Re: Custom Main Screens
Posted: Sun Sep 16, 2012 2:40 pm
Is the Cloud and time portion meant to eventually show when the next clouds are?DrewPalmer04 wrote:Lol good ol' photobucket messing up
https://forum.reefangel.com/
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Display");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
ReefAngel.LCD.DrawText(0,255,8,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
ReefAngel.LCD.DrawText(0,255,70,68,"Light");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawText(0,255,48,100, "Cloud");
ReefAngel.LCD.DrawText(0,255,41,108, "Duration");
ReefAngel.LCD.DrawText(0,255,60,30, "5v");
ReefAngel.LCD.DrawText(0,255,60,40,PWMSlope(20,2,6,0,0,100,255,0));
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 860 );
ReefAngel.PHMin=830; // 830=PH10.0
ReefAngel.PHMin=480; // 480=PH7.0
ReefAngel.SingleATO( true,Port1,60,0 );
pinMode(lowATOPin,OUTPUT);
//pinMode(highATOPin,false);//disable highATOpin
ReefAngel.Relay.On(Port3);//Koralia
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.Off(Port2);//Off
ReefAngel.Relay.Off(Port1);//Off
ReefAngel.Relay.On(Port8);//temp fan on (see Standard Fan)
//ReefAngel.AddWifi();
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMParabola(6,5,21,0,0,85,0);//85%
DaylightPWMValue=PWMParabola(7,5,19,0,0,80,0);//80%
CheckCloud();
//ReefAngel.StandardHeater( Port4,740,770 );
ReefAngel.StandardLights(Port7,8,15,18,30);//On 8:15 Off 6:30
ReefAngel.StandardFan(Port8,900,910);
//5 min turbulence wavemaker
if ( (hour()>=7 && hour()<11))
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
if (cycle<0)
nexttoggle+=random(35,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
else if ( (hour()>=11 && hour()<13) )
if (cycle<0)
nexttoggle+=random(10,20);
state=!state;
if (cycle<5)
else if ( (hour()>=13 && hour()<20) )
if (cycle<0)
nexttoggle+=random(15,45);
state=!state;
if (cycle<5)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
// ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,80,0) );//80%
// ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );//85%
//if (hour()>=6 && hour()<20)
//analogWrite(lowATOPin,0);
//else
analogWrite(lowATOPin,2.55*PWMSlope(20,2,6,0,0,100,255,0));
void CheckCloud()
#define Clouds_Every_X_Days 2
#define Cloud_Chance_per_Day 60
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 2
#define Max_Clouds_per_Day 4
// In this example, start could after 10:30am
#define Start_Cloud_After NumMins(10,30)
// In this example, end could before 5:30pm
#define End_Cloud_Before NumMins(17,30)
#define Lightning_Change_per_Cloud 0
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
//ReefAngel.LCD.DrawText(0,255,45,120,"L");
//ReefAngel.LCD.DrawText(0,255,51,120,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=48; else x=54;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart/60));
if ((cloudstart%60)>=10) x=66; else x=72;
ReefAngel.LCD.DrawText(0,255,x,57,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,56,119,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
bingolnevo wrote:1/2 circle could also represent moonphase...
byte a;
//* Edit History modified from.....
//* <MLS> = Mark Sproul msproul -at- jove.rutgers.edu
int FULLCIRCLE = 1;
int OPENEAST = 2;
int OPENWEST= 3;
int OPENNORTH = 4;
int OPENSOUTH = 5;
int OPENNORTHEAST = 6;
int OPENNORTHWEST = 7;
int OPENSOUTHEAST = 8;
int OPENSOUTHWEST = 9;
void LCDDrawCircle (int xCenter, int yCenter, int radius, int color, int circleType)
int tSwitch, x1 = 0, y1 = radius;
int Width = 2*radius, Height=Width;
tSwitch = 3 - 2 * radius;
while (x1 <= y1) {
if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENEAST||circleType == OPENSOUTHEAST) {
ReefAngel.LCD.PutPixel(color,xCenter+radius - x1, yCenter+radius - y1);
ReefAngel.LCD.PutPixel(color,xCenter+radius - y1, yCenter+radius - x1);
if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENEAST||circleType == OPENNORTHEAST) {
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + x1, yCenter+radius - y1);
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + y1, yCenter+radius - x1);
if (circleType == FULLCIRCLE||circleType == OPENNORTH||circleType == OPENWEST||circleType == OPENNORTHWEST) {
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + x1, yCenter+Height-radius + y1);
ReefAngel.LCD.PutPixel(color,xCenter+Width-radius + y1, yCenter+Height-radius + x1);
if (circleType == FULLCIRCLE||circleType == OPENSOUTH||circleType == OPENWEST||circleType == OPENSOUTHWEST) {
ReefAngel.LCD.PutPixel(color,xCenter+radius - x1, yCenter+Height-radius + y1);
ReefAngel.LCD.PutPixel(color,xCenter+radius - y1, yCenter+Height-radius + x1);
if (tSwitch < 0) {
tSwitch += (4 * x1 + 6);
} else {
tSwitch += (4 * (x1 - y1) + 10);
y1--;
x1++;
a=second()%9;
if (a==1) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENEAST));
ReefAngel.LCD.Clear(255, 10, 10, 120,120);
if (a==2) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENWEST));
if (a==3) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTH));
if (a==4) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTH));
if (a==5) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTHEAST));
if (a==6) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENNORTHWEST));
if (a==7) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTHEAST));
if (a==8) (LCDDrawCircle(50, 50, 20, T1TempColor, OPENSOUTHWEST));
if (a==8) (LCDDrawCircle(50, 50, 20, T1TempColor, FULLCIRCLE));
ReefAngel.LCD.DrawDate(5,121);
ReefAngel.Init();
}Code: Select all
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
JoelIreland wrote:Hi all, thought i'd share my custom main screen ( still tweaking ) would love to know your thoughts.
Error Screen
No Power with timer Countdown
yes, code please?lnevo wrote:Where's the code
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardHeater( Port2,780,790 );
ReefAngel.StandardHeater( Port3,780,790 );
ReefAngel.MHLights( Port4,10,0,21,0,7 );
ReefAngel.Wavemaker( Port5,100 );
ReefAngel.WavemakerRandom( Port6,60,120 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,21,0,0,90,0) );
ReefAngel.PWM.SetActinic( PWMParabola(9,30,22,0,0,90,0) );
ReefAngel.Portal( "badger55" );
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawText(0,255,3,17,"Dan's 90 gal Reef");
ReefAngel.LCD.DrawText(0,255,70,68,"Display");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
