Page 3 of 3
Re: Web Banners
Posted: Thu Feb 21, 2013 1:05 pm
by Paulturner911
Lets check. I have the following
http://forum.reefangel.com/status/banne ... 11&time=-5
Edit...Thas not right
Again
Re: Web Banners
Posted: Thu Feb 21, 2013 1:19 pm
Re: Web Banners
Posted: Thu Feb 21, 2013 1:23 pm
by Paulturner911
I had time spelled out, I think it was on the first page to the thread.
Re: Web Banners
Posted: Thu Feb 21, 2013 2:27 pm
I fixed that post.
Re: Web Banners
Posted: Wed May 22, 2013 3:47 am
by brettb
What are the chances of having the water level displayed on the web banners? For those who have water level sensors.
Re: Web Banners
Posted: Wed May 22, 2013 7:48 am
Yeah, I can work on that...
Re: Web Banners
Posted: Wed May 22, 2013 8:59 am
by brettb
Great stuff, Would be great to have. Water level is always a good indication of something gone wrong in a tank. My level expansion is on the way =)
Re: Web Banners
Posted: Wed May 22, 2013 9:13 am
Done
Re: Web Banners
Posted: Wed May 22, 2013 11:01 am
by brettb
That is great! Thanks Roberto!
Re: Web Banners
Posted: Fri May 24, 2013 3:40 pm
by paulvisco
Do you have a temlplate that one could work from (code) to generate a diffrent banner. i have a few ideas that i would like ot play with but...
having the backend code that generates the image is needed.. is it open or closed source..
Re: Web Banners
Posted: Fri May 24, 2013 3:55 pm
This should give you an idea.
I need to clean it up and optimize the SQL queries, but never had a chance...
Re: Web Banners
Posted: Fri May 24, 2013 10:10 pm
by paulvisco
cool thank you..
Re: Web Banners
Posted: Sat Feb 22, 2014 12:25 am
by monte455
Ok I tried to update my signature but it says I can't post links and to change or remove reef angel dot com, what gives?
Re: Web Banners
Posted: Sat Feb 22, 2014 6:00 am
Think you need to have 5 posts...
Re: Web Banners
Posted: Sat Feb 22, 2014 9:03 am
Spam couter-measure feature.
It won't let you post links until you reach a certain number of posts.
I removed the restriction on your profile and you should be able to post links now
Re: Web Banners
Posted: Sat Feb 22, 2014 6:03 pm
by monte455
Perfect much appreciated.
Sent from my SPH-L900 using Tapatalk
Re: Web Banners
Posted: Mon Dec 08, 2014 8:03 am
by Xender
Any ideas why my web banner doesn't update?
portal ans IOS App working good.
My web banner stay at 2012.
[img]http://forum.reefangel.com/status/banner_4.aspx?id=Xender&t=1[/img]
Re: Web Banners
Posted: Mon Dec 08, 2014 9:59 am
It was the last time your controller sent data to the server.
Maybe you enabled the portal key in the portal settings and never updated your code.
Try disabling the key.
Re: Web Banners
Posted: Mon Dec 08, 2014 10:41 am
by Xender
Nice it's was that !thanks!
