Page 3 of 3
Re: Ph cal
Posted: Wed Apr 18, 2012 10:56 pm
by pilonstar
hi everyone!
I am a bit slow thinking and i don't get it
so i got Ph9 and PH 7 from Dupla because nobody sells 10, i was looking all around australia and nothing
with 10 calibration...
so if anyone knows how to setup with 9?
7 is all good but 9
sorry for the silly question and thanks heaps in advance.
cheers.
Re: Ph cal
Posted: Thu Apr 19, 2012 7:18 am
Just go ahead and go through the calibration with 7 and 9.
Write down the numbers you are getting on the calibration process.
It's just simple interpolation.
Post those numbers and I'll help you with that.
Re: Ph cal
Posted: Sat Apr 21, 2012 2:25 am
by pilonstar
i haven't calibrated it but i did put in the water just for test and
it's giving me 7.9 at night 8.1 all morning.
i think is more or less accurate, so i will wait till receive the 10 ph from overseas.
thanks a lot.
cheers!
Erick
Re: Ph cal
Posted: Wed May 02, 2012 7:08 pm
by lucho84
hola gente necesito ayuda me estoy volviendo loco no puedo calibrar la zonda de ph
primero pongo la zonda en agua
entro al menu calibrar ph
pongo la zonda en el ph 7
lo dejo unos 3 o 4 minutos
luego enjuago la zonda en agua
la pongo en la zonda 10
espero unos 3 o 4 minutos
luego le doy ok
y mide cualquier cosa
las medidas que me da del ph
zona en liquido ph 7: 479
zonda en liquido ph 10: 500
Re: Ph cal
Posted: Thu May 03, 2012 3:19 am
by pilonstar
Si puedes tomar nota de los resultados cuando lo pones en Ph 7 y despues los resultados con Ph 10
una vez los tengas postealos por aqui.
Yo lo que no hice es no darle al okay, le di a cancelar y luego lo programe en la memoria via wifi.
De todos modos que resultados te da?
saludos.
Re: Ph cal
Posted: Thu May 03, 2012 6:10 pm
by lucho84
probe la zonda en otro medidor de ph y tira cualquier cosa, asi que supongo que el problema es la zonda... me voy a comprar otra zonda y probare a ver si con eso sale andando.
saludos
Re: Ph cal
Posted: Tue May 15, 2012 12:23 am
by J_C
Le puedes mandar un PM a Roberto, el te manda una zonda nueva.
Tus nĂºmeros no se miran bien, el pH 10 usualmente esta en los 8xx.
No te olvides de sacar el enchufe para acer un reset.
