTL - USB, plug in the WiFi and turn Port 5 on from the Portal (or other device), plug the TTL-USB back in and run Serial Monitor for :30 while Port5 is on?
3 Turn Port5 off wait 2 min and run Serial Monitor again.
Step 2 is where I'm confused. Do you want to run Serial Monitor while Port5 is running or turn on the off and then run Serial Monitor?
Also the Water Level is at 28% now do you want me to top it off before doing all of this or do you want to do it while it is low and the ATO will kick in?
Posted: Fri May 31, 2013 2:50 pm
I don't care where the water level is...I'll capture what part f the code we are in.
For step 2, we just need to trigger the routine so flip switch flip it back and then see the output. If you want , we can get a capture while the port is on then off...so step 2a & 2b.
Triggering port 5 is just to simulate your routine...This way we don't have to wait for your cycle to go through.
Posted: Fri May 31, 2013 3:42 pm
by Sacohen
Here is the Serial Monitor from step #1.
I can't get a wireless connection.
The TCP connection status is flashing green slow.
The TX/RX data transfer blinks yellow fast occasionally.
The Portal says Connection Status: Unreachable Address
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:258)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
