Hmmm..I wish RA made it more 'elegant' to control multiple tanks.Sacohen wrote:The remote relay and dimming expansion are the only things available right now.
I have the relay and it works great.
RANet Add-On
Smotz
Re: RANet Add-On
davaraj
Re: RANet Add-On
I have a RANet wireless relay box and wireless dimming module. Both are not working now. I have a few items connected to the wireless relay box. Since the box does not communicate and sync with the main head unit, can it be connected to the main unit through an expansion hub, which is in turn connected to the 1st non wireless relay box? I dont think the relay expansion module will work as it only has a SVGA connector. The wireless relay box on the other hand only has a micro usb connector. I need to have control over the wireless relay box. Can the same be applied to the wireless dimming module?
Dr Davaraj
Dr Davaraj
Re: RANet Add-On
The relay box can be connected to the hub just fine with a regular usb cable.
You just need to power it off and back on with the cable connected.
The dimming may work the same depending on how the module was built. Send me a photo of the dimming module or check if U1 is populated.
davaraj
Re: RANet Add-On
rimai wrote:The relay box can be connected to the hub just fine with a regular usb cable.
Re: RANet Add-On
U1 is not there, which means you won't be able to connect the dimming directly using USB cable.
Paulweck
Re: RANet Add-On
any updates on when this will get a full release
Kungpaoshizi
Re: RANet Add-On
I would be interested for this too
Re: RANet Add-On
There is an firmware update that is highly recommended to avoid any issues with the RANet expansion modules.
http://forum.reefangel.com/viewtopic.php?f=3&t=5885
WilliamArex
RANet Add On
Why are there no pvr client add-ons available? The repo just shows an empty add-on.
- madweazl
Re: RANet Add-On
Wasnt able to find this on the order tab; is it something that is no longer available?
- Sacohen
Re: RANet Add-On
I think they were beta versions.
Roberto should be able to tell you if he has anymore.
Sent from my SM-G928P using Tapatalk
Re: RANet Add-On
I have some still available.
We had some hiccups with the code and libraries, so I wanted to be sure it was working fine, but I don't think anyone is having issues anymore.
Send me a PM if you want to get them.
- Sacohen
Re: RANet Add-On
Mine has been working fine since I did the firmware update to it.
orucco
Re: RANet Add-On
I am about to order a RA, will it come with this ability?
- Sacohen
Re: RANet Add-On
No. The RA Net is an add on and as off now there are only two modules that work with it.
The wireless power outlets and the wireless dimming module.
