Page 29 of 33
Posted: Fri Mar 27, 2015 9:19 am
thanks for the link. i will look into it more and see how it works. i knew it could be done because that's how the Google Apps are. Gmail will update as far as it can but not update any farther than allowed.
Posted: Sat Mar 28, 2015 10:28 am
by Sacohen
Thanks Binder.
Feel better.
I've been on a cruise and out of contract with things.
If the different themes are to difficult, then forget it.
Posted: Sat Mar 28, 2015 12:14 pm
Sacohen wrote:Thanks Binder.
Feel better.
i have been feeling better...much better. must be nice to be on a cruise
oh no....the themes are not too difficult. they are a great idea. I actually like the option of changing between light and dark. I'm just trying to design it correctly and simplify the process. me looking into this has led me to discover better ways to handle things and makes me improve the functionality to make it easier to maintain and to allow more improvement in the future.
Posted: Sat Mar 28, 2015 12:17 pm
by Sacohen
Great.
The criuse is nice. We do it once a year.
The wife and kid love the Disney Cruise.
Posted: Sun Mar 29, 2015 4:23 am
by cosmith71
Would still love to see custom memory locations.
Posted: Sun Mar 29, 2015 6:58 am
cosmith71 wrote:Would still love to see custom memory locations.
you mean where you can create a list of your own memory locations instead of having to manually enter them each time?
Sent from my Moto X
Posted: Sun Mar 29, 2015 7:54 am
by cosmith71
Yep. Exactly!
Posted: Sun Mar 29, 2015 8:11 am
by Sacohen
Binder,
Is there anyway to see the web charts or relay history for a couple of days, like in the portal?
Posted: Sun Mar 29, 2015 9:34 am
Sacohen wrote:Binder,
unfortunately no.
i store all the data but i only display the history of the main controller data (no relays or expansion modules).
so, the data is all there but not being displayed at all. the history section is severely lacking and keeping the app from its full potential.
Posted: Sun Mar 29, 2015 9:39 am
by Sacohen
Ok.
I was only asking because there are times I'm away from a computer and chrome on my Android will not display the "tabs" of the portal.
Posted: Tue Mar 31, 2015 5:12 pm
Ok, I've got a second beta test for the app. I've changed the version to 2.0.0 - Beta 2. I plan on making the final release a major version change.
I fixed the couple errors that you guys were having. I fixed the
- crashing on changing the dc pump mode
- random viewpager crash in the app
- update text line is smaller to fit the entire date string
If all goes good with this round of testing, I should be getting close to doing a major release. I need to get the preferences page fixed up and displaying properly before I will give it the official release.
Thanks for the feedback Pandimus, Sacohen, dapg8gt, phrusher.
Here's the link to download the debug version. Again, this will not replace your default install...it installs alongside the official release version.
http://curtbinder.info/apps/ra-2.0.0.beta2-debug.apk
And yes, I still have a list of the features that I'm trying to work on.
Posted: Tue Mar 31, 2015 5:20 pm
by pandimus
Started testing it..
Do you guys get a device 13 error when you initiate a reboot? My controller reboots. But i always get the error
Posted: Tue Mar 31, 2015 5:25 pm
by Sacohen
I just downloaded and installed it too.
I don't get the error 13 on reboot.
I will get an error retry 1 when doing a reboot, but that's because it's trying to update before the reboot is done.
Posted: Tue Mar 31, 2015 5:27 pm
by pandimus
Odd. I consistently get that error
Posted: Tue Mar 31, 2015 5:33 pm
by Sacohen
Binder,
The DC page works fine now.
It doesn't crash, but it's still missing the custom mode.
I keep mine in custom, because of the code that Lee wrote to randomly change the mode daily.
When I changed it to "Else" mode to test the app I can't get it back to custom without going back to the portal.
Posted: Tue Mar 31, 2015 5:35 pm
by pandimus
Same else mode fixed...
Posted: Tue Mar 31, 2015 7:42 pm
hmmm... i am unaware of this custom mode. I guess I will have to look at the code more.
Sent from my Nexus 7 using Tapatalk
Posted: Tue Mar 31, 2015 7:45 pm
pandimus wrote:Started testing it..
it could be because of the retry time out being so short. I may have to either disable the auto refresh on the reboot command or make it wait longer than 1 second before communicating again... like 5 seconds or so.
Posted: Wed Apr 01, 2015 5:34 am
Are you using the 2014 screen or are you using a custom screen? I ask this because I'm using it on my test controller and it displays "blank" for the mode when we are in the custom mode.
What actual value are you using for Custom mode? I'm looking at the code and it appears that 11 is used for Custom mode based on the Globals.h file. However, the 2014 screen code is showing that 10 is used for the Custom mode. If you look at the Globals.h, 10 is set for Storm.
I'm just trying to clarify things and make sure there is consistency with the code. If you are not using the 2014 screen, then there is probably a bug in the displaying of the mode, which is simple to fix.
Posted: Wed Apr 01, 2015 6:09 am
by Sacohen
I'm not using the 2014 screens and I have modified the default screen slightly by adding 2 lines for my water level sensors.
I believe 11 is being used for the custom mode.
Here is my code...
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Kalkwasser 3
#define Pumps 4
#define Unused 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define ATO_Pump 8
#define Unused Box1_Port1
#define Feeder Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Main_RODI Box1_Port7
#define Dummy Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Water Level
ReefAngel.AddMultiChannelWaterLevelExpansion();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("Sacohen:xxxxxxxx");
//DDNS Server
ReefAngel.DDNS("myreeftank");
ReefAngel.AddRANet();
ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
//ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
//ReefAngel.DCPump.AntiSyncOffset=85;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.WaterLevelATO(0,ATO_Pump,720,34,36);
if ( hour()>=13 && hour()<21 )
ReefAngel.PWM.SetChannel( 5, 0 );
ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
//Flush RO/DI Membrane 3 times a week @ 9pm.
ReefAngel.Relay.Set(Main_RODI,(now()+10800)%(SECS_PER_DAY*3)<300);
//Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)==100 && prevWL<100) {
stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
//AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
ReefAngel.FeedingModeStart(); //START FEEDING MODE
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
ReefAngel.Relay.On(Feeder); //TURN FEEDER RELAY ON
ReefAngel.Relay.Off(Feeder); //TURN FEEDER RELAY OFF
} else {
if ( autofeeding > 0 ) {
autofeeding = 0;
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime); // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
// Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
lowSalFlag=true; // Salinity is definitely below 33.5
} else {
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
//if (lowSalFlag) ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
// Add random mode if we set to Mode to Custom in portal
static int rmode;
byte modes[] = { ReefCrest, Gyre, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, };
if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
// Continue NTM for the 60 minutes
ReefAngel.DCPump.Mode=NutrientTransport;
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
// Night mode (go to 30%)
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==11) {
ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
} else {
ReefAngel.Portal( "Sacohen","xxxxxxxx" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
// Date and Time
Posted: Wed Apr 01, 2015 6:39 am
Sacohen wrote:I'm not using the 2014 screens and I have modified the default screen slightly by adding 2 lines for my water level sensors.
Awesome. thanks. it does appear that the 2014 screen code is not displaying the custom mode properly. it is off by 1 in its display index. I will fix it and submit a pull request. this wont affect you but it is needed.
now, I will be adding that to my app and maybe do another release for you today. or i may hold off until the weekend and see if i can get a couple other things added as well to get it closer to an official release.
Posted: Thu Apr 02, 2015 4:46 pm
by pandimus
Everything seems to work well now.. No defects noted..
Posted: Thu Apr 02, 2015 5:36 pm
by pandimus
Well.. Im looking at my ai page and i notice it constantly says 255 percent even though the portal says the actual percentage.. I notice the old app does same thing... I dont have my ai hooked up atm, but just wanted to point this out
Posted: Thu Apr 02, 2015 5:43 pm
pandimus wrote:Well.. Im looking at my ai page and i notice it constantly says 255 percent even though the portal says the actual percentage.. I notice the old app does same thing... I dont have my ai hooked up atm, but just wanted to point this out
ok. good to know. maybe i'm doing something wrong and handling the value incorrectly. or maybe i'm just not storing it properly.
Posted: Mon Apr 06, 2015 6:51 pm
by AlanM
Curt,
I downloaded the new 2.0.0 app. One thing I noticed, but maybe I did it wrong.
-The setup wizard asked me if I was doing the reefangel ddns and told me correctly what my hostname would be for it, but then refused to connect in "away" mode. I went into the settings and saw that it had the away host as simply "home" instead of "alanm-home.myreefangel.com" as it should have. It started connecting when I changed that in the settings.
- It gets the 16 channel dimming module all correct and lets me set percentages for that, so it works great.
- Can there be a way to set custom variables when those are enabled by holding on the value just like you do with dimming and dc pump? You'd just need to call the url "
http://dns:2000/cvar1,150" or whatever it is set to and watch for the OK to come back similar to the other overrides, I think.
Posted: Mon Apr 06, 2015 10:52 pm
by pandimus
Not sure if its a memory location thing.. But the blue controls the royal blue and royal blue controls blue on ai page.. At least whithin the page.. I still need to figure out whats the matter with my ai cable for real time trouble shooting
Posted: Tue Apr 07, 2015 8:18 am
AlanM wrote:Curt,
good to know. i will check this. it could very easily be a bug that needs fixed.
great! glad this still works as expected.
yes, this is still on my todo list. i have an issue created on my own tracker. it is slated to be implemented. i have been detoured in the conversion to using the new material themes and improved toolbar (instead of the actionbar). i will double check on when i have a target version for it and try to get it in sooner.
i am going to try for the improved release sooner, release often approach. some of the changes im making are significant undertakings and have been long overdue and taking longer than anticipated.
Posted: Wed Apr 08, 2015 12:26 pm
pandimus wrote:Not sure if its a memory location thing.. But the blue controls the royal blue and royal blue controls blue on ai page.. At least whithin the page.. I still need to figure out whats the matter with my ai cable for real time trouble shooting
ok. keep me posted on this. i will look at the code and see if i can see something wrong with it.
Posted: Sat Apr 11, 2015 6:51 pm
by pandimus
This error I'm having with the ai sol control is definitely on your end.. You have the dimmer control backwards on royal blue and blue.. I thought it might just be an indication problem, but they are indicating the same on my portal.
Posted: Sun Apr 12, 2015 10:47 am
pandimus wrote:This error I'm having with the ai sol control is definitely on your end.. You have the dimmer control backwards on royal blue and blue.. I thought it might just be an indication problem, but they are indicating the same on my portal.
ok, great to know. i will get it fixed up. thanks for taking the time to determine the source of the problem.
