New to code ra and controls
troylong45
Re: New to code ra and controls
Post by troylong45 »
ok i added sun and cloud this look right i dont know if it runs relays 1 and 3 for blues and 2 and 4 for whites and 0 and 2 dimmming blues and 1 and 3 for dimming white and storm and cloud across all 4 channels or is just white and blue better for storm?
#include <SunLocation.h>
    SunLocation sun;
    int DaylightPWMValue=0;        // For cloud code
    int Latitude=-18;
    int Longitude=147;
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port5Bit;
    ReefAngel.Relay.On( Port7 ); // Return Pump
        sun.Init(Latitude,Longitude);
        void CheckCloud()
        #define Clouds_Every_X_Days 1
        #define Min_Cloud_Duration 7
        #define Max_Cloud_Duration 7
        #define Min_Clouds_per_Day 1
        #define Max_Clouds_per_Day 2
        #define Start_Cloud_After NumMins(12,00)
          // Add Random Lightning modes
          // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
          byte LightningModes[] = {Mega2,Mega,Mega};
          static byte cloudchance=255;
          static byte cloudduration=0;
          static int cloudstart=0;
          static byte numclouds=0;
          static byte cloudindex=0;
          static int LastNumMins=0;
          static byte lightningMode=0;
        #ifdef forcecloudcalculation
          if (cloudchance==255)
        #else
        #endif
              cloudchance=random(100);
              // If we have cloud today
              if (cloudchance)
                lightningchance=random(100);
          if (cloudchance)
            //is it time for cloud yet?
              if (chooseLightning)
                chooseLightning=false;
              switch (lightningMode)
              case Calm:
                break;
              case Mega:
                  // Send the trigger
                  Strike();
                break;
              case Mega2:
                  Strike();
                break;
              case Fast:
                  Strike();
                break;
              case Slow:
                  else lightningstatus=0;
                  if (lightningstatus)
                    DaylightPWMValue=4095;
                    DaylightPWMValue=0;
                  delay(1);
                break;
              default:
                break;
              cloudindex++;
              if (cloudindex < numclouds)
              int x=0;
              else x=17;
              else x=35;
            ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
            if (lightningchance)
              int x=0;
              else x=57;
              ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
              else x=75;
        void Strike()
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
            // Flash on
            int newdata=4095;
            Wire.beginTransmission(0x40);      // Address of the dimming expansion module
            Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
            Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
            Wire.write(newdata>>8);            // This sends the MSB
            Wire.endTransmission();
            // Flash off.  Return to baseline.
            newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
            Wire.beginTransmission(0x40);    // Same as above
            wdt_reset();    // Reset watchdog timer to avoid re-boots
          cstart*=60;
          cend*=60;
    ReefAngel.ActinicLights( Port1 ); // Left Actinic Light power
    ReefAngel.DayLights( Port2 ); // Left Day Light power
    ReefAngel.ActinicLights( Port3 ); // Right Actinic Light power
    ReefAngel.DayLights( Port4 ); // Right Day Light power
    ReefAngel.StandardHeater( Port5 ); // Heater
    ReefAngel.SingleATOLow( Port6 ); // Auto top off
    ReefAngel.Relay.Set(Port8, ReefAngel.HighATO.IsActive()); // Skimmer
    ReefAngel.PWM.Channel0PWMParabola(); // Left Actinic Light 0-10v
    ReefAngel.PWM.Channel1PWMParabola(); // Left Day Light 0-10v
    ReefAngel.PWM.Channel2PWMParabola(); // Right Actinic Light 0-10v
    ReefAngel.PWM.Channel3PWMParabola(); // Right Day Light 0-10v
    ReefAngel.DCPump.ExpansionChannel[4] = Sync; // Left Jebao RW4
    ReefAngel.DCPump.ExpansionChannel[5] = AntiSync; // Right Jebao RW4
        sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
        DaylightPWMValue=ReefAngel.PWM.GetChannelValueRaw(1); // Get the current value of channel 1
        CheckCloud(); // Apply cloud routine
        ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue); // Override Channel 1 with the result from the Cloud operation
    ReefAngel.Portal( "troylong45" );
    ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
Based on the code you posted I would recommend taking out the ActinicLights and Daylights functions for port 1-4 at the top of loop. I would add at the end if statements that turn the relays on if the % is over whatever you set (look in updateLED function in my INO). This will make sure the relays are in sync with gps location.
If you want to add an offset it's easy. For an actinic offset (ie on 30 minutes before and on 30 minutes after) use this
ReefAngel.PWM.Channel0PWMParabola(30);
If you want an east/west effect (ie on 30 minutes before and off 30 minutes before)
ReefAngel.PWM.Channel0PWMParabola(30,30);
Make sure the if statements for the relays come after everything in loop that sets dimming up.
troylong45
I think the edit I made with ur help of ur ino is right about what I need. So I'll probably scrape everything else lol. And it seems like yours has off set in it the dimming is at least reflecting that I'll have to wait for guaph to get long enough to see it all working
jimsreef
Post by jimsreef »
Did you ever get Reef Angel to dim the mars aqua leds? Jim
troylong45
jimsreef wrote:Did you ever get Reef Angel to dim the mars aqua leds? Jim
yea i got the mars to work heres new code http://forum.reefangel.com/viewtopic.ph ... 141#p51141 ...
i also make mars and sb reef light upgarde kits for apex, and reefangel check out www.facebook.com/sLinkcables
