Page 4 of 4
Re: New User Questions
Posted: Wed Feb 26, 2014 7:13 pm
by howaboutme
rimai wrote:Use the controllertester code in the examples folder to test each port.
roberto..this is in regard to the post about relay #6 not shutting off during feed/wc mode..i did the controllertest code..flipped through it but wasn't sure what to look for. the outlet was on when i flipped to #6. is that what you're testing? thanks.
Posted: Wed Feb 26, 2014 7:57 pm
You can scroll through each port turning it on and off by moving the joystick. Look at the screen to see which port is turned on.
Posted: Wed Feb 26, 2014 8:13 pm
by howaboutme
Yeah, I did that and everything seems to be okay for the test. #6 just won't turn off even though the code is correct. This is the 2nd time this happened. First time, the problem solved itself somehow w/o me doing anything.
Posted: Wed Feb 26, 2014 10:32 pm
Are you sure you are not overriding the relay port?
Posted: Thu Feb 27, 2014 6:35 am
by howaboutme
rimai wrote:Are you sure you are not overriding the relay port?
No, I am not sure. But I don't think so. I do nothing to the controller before I hit either the feeding or wc mode. I even re-uploaded the code last night to the controller and #6 still didn't recognize the mode. I am thinking tonight I will try to move the ph that's on #6 to an open outlet to test again.
How would I override the relay port? Since I am new I cannot rule that out inadvertently.
PS. I obtained a wifi module that I worked on briefly last night too. I have a few questions but will post a different thread so my questions won't get lost in this. Thanks.
