Page 3 of 3
Re: RANet Add-On
Posted: Sat Mar 28, 2015 3:46 pm
by Smotz
Sacohen wrote:The remote relay and dimming expansion are the only things available right now.
I have the relay and it works great.
Hmmm..I wish RA made it more 'elegant' to control multiple tanks.
Re: RANet Add-On
Posted: Sun Mar 29, 2015 12:18 am
by davaraj
I have a RANet wireless relay box and wireless dimming module. Both are not working now. I have a few items connected to the wireless relay box. Since the box does not communicate and sync with the main head unit, can it be connected to the main unit through an expansion hub, which is in turn connected to the 1st non wireless relay box? I dont think the relay expansion module will work as it only has a SVGA connector. The wireless relay box on the other hand only has a micro usb connector. I need to have control over the wireless relay box. Can the same be applied to the wireless dimming module?
Dr Davaraj
Re: RANet Add-On
Posted: Sun Mar 29, 2015 9:41 am
The relay box can be connected to the hub just fine with a regular usb cable.
You just need to power it off and back on with the cable connected.
The dimming may work the same depending on how the module was built. Send me a photo of the dimming module or check if U1 is populated.
Re: RANet Add-On
Posted: Sun Mar 29, 2015 4:06 pm
by davaraj
rimai wrote:The relay box can be connected to the hub just fine with a regular usb cable.
Re: RANet Add-On
Posted: Sun Mar 29, 2015 4:34 pm
U1 is not there, which means you won't be able to connect the dimming directly using USB cable.
Re: RANet Add-On
Posted: Thu Sep 10, 2015 8:01 pm
by Paulweck
any updates on when this will get a full release
Re: RANet Add-On
Posted: Mon Sep 21, 2015 12:23 pm
by Kungpaoshizi
I would be interested for this too
Re: RANet Add-On
Posted: Sat Feb 06, 2016 1:13 am
There is an firmware update that is highly recommended to avoid any issues with the RANet expansion modules.
http://forum.reefangel.com/viewtopic.php?f=3&t=5885
RANet Add On
Posted: Fri Mar 11, 2016 8:23 am
by WilliamArex
Why are there no pvr client add-ons available? The repo just shows an empty add-on.
Re: RANet Add-On
Posted: Fri Mar 11, 2016 10:53 am
What is a pvr client add-on?
Re: RANet Add-On
Posted: Sat Jun 11, 2016 8:09 am
by madweazl
Wasnt able to find this on the order tab; is it something that is no longer available?
Re: RANet Add-On
Posted: Sat Jun 11, 2016 8:11 am
by Sacohen
I think they were beta versions.
Roberto should be able to tell you if he has anymore.
Re: RANet Add-On
Posted: Sat Jun 11, 2016 8:13 am
I have some still available.
We had some hiccups with the code and libraries, so I wanted to be sure it was working fine, but I don't think anyone is having issues anymore.
Send me a PM if you want to get them.
Re: RANet Add-On
Posted: Sat Jun 11, 2016 8:19 am
by Sacohen
Mine has been working fine since I did the firmware update to it.
Re: RANet Add-On
Posted: Sat Jun 11, 2016 10:14 am
by orucco
I am about to order a RA, will it come with this ability?
Re: RANet Add-On
Posted: Sat Jun 11, 2016 10:17 am
by Sacohen
No. The RA Net is an add on and as off now there are only two modules that work with it.
The wireless power outlets and the wireless dimming module.
